Telefunken 32" LED TV Model TLEDD-32HD Require Firmware
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Hi all.
    I am desperately looking for an eprom dump for the above set. The set is stuck on standby and suspect eprom. All voltage regulators on board are active. Pressing on the standby button on the tv or on the remote makes no difference to any voltages and standby led is permanently lit. This is a "all in one board". The panel number is HV320WX2-500 and the chassis number is CV59TH-A32. The Eprom is a 25Q32BSIG.
    The manufacturer does not sell the eprom they want to sell the whole board at a cost of 50% of a new TV.
    I have checked all those eprom sites on the web that i am aware of but no go.
    Any help anyone or is it of to the landfill with this one?
    Regards
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Re: Telefunken 32" LED TV Model TLEDD-32HD Require Firmware
    Update!
    I got an eprom dump from a person on facebook. I loaded it and still same result, no luck. Is there something else i can check? Because its a all in one board it makes things difficult but on the voltage regulators i do have 12V, 3.3V and 1.8V On the 3 diodes from the power supply i have 53VDC. I also have 19V going to the back lights which is not enough to drive the LED's
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Photos would be useful.
      • angelos
        • Dec 2012
        • 571
        • South Africa
        I have included a picture of the board. What else would you like a photo of?
        • vinceroger69
          • Mar 2012
          • 6714
          can you upload one picture of the back of the tv so we can see where all the wires are going too and one clear picture of the back of the board thanks
          • angelos
            • Dec 2012
            • 571
            • South Africa
            Is this adequate?
            • angelos
              • Dec 2012
              • 571
              • South Africa
              Ping
              • angelos
                • Dec 2012
                • 571
                • South Africa
                I guess this thread is dead? Not much else i can check. No circuit diagram to follow up.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  this seems a good price for a new board
                  https://www.yoycart.com/Product/521085401261/
                  • MrMagoo
                    • Jun 2015
                    • 6
                    • Oztrailya
                    Might be worthwhile checking leds?
                    • angelos
                      • Dec 2012
                      • 571
                      • South Africa
                      Yeah. The client is not prepared to pay. So its a return.
                      • omerzaid
                        Technician
                        • Aug 2017
                        • 11
                        • Iraq
                        Best Forum ever
                        • Rusenga
                          • Feb 2017
                          • 19
                          • South Africa
                          [QUOTE=angelos;852798]Hi all.
                          Hi, has anyone came across this problem and how did you solve it. I have exactly the same problem.
                          Regards
                          • angelos
                            • Dec 2012
                            • 571
                            • South Africa
                            No, there were no replies.
                            • arizanotlari
                              • Nov 2014
                              • 158
                              • Turkiye
                              Flash dump : https://yadi.sk/d/V5qOHsPriIezpA
                              https://www.badcaps.net
                              • Mirenia
                                Samsung UEMU6199U - no Standby - bad Firmware?
                                by Mirenia
                                I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                                Voltages on the power supply board is okay. Backlight test is also okay.
                                I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                                So I think my TV has exactly this issue.
                                Can someone please fix the dump?
                                And how do you do that?
                                As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                                05-12-2025, 06:13 AM
                              • TheUser
                                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                by TheUser
                                Hello to everyone ,
                                This is my first post here, and i would like to share with you a small story in case you can help me.
                                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                02-10-2024, 02:07 PM
                              • zklgfs
                                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                by zklgfs
                                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                Yesterday, 02:14 PM
                              • gurj1979
                                Ubiquiti firmware help. US-8-150W POE
                                by gurj1979
                                Hi guys.
                                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                Got New chip and writes good.
                                THE PROBLEM...
                                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                Does anyone have a Good Firmware I can have?...
                                07-22-2024, 05:13 PM
                              • wattage
                                AOC AG493UCX 49-inch monitor - Firmware request
                                by wattage
                                Hello Badcaps Community,
                                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                07-13-2025, 04:41 PM
