Find replacement resistor
  • magneh
    • Apr 2014
    • 625
    • Portugal
    Hi there!
    I know this can seem to be a stupid question, but how do I find a replacement for this resistor of a TV power supply?
    If I check the band resistor colour code, It's 1 ohm, but on the schematic its marked as 3.3R
    Anyone can clarify ?
    Thanks!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Find replacement resistor
    There are no stupid questions on this forum What are the coloured bands on your resistor??
    • CapLeaker
      Leaking Member
      • 8352
      the sanken pdf for the IC sez for that resistor to be 1.5 Ohm 1/2Watt in their test circuit.
      • magneh
        • Apr 2014
        • 625
        • Portugal
        Hi there!
        Well, I know that the resistor coloured bands should mean 1 ohm resistor...
        Not sure about the wattage...
        Thanks!
        • magneh
          • Apr 2014
          • 625
          • Portugal
          Ok, interesting.
          If I check the coloured bands I get 1 Ohm resistance as value
          Feel kinda tempted to get an 1 Ohm resistor 1/2 watt ...
          Worst case scenario, Ill watch it burn when I turn it on
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Yes, I would go for the 1/2W resistor also.
              That Source resistor for the Internal MOSFET of the SMPS IC will go open circuit if the MOSFET shorted out. Is that resistor tested open circuit?
              • magneh
                • Apr 2014
                • 625
                • Portugal
                Thanks for the inputs
                The resistor is shorted and clearly burned underneath it.
                I will go for the 1/2W 1 ohm ... most likely
                Cheers!
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  The resistor would be open and not shorted. The reading would be infinity or increased.
                  • R_J
                    • 9625
                    I agree with Andrew, The resistor is ok, and the board is likely discolored do to heat from the resistor. hard to tell without a picture.
                    • magneh
                      • Apr 2014
                      • 625
                      • Portugal
                      Hi there!
                      Finally had time to take a look again at the resistor.
                      You guys are totally right, the resistance is OPEN not shorted
                      Some pics attached.
                      Should I definitely go with a 1 Ohm 1/2W?
                      Ty all!
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        As Budm says in Post #7 there's every possibility that the IC is damaged and replacing the resistor without checking out the IC may just result in it burning out again. Check the mosfet with the meter in diode mode between Source/Drain (Pins 1 and 8) reversing your leads for the second measurement. Set OFF.
                          I would replace that IC.
                          • redwire
                            • 3912
                            +1 the IC is shorted, replace it first. Otherwise a new resistor will just burn up.
                            It should be a flame-proof, fusible-type resistor to prevent fire.
                            • magneh
                              • Apr 2014
                              • 625
                              • Portugal
                              Thanks for all the inputs!
                              Yes, I forgot to mention that the IC was also burned and replaced.
                              Only thing missing is to find a correct replacement for that resistor.
                              Fusible type resistor, 1 Ohm, 1/2W this is what Im going for
                              Why do they put 3.3R in the schematic for this resistor? any idea?
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                Could be an update on the board design. 3.3ohm maybe an original design flaw that was never updated.
                                • SLK001
                                  • May 2014
                                  • 264
                                  It looks like a 1.5 ohm resistor to me. The second band looks green, not black. However, it could be how colors show up here - you decide which it is.
                                    Looks like 1 Ohm.
                                    You can use MOX (Flame proof Metal Oxide) non inductive.
                                    Measure the dimension to get rough idea what the wattage is.
                                    • jeeptechfred
                                      • Oct 2018
                                      https://www.digikey.com/product-deta...69H-ND/3661844
                                      the IC is cheap and available
