Hi guys
I have this Panasonic TX-L50BL6E here
The original problem was blown backlight LEDs and a short circuit power FET on the backlight driver PCB
I've replaced the whole set of LED strips and the short circuit power FET. The set now powers up but is has another problem
When first powered up I get an image with the wrong aspect ration (too narrow and too high to fit the screen). Also on the left hand side of the screen there are regular spaced black horizontal lines that fade away towards the centre of the screen. The right side of the screen looks fine. These can be intermittend, the black lines flickering in and out.
I can see the same horizontal lines on the onscreen menu and HDMI 1 message block before the image from the video source appears.
Then after 5-10 seconds or so the picture disappears and I have a mainly purple screen with vertical lines, but no horizontal lines. This stays on screen until I power off and back on again, in which case the same sequence occurs
What is likely to be causing this problem?
best regards
Rich
best regards
Rich
