Sharp 70" First Failure Post Side-Tab Removal ?
  • mmartell
    • Oct 2013
    • 3189
    My LC-70LE650U has developed an issue which looks to me like panel failure. Has not been taken down from the wall yet.
    Until it is, what do you think ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp 70" First Failure Post Side-Tab Removal ?
    Other times it looks normal except for the dark band across the bottom of the screen. The band goes edge to edge.
    • budwich
      • Jul 2015
      • 3097
      that is quite significant... it looks like the last remaining tab failed.... :-(
      • geeforce
        • Oct 2017
        • 87
        Do you think adding any heatsink or anything would help remaining tabs survivability?
        • budwich
          • Jul 2015
          • 3097
          I think some on the forum have put some form of flexible heat padding on them. I would be concerned that playing with them more than you have to is a risk... potentially more than heat itself. Based on the numbers of posts in this forum, it would appear that the "mortality" of the tabs is kind of like... first failure rate has been reached, after that second and third, is already "baked in" so to speak.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4299
            • Italy - Milan
            Trash it... anyway how long it lasted?
            • mmartell
              • Oct 2013
              • 3189
              I think it's been just short of three years since original reapair.
              • mmartell
                • Oct 2013
                • 3189
                Here's the diagnosis... COF failure second from bottom. Already pulled them from the other side so this one is toast.
                Lasted a few months short of three years.
                (pics in next post)
                • mmartell
                  • Oct 2013
                  • 3189
                  I tried making a thermal pad sandwich and reinstalling the metal bar but it did not make a difference as the chip appears roasted. You can see the pad in one of the pics, the other was on the underside of the bar.
                    No doubt it's dead...wonder why Sharp's larger panels are so prone to this failure. It seems like a design defect.
                    Maybe the lesson here is to peel off ONLY the failed tab so you have more chances if the issue occurs again.
                    There may also be a reason to look at seeing if the VGH and VGL voltages can be adjusted, e.g. by adding some extra load to them. It may decrease power dissipation in the drivers, and increase the lifespan. VGH or VGL too low will however cause picture defects so it may be a fine balance.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4299
                      • Italy - Milan
                      Ehm.. i noticed you're from Canada, i know there is an enterprise there called LCD Masters that changes the flat cables..
                      • angelos
                        • Dec 2012
                        • 568
                        • South Africa
                        Aren't there tab bonding machines in the US where you can have this panel repaired?
                        • mmartell
                          • Oct 2013
                          • 3189
                          Considering I bought it for $100 and had it almost three years doesn't interest me much to try to find someone to attempt a tab bonding repair but I'll look into it anyway. I'm sure it's cost prohibitive considering similar tv's can be had for cheap only in need of backlight repair.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4299
                            • Italy - Milan
                            I don't know how much costs there for a similar working tv, but i always consider if a tv worth 400$ and a repair 380$ if the repair is guaranteed it worths the pain.. this for non repairer users..
                            • mmartell
                              • Oct 2013
                              • 3189
                              Do they have access to the tab/cof ? Otherwise it's a non-starter and only useful where the tab joint has lifted partially or wholly.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4299
                                • Italy - Milan
                                They change the tab with a new one, check his Youtube videos..
                                • angelos
                                  • Dec 2012
                                  • 568
                                  • South Africa
                                  Davi, can you send me the youtube link?
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Ok I called LCD Masters in Toronto (4 hour trip by car each way) and was given a price of $500cdn. I told him I already ripped off the tabs from one side and he said they only replace what's necessary to get the picture restored so presumably the single tab/cof that just burnt up in my case.
                                    Not worth it for me.
                                      I wanna know who is spending $500 to fix a TV when you can buy a new 70" 4K TV for $900. I understand it's a precision job but that is just not economical in the slightest.
                                      • jetadm123
                                        • 2169
                                        $500 and 8-hour round trip? Are they planning to work on it while you wait? Not worth it for a TV over 3 years old. Strip the boards and sell them and apply that money towards a new TV.
                                        • TimScrawn
                                          MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
                                          by TimScrawn
                                          Hi there,
                                          This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
                                          I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
                                          06-23-2024, 09:41 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • gavenb
                                          Sharp LC-80LE661U 80 inch
                                          by gavenb
                                          Hi folks!
                                          I have a LC-80LE661U that had some interesting issues.
                                          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                          11-12-2023, 02:05 PM
