Sasmung la40m81bd - Recapped
  • Amraks
    • Nov 2011
    • 725
    History:
    PSU only recapped.
    This TV was not turning on a few weeks ago I then recapped it as I recall I swapped all capacitors except a 163v 1uf as I didn't have this value.
    A few weeks pass.
    The TV now is coming back to me with with a picture fault.
    https://youtu.be/sYJE7VpX4yE
    Any idea what may cause this? could it be that 163v 1uf I didn't recap?
    Just want this customer to have their tv back as I have their other one at the moment as well.
  • Hamie
    • Apr 2014
    • 1383
    Re: Sasmung la40m81bd - Recapped
    Try heating the main board metal shield. If the picture comes back then it's probably the 2 x 1000uf caps under the tin work.
    • Amraks
      • Nov 2011
      • 725
      They where replaced though with new ones. forget which brand I used for them.
      Ill check their ESR when it comes back.
      Any idea what the 1uf 163v would do?
      • Amraks
        • Nov 2011
        • 725
        Oh Oops just noticed you meant the mainboard I originally recapped the PSU board.
        • drussell
          • Nov 2014
          • 144
          Just a quick aside... There is no such thing as a 163 volt capacitor rating. 63? Yes. 100? Sure. 150 or 200? Yup...
          Even 160 and 165 are something that (while rare), do actually exist but I've never seen a 163 volt capacitor.
          • Amraks
            • Nov 2011
            • 725
            its a 160v not sure how I got 163v.
            I can not see how it could be a cap on the mainboard as they are smd
              • 12129
              • U.S.
              Video resembles a tcon problem?
              • Amraks
                • Nov 2011
                • 725
                Heres a better video now I have the tv in my hands.
                https://youtu.be/d3zCpfB23Sg
                  What do you mean by ' how it could be a cap on the main board as they are SMD'? SMD is just a form factor, so if it is SMD lytics cap then they can still fail just like other lytics caps.
                  • Amraks
                    • Nov 2011
                    • 725
                    I thought they where rare to fail budm.
                      • 12129
                      • U.S.
                      Try heating things with a hairdryer on the mainboard and tcon, see if picture changes and maybe the one ribbon at a time tcon check.
                      • Amraks
                        • Nov 2011
                        • 725
                        I checked both sides of the tcon left and right, left side pulled was white with right side still showing this defect.
                        right side pulled was the same as well but opposite.
                        heated up around the main-board and tcon the problem doesn't go away.
                          • 12129
                          • U.S.
                          Check the capacitors on the tcon for shorts, tv unplugged, meter in diode mode.
                          • Amraks
                            • Nov 2011
                            • 725
                            checked all caps for shorts on the tcon board couldn't find any shorted
                            • Amraks
                              • Nov 2011
                              • 725
                              I replaced that cap on psu that I didn't have before problem is still there.
                                • 12129
                                • U.S.
                                Maybe test the voltage regulators on mainboard, tutorial if needed in budm's signature post #9.
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  I believe you removed the video.
                                  I'm just going to give my 2 cents nonetheless by saying it's probably a T-con issue since you're saying both sides of the screen display the same. Ideally, you'd have a second main board/T-con to compare how each performs.
                                  Do some measurements on the t-con board: there should be test points labeled VCC, 1.2v, VGH, VGL, etc. Really curious to see how this telly gets fixed
                                  Wattevah...
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    Here is a photo of the tcon all the VCC lines seem to match their values I can't find vgh or vgl
                                      How about AVDD, AVDD_1, VDD around the left side of the board around IC8?
                                      You can also look up the spec sheet of that IC8 TPS65160A to see how many output Voltage sources it has.
                                      • Amraks
                                        • Nov 2011
                                        • 725
                                        Some more photos
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
