Sharp 70" First Failure Post Side-Tab Removal ?
  • mmartell
    • Oct 2013
    • 3189
    My LC-70LE650U has developed an issue which looks to me like panel failure. Has not been taken down from the wall yet.
    Until it is, what do you think ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp 70" First Failure Post Side-Tab Removal ?
    Other times it looks normal except for the dark band across the bottom of the screen. The band goes edge to edge.
    • budwich
      • Jul 2015
      • 3097
      that is quite significant... it looks like the last remaining tab failed.... :-(
      • geeforce
        • Oct 2017
        • 87
        Do you think adding any heatsink or anything would help remaining tabs survivability?
        • budwich
          • Jul 2015
          • 3097
          I think some on the forum have put some form of flexible heat padding on them. I would be concerned that playing with them more than you have to is a risk... potentially more than heat itself. Based on the numbers of posts in this forum, it would appear that the "mortality" of the tabs is kind of like... first failure rate has been reached, after that second and third, is already "baked in" so to speak.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4540
            • Italy - Milan
            Trash it... anyway how long it lasted?
            • mmartell
              • Oct 2013
              • 3189
              I think it's been just short of three years since original reapair.
              • mmartell
                • Oct 2013
                • 3189
                Here's the diagnosis... COF failure second from bottom. Already pulled them from the other side so this one is toast.
                Lasted a few months short of three years.
                (pics in next post)
                • mmartell
                  • Oct 2013
                  • 3189
                  I tried making a thermal pad sandwich and reinstalling the metal bar but it did not make a difference as the chip appears roasted. You can see the pad in one of the pics, the other was on the underside of the bar.
                    No doubt it's dead...wonder why Sharp's larger panels are so prone to this failure. It seems like a design defect.
                    Maybe the lesson here is to peel off ONLY the failed tab so you have more chances if the issue occurs again.
                    There may also be a reason to look at seeing if the VGH and VGL voltages can be adjusted, e.g. by adding some extra load to them. It may decrease power dissipation in the drivers, and increase the lifespan. VGH or VGL too low will however cause picture defects so it may be a fine balance.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4540
                      • Italy - Milan
                      Ehm.. i noticed you're from Canada, i know there is an enterprise there called LCD Masters that changes the flat cables..
                      • angelos
                        • Dec 2012
                        • 573
                        • South Africa
                        Aren't there tab bonding machines in the US where you can have this panel repaired?
                        • mmartell
                          • Oct 2013
                          • 3189
                          Considering I bought it for $100 and had it almost three years doesn't interest me much to try to find someone to attempt a tab bonding repair but I'll look into it anyway. I'm sure it's cost prohibitive considering similar tv's can be had for cheap only in need of backlight repair.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4540
                            • Italy - Milan
                            I don't know how much costs there for a similar working tv, but i always consider if a tv worth 400$ and a repair 380$ if the repair is guaranteed it worths the pain.. this for non repairer users..
                            • mmartell
                              • Oct 2013
                              • 3189
                              Do they have access to the tab/cof ? Otherwise it's a non-starter and only useful where the tab joint has lifted partially or wholly.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4540
                                • Italy - Milan
                                They change the tab with a new one, check his Youtube videos..
                                • angelos
                                  • Dec 2012
                                  • 573
                                  • South Africa
                                  Davi, can you send me the youtube link?
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Ok I called LCD Masters in Toronto (4 hour trip by car each way) and was given a price of $500cdn. I told him I already ripped off the tabs from one side and he said they only replace what's necessary to get the picture restored so presumably the single tab/cof that just burnt up in my case.
                                    Not worth it for me.
                                      I wanna know who is spending $500 to fix a TV when you can buy a new 70" 4K TV for $900. I understand it's a precision job but that is just not economical in the slightest.
                                      • jetadm123
                                        • 2169
                                        $500 and 8-hour round trip? Are they planning to work on it while you wait? Not worth it for a TV over 3 years old. Strip the boards and sell them and apply that money towards a new TV.
                                        • npielawski
                                          MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                          by npielawski
                                          I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                          I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                          10-15-2025, 01:53 AM
                                        • mmx01
                                          HP Z2 G5 Twr BIOS password removal failure
                                          by mmx01
                                          The machine was/is password locked for BIOS. You can imagine I am writing here because things did not go as planned... I downloaded and edited both main bios and EC rom flash chips with 866II+ programmer using RCUnlocker for EC and BIOS patcher for BIOS. Verification goes ok for all files but now the computer is not even turning on.
                                          When I press power on, white LED goes on but as soon as I release the power button it goes back to sleep. No beeps or other sings of life. Soldering of both chips is verified with continuity test, all is connected okay. Both chips were...
                                          11-17-2025, 04:02 PM
                                        • TimScrawn
                                          MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
                                          by TimScrawn
                                          Hi there,
                                          This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
                                          I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
                                          06-23-2024, 09:41 AM
                                        • puccovelli
                                          Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                                          by puccovelli
                                          Hi all, I hope this is the right place to post.
                                          I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                                          I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                                          1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                                          2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                                          10-11-2025, 06:30 AM
