Sharp LC46D64U Power and OPC Flash
  • Icitte
    • Aug 2011
    • 61
    Hi guys
    I am working on this unit for a couple of weeks and now I need your help!
    So when I plug it nothing happen but the green power light blink at 1 sec.
    When I plug the TV while holding Vol- and Input nothing happen BUT power light blink twice and OPC blink once.
    So in the manual this mean: PS_ON DET_10V failure ''DET_10V (pin 57). UR10V or A9V is not applied.
    If error is detected during operation, the power is turned on
    again by interrupt handling (instantaneous blackout processing).''
    I just istalled the Shopjimmy kit (https://www.shopjimmy.com/sharp-rden...repair-kit.htm) but nothing change
    I tested the voltage at the connector from the P/S board that goes to the Main Board
    Here's the result:
    LNB - NO WIRE
    LNB_POW - NO WIRE
    LNB_CONT - NO WORE
    PS_ON - 0V
    AC_DET - 3V
    PNL_POW - 0V
    SGND - 0V
    BU5V - 5V
    SGND - 0V
    SGND - 0V
    UR15V - 0V
    UR15V - 0V
    Could you help me?
    Another question, how can I know which pin too test the huge transformer? thanks
    Re: Sharp LC46D64U Power and OPC Flash
    Here's the result:
    LNB - NO WIRE
    LNB_POW - NO WIRE
    LNB_CONT - NO WORE
    PS_ON - 0V
    AC_DET - 3V
    PNL_POW - 0V
    SGND - 0V
    BU5V - 0V
    SGND - 0V
    SGND - 0V
    UR15V - 0V
    UR15V - 0V
    Are you 100% sure that you count the pins and measure those Voltages correctly? Your report shows ZERO Volt for the standby power supply to run the main board, so no Standby Voltage then there will be any Voltage to run the main board to produce any error codes or to light up any Indicators. Recheck your measurement again.
    • neilc6
      • Nov 2015
      • 1550
      So how many times does the Power LED blink and how many times does the OPC LED blink. It is confusing but you need to count them separately since they may flash together.
      Service manual here
      • Icitte
        • Aug 2011
        • 61
        You are right, I made an error, just edit the post, BU5V is 5V
        Originally posted by budm
        Here's the result:
        LNB - NO WIRE
        LNB_POW - NO WIRE
        LNB_CONT - NO WORE
        PS_ON - 0V
        AC_DET - 3V
        PNL_POW - 0V
        SGND - 0V
        BU5V - 0V
        SGND - 0V
        SGND - 0V
        UR15V - 0V
        UR15V - 0V
        • Icitte
          • Aug 2011
          • 61
          Service manual here
          • Icitte
            • Aug 2011
            • 61
            Anyone have a clue for me?
            • Icitte
              • Aug 2011
              • 61
              I really need your help guys!
                • 12225
                • U.S.
                I would try a software update/reapply as described in the service manual provided by neilc6 in post #3, chapter 5 of the manual.
                • budwich
                  • Jul 2015
                  • 3097
                  I "played" with one of these for a friend. Ultimately, he replaced the main board although his symptoms were different (only over the air worked). As suggested, try a software reload / update from usb. Actually, iirc, you don't even need anything "great" on the usb other than it being formatted (fat16/fat as opposed to fat32... which everywhere seem to suggested... fat32 didn't work). Anyways, IF the set powers up with the usb in, it will attempt to do the software update, asking before proceeding. IF this occurs, you will at least know that the "boot" / "upgrade ware" is working on the board. IF not (nothing happens with the set), then you likely have a main or powering problem.
                  One question, what is the history of the set and problem?
                  Further: I am not sure you are interpreting the flash codes correctly... if the codes are correct then my "read" is you have DET_D3V3 fault.
                    https://elektrotanya.com/showresult?...oria=&kat2=all
                    Service manual for 42, 46, 52":
                    It does not show error code chart in this manual, and I do not know for sure if 32/37 codes are valid for 46INCH or not.
                    32 & 37 inch: Power LED twice + OPC once = PS-ON, DET_15V failure.
                    • Icitte
                      • Aug 2011
                      • 61
                      I tried the upgrade firmware but the TV doesn'T even try to open....it blink power at 1 sec
                      Its strange how I get 1 sec power light blink when I just plug the power and 2 blink/sec power light and 1 blink OPC light when I plug it while pressing VOL - and INPUT at the same time!
                      • Icitte
                        • Aug 2011
                        • 61
                        ok so I open plugged the TV with CH- and VOL+ at the same time to reset the blink once I got when I was just plugging the tv
                        So now when I plug it I got the 2 blink power light and 1 blink OPC
                        so here's what is in the manual:
                        https://www.dropbox.com/s/pjqps0alh2...anual.jpg?dl=0
                          I do not know if the code for the 32, and 37 is applied to 46 inch or not. See post 10.
                          • Icitte
                            • Aug 2011
                            • 61
                            I have the 46 manual
                            so the image is good for me
                            • budwich
                              • Jul 2015
                              • 3097
                              Originally posted by budwich
                              I "played" with one of these for a friend. Ultimately, he replaced the main board although his symptoms....
                              oops... I misread the number of flashes you posted.
                              It would appear to be a "det_10v" failure.
                              but... can you provide a history of the set?
                                Can you please provide the link to the one you have since the one from ELEKTROTANYA does not show error code?
                                • Icitte
                                  • Aug 2011
                                  • 61
                                  here we go!
                                  https://www.dropbox.com/s/khu7oealtn...2d64u.pdf?dl=0
                                    Thanks!
                                    • R_J
                                      • 9580
                                      I have the manual with the error codes but its larger than the sites 19.07 MB limit
                                      • R_J
                                        • 9580
                                        Here it is, Error codes on page 62
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • ekozeko333
                                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                          by ekozeko333
                                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                          🔥 The Problem Started After Suspected ESD/PD Fault
                                          I experienced a power issue or ESD event through a USB-C charger
                                          After that, the NX20P5090 power switch was visibly burned and was replaced
                                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • yucel-yucel
                                          Sharp LC-39LE652V Nand Flash
                                          by yucel-yucel
                                          Sharp LC-39LE652V model device could not be opened due to nand software error, we rewrote the nand software and it worked. But we were able to find the software without satellite, it does not see the internal satellite. Does this model have a working satellite version and software? Thanks in advance.
                                          Model ; Sharp LC-39LE652V
                                          Panel ; V390HK1-LE6
                                          Mainboard ; QPWBXG135WJZZ
                                          04-06-2023, 04:57 AM
                                        • spmetroil
                                          Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                                          by spmetroil
                                          I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                                          The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                                          I have a CH341A programmer and I already attempted the following steps:
                                          1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                                          2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                                          3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                                          08-19-2025, 09:23 AM
