flikery picture with hissing sound when bright only
  • GraphicMan
    • Aug 2018
    • 124
    • Egypt
    Hello guys
    I just replaced my faulty FBT with a brand new chinese one for my LG 29" RT-29FB75VE CRT TV
    the replacement was not the exact model but it has same pin assignment and voltages
    The tv worked perfectly with same exact super quality/contrast image
    but I noticed that the image does flicker noticeably WITH a hissing sound from the FBT only when there is a very bright image is displayed or a sudden brightness like explosions in a movie or something
    if I drop down the contrast/brightness from the menu (still nice picture) that issue never happens
    the FBT replacement is a BSC26 - N2137 (6174V 5003Z)
    my original FBT is 6174V 5003R
    what does that issue mean?
  • Harvey
    • Apr 2007
    • 264
    Re: flikery picture with hissing sound when bright only
    Originally posted by GraphicMan
    chinese
    • R_J
      • Jun 2012
      • 9623
      Crap replacement flyback, try and find an original. This problem has been around for years. In a lot of cases the cheap replacements just do not work correctly. Higher brightness means more current has to be supplied by the flyback.
      • petehall347
        • Jan 2015
        • 4448
        what killed the old one ?
        • GraphicMan
          • Aug 2018
          • 124
          • Egypt
          Thank you very much for your replies
          What killed the original: I dont know, but it arced after about 14 years of use, so it has to be replaced
          • R_J
            • Jun 2012
            • 9623
            Those replacements are not made to the same spec. as original, but it could be that you got a poorly made one. If you can have it replaced with another one or have it replaced with another brand it might work better.
            I have had replacements for Hitachi that did not work (narrow picture, poor hv regulation) I ordered an original and it worked perfect. I have also used those $10.00 transformers in some Sony's and they worked ok.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Turn the SCREEN control on the FBT to the bare minimum to see a picture
              • GraphicMan
                • Aug 2018
                • 124
                • Egypt
                Like I said, I lowered the brightness/contrast just a little (still have a great bright picture) and this issue does not show anymore
                I am very happy with the picture at the moment, I have also glued a 12cm fan in front of the FBT/Heatsink around it in an attempt to keep it for a longer time
                that fan is inside the cabinet and controlled via a switch outside, powered with a dc adapter, it helped lower the overall heat in that area
                I just want to know, would that FBT live for some years or that issue is a sign of a soon failure?
                it has been about 5 days now of work
                  • 31285
                  it could also be a failing B+ capacitor that smooths the power to the transformer.
                  • GraphicMan
                    • Aug 2018
                    • 124
                    • Egypt
                    Mabe not in that case because that never happened before with the original FBT
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Schwoin
                      Philips 243v5lhsb00 Monitor Picture too bright
                      by Schwoin
                      Hey everyone,
                      the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                      While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                      you can see them on the top half of the photo.
                      At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                      03-21-2023, 12:40 PM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • jchang
                      Samsung UN70NU6900F no picture and no sound
                      by jchang
                      Hi all
                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                      Symptom:
                      No picture no sound.
                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                      No sound at all.
                      What I tried:
                      1. I tried unplugging the left or right ribbon...
                      01-09-2023, 06:28 PM
