Samsung LN40A550P3F 40" HDTV, slow to turn on
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: Samsung LN40A550P3F 40" HDTV, slow to turn on
    Can you verify that the piggy back cap negative ( - ) end is on the left side of the original cap. The stripe on the original cap is the positive ( + ) end.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Personally, I've never had any luck with changing that chip. Either the capacitor does the trick or nothing works. I do typically change C131 on the front of the board as well (same cap rating as C102).
      Originally posted by samsonite
      This video at 5:00 explains that both c102 and a nearby 8-pin IC chip should be replaced:
      https://www.youtube.com/watch?v=oC4f2Ik8rCI
      They also used a heat gun and tweezers to remove that stubborn SMD, btw. I don't have a heat gun, so I would
      need some kind of heat clamp to remove the SMD in one go.
      My IC chip says:
      MP2363DN
      83833419
      MPS818
      My Main Board:
      BN41-00975B (2008.01.13)
      MODEL: PEARL
      This link doesn't describe the IC chip they sell:
      https://www.shopjimmy.com/samsung-bn...a530p1fxza.htm
      Is this the chip?
      https://www.digikey.com/product-deta...366-ND/5299123
      I could try replacing that as a last resort. Does that sound reasonable?
      • nomoresonys
        • 12306
        • U.S.
        Yes, I remember them changing both C131 and C102 also.
        • samsonite
          • Jul 2015
          • 46
          I may try to re-solder C102 again. I think I need a cheap heat gun, because it isn't coming off for me.
          And C131 is on the opposite side of main board near a power connector. It looks crowded, so I will have a difficult time with it without a heat gun.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Just add solder to both sides of the cap and you could use both irons to heat both sides at once and remove it.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              What DC voltage do you have across the capacitor you soldered in?
              • samsonite
                • Jul 2015
                • 46
                That sounds like a good idea. I was trying to wick away solder instead of adding more. But my luck, the solder will ball up and stick to the iron instead.
                As for the voltage, sorry, I don't know. How do shops test these boards when they only have the board and no TV?
                • nomoresonys
                  • 12306
                  • U.S.
                  #28
                  Solder iron prep. https://www.youtube.com/watch?v=7PWmMxjXwYE
                    https://www.badcaps.net/forum/attach...2&d=1548278425
                    What is that silver color blob between the two legs on that added on cap?
                    • samsonite
                      • Jul 2015
                      • 46
                      Yes, I realize I would get a better connection if the capacitor legs actually touched the pads instead of being blobbed on, but that's the best I can do with the tools I have. I don't have the hottest iron or the smallest diameter solder core right now. But, I think I'm going to put this project on hold for another week until I get some better stuff. Thanks.
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        #31
                        Take a pic of the capacitor from the legs. There looks like a "blob" between the legs what brand is that capacitor?
                          I am talking about the silver blob between the two legs (where the legs come out of the body of the cap) of that Blue shown in your picture.
                          • samsonite
                            • Jul 2015
                            • 46
                            It must be the lighting, because it's really some kind of black plastic plug. Specs call it "sealing rubber". The cap doesn't look ruptured. That's the way I received it.
                            I was looking at these.
                            P11196-ND (FC)
                            47uF 16V Aluminum Electrolytic Capacitors Radial, Can 1000 Hrs @ 105°C
                            https://www.digikey.com/product-deta...1196-ND/356100
                            P14478-ND (GA)
                            47uF 10V Aluminum Electrolytic Capacitors Radial, Can 1000 Hrs @ 105°C
                            https://www.digikey.com/product-deta...478-ND/2504567
                            P12923-ND (FM)
                            47uF 25V Aluminum Electrolytic Capacitors Radial, Can 2000 Hrs @ 105°C
                            https://www.digikey.com/product-deta...2923-ND/762833
                            P10267-ND (FC)
                            47uF 25V Aluminum Electrolytic Capacitors Radial, Can 1000 Hrs @ 105°C
                            https://www.digikey.com/product-deta...0267-ND/266276
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4516
                              • Italy - Milan
                              #34
                              The cap is a Panasonic, red M stays for Matsushita.. anyway the not removing the old cap is not a good thing, tantalum caps last longer than electrolytic ones for a matter of capacity but them can go short circuit...
                              • samsonite
                                • Jul 2015
                                • 46
                                Well, I finally got C102 off, got rid of my new capacitor too, and replaced it with a new SMD cap (KEMET 399-18658-1-ND). Powered up the TV and still not working. Red LED light keeps blinking forever. So, either the problem is somewhere else, or I toasted the board.
                                And I can't measure any voltages, because this is the backside of the board. After I screw the board in, and hook the cables up, you can't access it. Also, this board has 4 grounding screws, so I always make sure they make good contact with the board when I screw them in, so I see no issues with my re-assembly either.
                                Maybe I will replace these IC chips, IC101 and IC102, as a last resort.
                                • sean0118
                                  • Jun 2016
                                  • 103
                                  Yes, lead-free solder has a high melting point, but if you add leaded solder it will melt easier.
                                  Then use two soldering irons, one either side to lift it off. Once it's removed use solder wick to remove all the existing solder. Then solder the new capacitor on, one pad at a time.
                                  edit: Post a pic of the main board as it is now, with the new capacitor.
                                  Might also be worth trying your original power supply board? In case the Shopjimmy one from your first post is faulty.
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    #37
                                    There is one more cap on the top side of the board you could try and replace. I can't remember where it's located, but I know it's in a tight spot.
                                    • samsonite
                                      • Jul 2015
                                      • 46
                                      Well, it's not too pretty. The board still has flux on it, and I put too much solder on the pads, and had some trouble getting it off, so I left it for now. And I accidently got some solder on R107, and had some trouble getting that off too, which is why R107 looks charred. And you can't tell from the photo, but the SMD does have a small stripe on one side indicating positive polarity, but not visible here.
                                      BTW, is there anyway to reset the power cycle on a TV, so it no longer blinks when plugged in? It seems to be stuck in an endless loop. Unplugging and waiting doesn't work for me.
                                      • nomoresonys
                                        • 12306
                                        • U.S.
                                        #39
                                        Mainboard there for 20 bucks BUT untested. https://www.ebay.com/itm/Samsung-LN4...frcectupt=true
                                        • samsonite
                                          • Jul 2015
                                          • 46
                                          It's tempting to buy another board, but I've already invested some money into this project.
                                          But, if I were to buy one, it would have to be a 100% working board. Not a repaired or salvaged board. It would have to be a board with new parts that have been replaced. Some people advertise repaired or salvaged boards as "refurbished", without replacing a single part. I already have an old board with old parts, I don't need another one.
                                          BTW, the Ebay pic of the backside of the board, it looks like c102 has been replaced with a banana colored capacitor. But, since they say "not working", maybe it was a failed attempt.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                            • Have read ALL applicable threads
                                            • C1818 and CP820 replaced as low hanging fruit
                                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                            09-07-2024, 05:50 AM
