Hitachi lcd tv L42VK04U not staying on
  • thuss
    • Jul 2012
    • 321
    Hi
    I am trying to repair this tv for my neighbour .
    The red standby light is on.
    I switch the tv on and the standby light flashes blue and backlights flash for a couple of seconds and then turn off.
    Then the standby light justs cycles between red and blue.
    The power supply is a vestel 17PW26-5 v.3.
    The main board is a 17MB65-2.
    I have replaced the inveter board and it does the same. Ive disconnected the inverter board but still the same.
    On the power supply the white connecter top right hand corner I get the following voltages
    Starting at the top with column on the left hand side
    readings are
    standby voltages /on voltages
    0 / 0
    7.86 / 8.97
    2.57 /0
    0.36
    0 /3.57
    11.86
    5.03
    3.39
    0 /3.39
    0 /3.39
    0 /3.39
    0
    0.23
    0.23
    Power supply top right column nearest to main board
    standyby voltage / on voltage
    0
    0
    0
    0
    0.11
    11.85
    3.39
    0 /5.15
    0.24
    0.24
    0.1
    0.28
    0 /3.15
    I have checked some of the caps on a meter and they are fine theres no leaks
    Any pointers would be really appreciated -
  • CapLeaker
    Leaking Member
    • 8352
    Re: Hitachi lcd tv L42VK04U not staying on
    check the connector that goes to the inverter. looks like you don't have any 24V for the inverter on the PSU. First check the voltage on the main filter capacitor, in order to see if the PFC is running or not. If the PFC is running, check the rectifying diodes on the output section of the 24V rail.
    • thuss
      • Jul 2012
      • 321
      Thanks- forgot to mention I am getting 24v from the top left connector block on the psu- on the inverter board fuse there is 24v. Ive checked the diodes they seem fine.
      I will check the main filter cap
      • CapLeaker
        Leaking Member
        • 8352
        Do the backlights come on at all?
        • thuss
          • Jul 2012
          • 321
          Hi yes the back lights do come on for about 2 seconds.
          Ive checked the fan chip seems fine high ohms,the smd caps surrounding the fan chip seem fine no shorts.
          • CapLeaker
            Leaking Member
            • 8352
            compare the secondary windings on each HV transformer for the backlights. They have to be in line withing 3% of each other.
              Can we see the pcitures of the Inverter board without the metal shield?
              What Voltages do you get on the connector of Inverter board that goes to the power supply board? Pin names for those pins?
              • thuss
                • Jul 2012
                • 321
                As req With ref to the new attached photo of the connection wires that go from the psu to the inverter board.
                Ive started with the green wire as number 1. (standby/ on voltage)
                1 green wire on psu (standby /on voltages)- 0.6v/0
                2 Pink wire 0/3.38
                5 Brown wire 0/0
                6 Brown wire 0/0
                7 Brown wire 0/0
                9 white wire 0.2/24
                10 white wire 0.2/24
                11 white wire 0.2/24
                12 white wire 0.2/24
                Ive have tried two inverter boards- still the same results
                • R_J
                  • 9632
                  Try disconnecting one of the lamps from the inverter and see if the backlight still comes on for 2 sec. Then reconnect that lamp and disconnect the other lamp and try again. There may be a faulty ccfl
                  • thuss
                    • Jul 2012
                    • 321
                    before I remove the lcd screen to get at the tubes- shouldn't the PSu have a constant 24v on the connector block from the main board.
                    • CapLeaker
                      Leaking Member
                      • 8352
                      check these transformers first, before you take stuff apart.
                        #1 green wire on psu (standby /on voltages)- 0.6v/0
                        #2 Pink wire 0/3.38
                        One of those two wire should be for BL-ON, another one will be for Dim control.'
                        The Voltage on #1 looks to be too low, you should keep the meter on that pin ten turn the TV on to see if it jumps up over 0.6V and then drops own to 0V or not, then try disconnecting just that wire #1 from the inverter board and see what Voltage you will get on that pin of the inverter board when you turn on the TV.
                        • thuss
                          • Jul 2012
                          • 321
                          2 Pink wire 0/3.38
                          5 Brown wire 0/0
                          6 Brown wire 0/0
                          7 Brown wire 0/0
                          9 white wire 0.2/24
                          My mistake the green wire has on standby 0.6v but today switched the TV on backlights came on for two seconds and the voltage went to 3.36v and then dropped
                          Cut the green wire same result as above just no backlights flash forgot to mention transformers seem fine
                          • thuss
                            • Jul 2012
                            • 321
                            It's definitely the psu I repaired a 17pw26-5 (one main white plug)out of a toshiba that was lying about and the tv fires up fine- but not with the 17pw26-5(black and white plug)
                              The control signals for the inverter are generated by the main board, they are just routed through the power supply board for neat wiring.
                              • thuss
                                • Jul 2012
                                • 321
                                Just sourced another psu worked straight - couldn't work out what was wrong with original psu
                                • Thierry Wolffenbuttel
                                  Ps5 with bad standby voltages
                                  by Thierry Wolffenbuttel
                                  I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                                  04-08-2024, 08:04 AM
                                • Crystaleyes
                                  iMac A1224 PSU, 614-0421 - no standby voltages
                                  by Crystaleyes
                                  Hi chaps.
                                  Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                                  I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                                  Anyway, this PSU in question had already had someone having a pop at soldering.
                                  The current problem is (at the very least) in the primary side.
                                  Fuse is ok
                                  MOV is ok
                                  NTC is ok
                                  Bridge rectifier is ok (~380vDC)
                                  Fat filter cap is ok
                                  10-11-2021, 05:07 PM
                                • Capacitorial
                                  Powersupply has all the voltages - Monitor still no power
                                  by Capacitorial
                                  Hello guys,
                                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                  The weird thing is, that the Power LED is powered over the TCON board.
                                  On The TCON...
                                  12-28-2024, 02:12 PM
                                • zwerw3
                                  la-g07jp no standby voltages
                                  by zwerw3
                                  Hello. Please help. la-g07jp rev1.0 does not turn on. The 3 and 5 volt alarm goes up for 2 seconds and goes out. I opened the 3 and 5 volt power jumpers, removed the pu302, flashed the multimcontroller with different firmware, nothing helped. I noticed that on the u4104 the output is 1.5V, this voltage goes to the combined processor. Should there be such tension there?
                                  05-06-2024, 01:01 AM
                                • Jack828
                                  Hitachi 42HXT12U - Not working - Standby LED Flashes
                                  by Jack828
                                  Hello fellow tech geeks!
                                  I've recently come into possession (a freebie!) of a Hitachi 42HXT12U LED TV which does not work.
                                  It does the following:
                                  - Plug in
                                  - Standby LED flashes alternating RED and BLUE approx 6-7 times
                                  - Does this approx twice
                                  - Standby LED stays solid BLUE
                                  I've opened it up and had a look at the PSU board (which is a 17IPS20 23145828) for any bulging caps and there aren't any.
                                  Any ideas folks? If you suggest replacing the PSU board then I'll go ahead and do it - only about 30 quid off...
                                  12-13-2020, 09:14 AM
