Sasmung la40m81bd - Recapped
+ More Options
Posts
  • Amraks
    • Nov 2011
    • 725
    Re: Sasmung la40m81bd - Recapped
    Chip I flashed is IC1803 is a 24C256
    No flashed firmware after the erase as the tv writes to the chip when blank chip is detected
    Can get into service menu but its very hard to navigate being the picture is the way it is.
    • nomoresonys
      • 12094
      • U.S.
      #62
      That chip costs 1 dollar, I'd replace it with a new one, that will at least confirm or eliminate it as a suspect.
      • Amraks
        • Nov 2011
        • 725
        yeah I have ordered 5 of them, seems weird that I have the off/on clicking fault now after erasing that chip.
        chip sectors could be bad and its writing on the corrupt chip sectors creating incorrect settings for panel and the watchdog is now kicking in as it should be.
        • Amraks
          • Nov 2011
          • 725
          Tried a new chip not fixing any fault
          2 of these caps under the metal shield
          44080
          82
          6FA
          One reads higher than the other of the same value on my esr meter
          .16ohms
          .04ohms
          Could this be my problem?
          • Amraks
            • Nov 2011
            • 725
            Also found some of these caps on the mainboard are reading funny
            100
            16J
            Which look to be the JC series in Samwha
            some are reading
            1.0ohms
            .90ohms
            .09ohms
            there is a few of these caps all over the board it seems like the lowest readings are the rarest ones
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4286
              • Italy - Milan
              #66
              Hi, i don't like the suggestions done here in this thread..
              the video shows evidently a corruption in firmware data, the part on the flash chip or the data copied into the RAM, so best way to do for me is to begin with cap replacing, for the 3,3v that feeds the Flash 29AL032 are C1110,C1177, for the DDR 2,5v is the C1149, since before or after but very often fails also C1165,C1167 change also them. I don't know what it is HYB25D256 chip, seems another flash chip, anyway if the cap replacement doesn't work then a reflashing of the firmware (NOT THE EEPROM!!) is suitable but the file is unavailable.
              • Amraks
                • Nov 2011
                • 725
                Ok I replaced them caps you have mentioned also took the liberty of replacing C2267 and C1140
                this has made a bit of difference in the picture I can recognise some text in menus but it seems a little flashy still.
                • Amraks
                  • Nov 2011
                  • 725
                  Here is a new video
                  I have bought up some menus also I never switched it off, it did this by itself.
                  https://www.youtube.com/watch?v=WgGf9TVDFj4
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4286
                    • Italy - Milan
                    #69
                    ok maybe some caps are still bad on the mainboard, or there's a problem in the video RAM, for the shutting off then on surely the job done on eeprom is not a good thing, it must be placed back the original eeprom with original content, or right to try, delete the actual eeprom maybe with the short on pins 5,6 during the mains plug connection (stay so for 10 seconds), then shut off then on.. another common fault in theese boards is the soldering if i remember on the ST CPU.. if i'm right the ST governs the DTV (terrest. digit. tv). Try to warm it up for 30 secs at high temp, at least 300 °C, then try the tv, if its better then do a reflow.
                    • Amraks
                      • Nov 2011
                      • 725
                      Not sure what's going on with that could still be processing video.
                      Try again soon.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4286
                        • Italy - Milan
                        #71
                        What do you mean?? Try what? I think the most probable culprit is the ST chip and its solderings, the things are strictly related, PSU and Mainb. caps generate high ripple that causes the ST chip to get too hot then solder balls detaches itself.
                        • Amraks
                          • Nov 2011
                          • 725
                          C2267 and C1140 there is a short to ground on these two caps hmmmm
                          • Amraks
                            • Nov 2011
                            • 725
                            its weird its only doing it after board has been on
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4286
                              • Italy - Milan
                              #74
                              How do you measure this? first you have to measure in volt to be sure to not damage the tester, then you can measure in ohm with caution..
                              • nomoresonys
                                • 12094
                                • U.S.
                                #75
                                WRONG, when these eeproms are replaced they use new blank chips.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4286
                                  • Italy - Milan
                                  #76
                                  I reorder things, i remembered bad, then the chip erasing it's been already done, but what it's been done after? 'Cause the tv usually needs an initialisazion, it's been made it ('cause before cap replacing the characters of the OSD was no readable)? So the chip has not been changed and the original content is lost.. now that characters are visible a little a service menu reset must be made, with TV initialisation after..
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    I have gave up on this tv only solution would be a mainboard.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4286
                                      • Italy - Milan
                                      #78
                                      ok i've learned a thing, never put much effort in a forum!...
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        #79
                                        Your effort is much appreciated, as it can be useful to others out there
                                        Wattevah...
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #80
                                          maybe search you local free adds etc or ebay for a cracked screen set if you cant find a replacement mainboard cheap enough.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
