Sharp LC-60E79U Backlight Flicker
  • SolderMaster
    • Dec 2013
    • 53
    Hiya folks.
    This one has a backlight flicker problem as the title states. Eventually the set will shut itself down into protect mode.
    Right now I have it in my basement running Youtube videos off an Xbox 360 for a source. Gonna let it run over night to see if I can get it to crash.
    It seems to flicker mainly on the right side of the screen. Tapping on the metal top piece of the inverter board seems to make it stop for a few seconds before the flicker starts back up.
    The main model number of this set is LC-60E77UN. https://www.manualslib.com/manual/91...page=65#manual
    I'll check in tomorrow and let ya'll know what happened.
  • CapLeaker
    Leaking Member
    • 8119
    Re: Sharp LC-60E79U Backlight Flicker
    cold solder joint, or bad transformer.
    • SolderMaster
      • Dec 2013
      • 53
      Error code is DET_15V (34pin) error (L). UR13V is not applied.
      If error is detected during operation, error standby is activated by
      polling. ( Pwr flashes x2, OPC flashes once )
      On the power supply or the inverter, CapLeaker?
      Voltages on Power Supply going to Main:
      PNL_POW = 3.26
      BU5V = 5.00
      PS_ON = 2.8
      AC_DET = 3.0
      S14.3V = 14.39
      UR14.3V = 14.39
      PNL12V = 11.97
      PNL12V = 11.95
      Both red wired cables have 24V where it should
      All voltages recorded white TV is on and flickering.
      • CapLeaker
        Leaking Member
        • 8119
        Look at the solder joints on everything on the HV side on the inverter board. Also check these blue litte HV caps at the CCFL plug. Compare the HV output (secondary) on each transformer with your DMM on Ohm scale and note it down. If one transformer is more than 3% off, that's the bad one. The bad transformer will also run hotter than the others. Hope that helps you to get started.
        • SolderMaster
          • Dec 2013
          • 53
          I took the slave M2 board out, smaller one with 3 transformers on it, and measured Ohms from Hot to DC, the only one that reads any different is T1601. Lower at 1550 Ohms vs 1580 like the rest of them. Also, there is a "cooked" look to the connector going into the CCFL connector. The back side of the CCFL looks "cooked" as well.
          Can that be replaced along with the board and/or transformer? I do have experience replacing LED strips on LED Tvs so I'm not afraid to tear the whole thing down.
          What little blue caps?
          Set now flashes "Lamp Error" 1 blink of the Power light.
          Last edited by SolderMaster; 01-03-2019, 07:07 PM. Reason: Forgot stuff, new error code
            • 12123
            • U.S.
            Testing transformers, couldn't find one on sharp, you said you have lamp error. If you have a bad lamp it should show up on transformer test. https://www.youtube.com/watch?v=oE6K4xBVweA
            • SolderMaster
              • Dec 2013
              • 53
              This set is now stuck in the lamp error mode. I can force it on, backlight comes on for a split second then turns off, then tv shuts down flashing lamp error. I was able to get into service mode and using a flashlight, navigated to the lamp error reset and turned it on. Powered down set, and restarted. Tv came on for a second then shut down again with lamp error.
              Has anyone here upgraded to LEDs in one of these sets? Or should I scrap this thing and move on?
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
              • Misterfixit
                Sharp LC-58Q7330U No Backlight
                by Misterfixit
                This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
                06-04-2023, 07:39 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • Misterfixit
                sharp LC-50LB601U No backlight
                by Misterfixit
                I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
                04-04-2023, 01:21 PM
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
