SAMSUNG UE46D5520 rebooting
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: SAMSUNG UE46D5520 rebooting
    could a bad t con cause this issue? or maybe keep a look out for a smashed screen set and swap the boards over etc.
    • finntricky
      • Jan 2014
      • 449
      • uk
      Head scratcher, unless your firmware is wrong or your preparation of the chip is off somehow or your programmer?
      i never programmed the chips, they was sold to me as programmed, i don't have the equipment to do it anyway, and would not know where to start on that side of things.
      • finntricky
        • Jan 2014
        • 449
        • uk
        im looking m8, but they are like gold dust, just like the main boards for the tvs
        • nomoresonys
          • 12274
          • U.S.
          Repair service there, must be pretty popular 5 sold in 24 hours. https://www.ebay.co.uk/itm/SAMSUNG-U...2ux:rk:26:pf:0
          • nomoresonys
            • 12274
            • U.S.
            My bad, got the details wrong.
            • Mungry
              • Oct 2020
              • 13
              • United Kingdom - England
              #26
              I know this is an old thread but did anyone get any further with this fault?
              I have a TV doing the same starting up and then turning off. It is on long enough to get a picture or channel come up and I can just get in to the first couple of menus before it turns off.
              The Power PCB is whistling a bit. the problem is it is a chicken and egg situation to find out if it is the main power board that is shutting down or the main board causing it to. When you unplug the wires from power to the main board the LED back lights stay on and TV does not keep turning off, plug it back in and the tv reverts back to constantly turning on and off.
              When it stays on long enough the panel works fine picture is good with sound, just won't stay on. There seems to be no bad capacitors on the power PCB, voltages on the panel look good when its on.
              Seems like Samsung has had this issue for some time and I would have thought it would be an easy fix to find now?
              • nomoresonys
                • 12274
                • U.S.
                #27
                Having the exact same issue with a samsung UN, H series. Did you try freezing the nand/spi/eeprom to see if it stays on longer?
                • nomoresonys
                  • 12274
                  • U.S.
                  #28
                  Video there: https://www.youtube.com/watch?v=bJ8HSLlOwA8
                  • Mungry
                    • Oct 2020
                    • 13
                    #29
                    I will give that a go. I have tried hardwire reset and putting PCB in freezer for 4 hours but not cold enough. I did also try lighter fluid but you have to wait for that to evaporate or you could be in trouble ;-) Looking at the video it is critical to get that chip cold. So of to shops for some freezer spray.
                      What happen if you disconnect the cables between LCD panel and the T-CON?
                      • Mungry
                        • Oct 2020
                        • 13
                        #31
                        Hi, If you disconnect the cable from the power board to the main interface board the back light stays on and TV does not switch on and off. Any other cables disconnected the TV carries on switching on and off. I have freezer spray now so will give the Eprom a blast but now I have to wait for Samsung's Website downloads to be fixed. For some reason I could not download them so contacted webchat and after 1 hour on there they realised their site was not working and is a known issue. They say they will fix it. Until I get hold of the updated software I can't move forward with this. It is a bit of chicken and egg as to cause and which PCB it is. Either one could be at fault but after seeing a you tube video of the same TV with exactly the same fault and what he did to get the TV to stay on etc. So I thought I have nothing to lose. The TV will be scrap if I can't fix it and I got it for nothing. But hope I can sort it if possible.
                        I do get a picture and sound when I have aerial plugged in so the TV and panel do function for a brief time.
                        Cheers Budm, I have seen your help and assistance and I have checked some of the voltage levels etc as you mention.
                        • Mungry
                          • Oct 2020
                          • 13
                          #32
                          Is there another way to get the software? Does anyone else have it?
                          Just a thought.
                          Cheers,
                          Paul.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #33
                            The website and download links are working. https://www.samsung.com/uk/support/m...E46D5520RKXXU/
                            • Mungry
                              • Oct 2020
                              • 13
                              #34
                              OK just to update, I read about certain internet browsers not working on Samsungs website download so tried Edge instead of Google Chrome and the download worked OK.
                              Got both versions available on the USB and ready to go. tried them one at a time after freezing eeprom. TV stayed on much longer so I could select the menu.
                              Tried both and TV just says no software to download or upgrade when I try. It knows the USB drive is there but won't load the upgrade at all. I have tried a hardware reset as well. and download via hard internet connection and still will not download.
                              It is looking like this TV is bricked. If I can't get the software to download or keep the TV on I am now stuck.
                              Any advice welcomed?
                              Cheers,
                              Paul.
                              • Mungry
                                • Oct 2020
                                • 13
                                #35
                                Hi Diif, thanks for your reply. The link you sent above does not work either for me in Google Chrome. But I sorted this by using Edge Internet Browser ;-)
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  #36
                                  Working fine with Firefox and Chrome.
                                  You've extracted the update to the USB ?
                                  • Mungry
                                    • Oct 2020
                                    • 13
                                    #37
                                    Hi Diif, Yes I got the file extracted. So I have -
                                    Upgrade File(USB type) ver 1027.0 (MULTI LANGUAGE)
                                    : All OS
                                    2015-06-24
                                    Downloads [61.71 MB]
                                    Upgrade File(USB type) ver 1025.0 (MULTI LANGUAGE)
                                    : All OS
                                    2015-04-23
                                    Nether would load on the TV. I assume it is because the TV already has this update? Maybe I did not do the reset properly? But now stuck.
                                    Cheers,
                                    Paul.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #38
                                      You've run the downloaded .exe and it's created the folder on the memory stick ?
                                      • Mungry
                                        • Oct 2020
                                        • 13
                                        #39
                                        Yep, it has the folder and the original file. I tried it a few times. TV just did not want to read the file or upgrade. I also tried both USB ports. The TV only had mains and the USB stick connected. I am sure I am doing something wrong?
                                        • nomoresonys
                                          • 12274
                                          • U.S.
                                          #40
                                          Strange that it doesn't want to update thru usb, you might have the latest firmware already on tv, can you see anywhere that says what your current version number of firmware is? Wonder if you could update it thru ethernet, maybe, as long as the tv stays on long enough, might need to give it a periodical shot of freeze-spray to keep it cold.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • DynaxSC
                                            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                            by DynaxSC
                                            Hi
                                            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                            08-04-2025, 12:20 PM
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                            Common SPI bios chip programming Questions and Answers
                                            by SMDFlea
                                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                            A: If you can`t read from it how do you expect to write to it ?.
                                            Q: Why is my bios chip unreadable ?.
                                            A: The programmer is faulty or has a worn or broken zif socket.
                                            The USB cable is frayed,connector pins worn or some other physical damage.
                                            Not enough amperage or voltage to power the programmer properly.
                                            Bad...
                                            09-02-2021, 04:40 PM
