Megmeet MIP390HW power supply problem
  • cheeky2
    • Dec 2012
    • 337
    I have this Megmeet MIP390HW power supply which had some blown components after a mosfet shorted out. I have replaced the blown resistors R40, R41, R42, R26, R32 and the mosfet Q4. The main fuse T5A was also replaced.
    However I cannot seem to find a schematic for this power supply to identify U1 which I believe is blown as a result of the resistors vaporising together with the mosfet.
    I have attached a close up of a working psu together with the blown board before replacing components.
    I don't have any standby 5V which I suspect is down to U1. So any help with identifying the IC U1 or schematic for this Megmeet MIP390HW from a Technika 39C273 tv would be great.
    Re: Megmeet MIP390HW power supply problem
    It nay be NCP1250.
    Looking at your board lay out, the connections of the IC's pins seem to match with NCP1250.
    1 = gnd
    4 = CS
    5 = VCC
    6 = Gate drive
    BTW, it also matches FAN6862-D, SG6858.
    • R_J
      • 9588
      Another one might be a OB2262, any numbers on the ic of the working power supply ?
      • cheeky2
        • Dec 2012
        • 337
        Great thanks for the input.
        I took the pictures of the working psu before the TV was sold. Thinking about it I could get the microscope out and examine the old one to see if I can get some numbers off it. It appears to have lacquer over it which might make it a little tricky to determine what it is. Any thoughts as to an easy removal of the lacquer without damaging the information on the ic?
        I will keep you updated on how it goes with pictures...
        • cheeky2
          • Dec 2012
          • 337
          Ok here are the pictures of the ic! It doesn't look to be any of the suspected ics as it is marked KvP amongst other things. Over pin 5 it looks like part of the ic has blown a small hole in it which is where R26 and R32 were open circuit.
          I am now trying to identify this ic picture attached.
          I removed the lacquer with white spirit, my finger nail, toothbrush and cleaned up with isopropanol.
          I didn't have any success with KvP but as soon as I searched for 37R came up trumps.
          Datasheet attached.
          Now off to order it
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • nubie
            Rosewill Tokamak 1200w blown mosfet 5R199P
            by nubie
            Rosewill 1200w blown APFC? Mosfet.
            I got this with a blown fuse. Replaced fuse and the APFC mosfet blew.
            Removed the mosfet and got 5VSB, then when I connected PWON to ground the Fuse blew again.
            So do I need to replace the mosfet? Or should I be looking elsewhere? Thanks.
            According to a review of the 1500w unit there is an option for 4 transistors instead of 3 and they are different: https://www.tomshardware.com/reviews...su,4823-3.html
            07-02-2024, 05:33 PM
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
