LG42CS570 Screen Acts Like It Needs To Warm Up
  • nomoresonys
    • 12274
    • U.S.
    Re: LG42CS570 Screen Acts Like It Needs To Warm Up
    Example, different brand but same general idea. https://www.youtube.com/watch?v=vCExlSnG4yY
    • nomoresonys
      • 12274
      • U.S.
      Also have seen this symptom where the backlights were the problem, could be bad or loose connection too, tapping tv changes picture that is.
      • nomoresonys
        • 12274
        • U.S.
        https://www.youtube.com/watch?v=waBbLXwqqWQ
        • nomoresonys
          • 12274
          • U.S.
          Looks like you only have to get to the scandrive boards, this is an lg, isn't your exact model. then apply a little pressure to tabs to see which one it is. https://www.youtube.com/watch?v=s4wNc3hF4JI
          • CloakedWarrior
            • Nov 2018
            • 22
            Thank you for your time you have put in to trying to help me. I tore it down all the way to the tabs cannot seem to find an exact fault in one particularly so I put a piece of black electric tape over the humps built into the frame over the TABS thinking maybe they were getting to cold because of possibly resting on the metal frame??? Idk i'm so confused at this point lol.
            Most of the issues I have seen are lines and problems that are vertical. My screen is in half horizontally. It has a full picture from one end to the other across the top only about 1 inch wide to start, then as time passes it will go from 1 to 3 inches and just before it reaches the half way point it starts glitching the entire bottom of the screen as if something is warming up and starting to work properly as it starts the glitching I can start tapping on the top of the Tv and sometimes it effects it and sometimes not.
            • CloakedWarrior
              • Nov 2018
              • 22
              Update : No type of shimming seems to work. I watched a few videos on others doing the same thing but no luck and cannot seem to get any effect out of even messing with the boards or drivers.
              • nomoresonys
                • 12274
                • U.S.
                #27
                Maybe test the voltage regulators on the mainboard, I might be tempted to try and find a decent priced mainboard.
                • nomoresonys
                  • 12274
                  • U.S.
                  #28
                  Ran across this while searching google, don't know anything about them tho, was cheapest by far, could also be a dud, who knows. https://www.shoppinder.com/trends/cs-570
                  • CloakedWarrior
                    • Nov 2018
                    • 22
                    I made a video of the symptoms from start to finish if you'd care to check it out.
                    https://youtu.be/61u_ITd4U4E
                    • CloakedWarrior
                      • Nov 2018
                      • 22
                      I might try the main board. I tried the baking method with no results.
                      • nomoresonys
                        • 12274
                        • U.S.
                        #31
                        Dam if that don't still look like a tcon issue?
                        • nomoresonys
                          • 12274
                          • U.S.
                          #32
                          Wonder if your lvds/tcon cable could be faulty?
                          • nomoresonys
                            • 12274
                            • U.S.
                            #33
                            Thought I saw some utube videos that showed how to determine if it was a mainboard or panel issue.
                            • nomoresonys
                              • 12274
                              • U.S.
                              #34
                              According to this site, theres like 10 substitute parts that will also work, did some searching, still seemed hard to locate one for a decent price. https://tvpartsforsale.com/product/l...04-main-board/
                              • TeeEeeKay
                                • Sep 2015
                                • 10
                                How about trying to heat up different boards (or parts of the boards) with a hair dryer to see if you can narrow down or confirm the bad part / board?
                                If you heat a section up, power it on and it works right away - bingo!
                                • CloakedWarrior
                                  • Nov 2018
                                  • 22
                                  I have tried heating up different boards with no success to affect it in anyway other than right about the 30 minute mark of it warming up I can tap on the top of the frame mainly the corners and it will jolt and seem like it effects the picture to some degree.
                                  I checked the voltage from the power board pins going to the main board and all seemed to be within range of the schematic on the board. I preformed the check at first on and when operating properly to see if there was a change I noticed nothing which leads me to presume the power board has no fault.
                                  I am not certain as how to check the main board or tcon properly. Any tips would be lovely lol.
                                  • CloakedWarrior
                                    • Nov 2018
                                    • 22
                                    How would I find out how much voltage is supposed to be going through the lines from the main board to the t-con? And the voltage from t-con to tab driver boards?
                                    • nomoresonys
                                      • 12274
                                      • U.S.
                                      #38
                                      I'd test the tcon, not sure what voltages you should get but it would be nice to eliminate it from the suspects.
                                      • nomoresonys
                                        • 12274
                                        • U.S.
                                        #39
                                        You have 2 tcons, you could see if you get the same voltages on both.
                                          Video @3:13 looks like bad panel issue.
                                          You need to test Voltages on the T-CON board test points, I.E. VGH, VGL, VDD, etc.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • smic717394
                                            by smic717394
                                            07-25-2024, 10:16 AM
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
