Samsung UE55F6800SB
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Re: Samsung UE55F6800SB
    If it wont open i don't know ?
    I am not the best on these computers i do struggle a bit ?
    • vinceroger69
      • Mar 2012
      • 6714
      #62
      yes video works fine now thats certainly a odd fault as its returning to the smart tv logo and then back to the dvd picture
      • ronhayes
        TV Engineer
        • Mar 2014
        • 458
        Yes it actually turns off then when it powers back up it starts at the logo.
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Yes i am sure if it stayed on long enough you would be able to tune it in ?
          • vinceroger69
            • Mar 2012
            • 6714
            #65
            not sure what to suggest but if a tcon is cheap i would replace it to rule it out you can always re sell it and get your money back if its not the tcon at fault but i cant see a brand new mainboard having the exact same issue.
              So right now if you disconnect the LVDS cable between the main board and the T-CON board then you can turn the TV on it will stay on and get sound?
              I see sparkles on the Video.
              • ronhayes
                TV Engineer
                • Mar 2014
                • 458
                Yes
                If i unplug the ribbon either from the main board or from the T-Con the set stays on with the backlights on and sound and you can go into St/by and out off St/by no problem i think all of the remote functions would work but with no picture its hard to tell ?
                But when the T-Con is re-connected it just keeps tripping or as i say keeps going off/on over and over.
                Before i removed the outer frame and it was standing on its stands the picture looked a lot better. ?
                I am waiting for a couple of replies from sellers about T-Con boards but as it is showing these sparkles and it only trips when the T-Con is connected i am leaning more to the T-Con being faulty?
                  At this point it does point to T-CON board problem.
                  • ronhayes
                    TV Engineer
                    • Mar 2014
                    • 458
                    Thank you budm
                    I will post the out come when i have replaced it.
                    • budwich
                      • Jul 2015
                      • 3097
                      Originally posted by ronhayes
                      Yes
                      but didn't you report earlier that with one cable disconnected on the tcon, the tv still went off and on by itself????
                      • ronhayes
                        TV Engineer
                        • Mar 2014
                        • 458
                        Yes that is correct but the T-Con was connected to the main board at that point when i reported unplugging the ribbons to the LCD panel !!
                        It is only when the T-Con is disconnected from the main board the TV stays on ?
                        • megaraider
                          • Jul 2015
                          • 307
                          • Portugal
                          #72
                          Changing the T-CON won't necessarily give the expected results...!
                          There's a huge design flaw, or lack of redundancy, happening on T-CON board:
                          the power plug is nowhere to be seen (see picture 1)
                          Since that TV set has an history of overcharge, and the T-CON board is only powered from the ribbon connected to the mainboard, you should check first the continuity for every pin on that ribbon (most likely there are burned tracks, even short circuity tracks).
                          Besides visual inspection, from the rear after disconnecting the ribbon on both ends, also check continuity (with the ribbon connected at both ends) between the sockets pins on the circuit boards, i.e. socket pin 1 to X on mainboard and socket pin 1 to X on T-CON board (being X the total number of pins).
                          • ronhayes
                            TV Engineer
                            • Mar 2014
                            • 458
                            I can understand what you are saying ! and have used my magnifying glass attachment to my glasses and took a good look at the ribbon and cannot see any burn marks and i have also carried out a continuity test on the ribbon which was extremely difficult considering the poor condition of my eyes in my old age ! and have found no issues . 1have not yet been able to carry out a continuity test when then ribbon is connected to each board due to my eyes and having to shift eyes from one board to the other with a magnifying attachment.
                            I am hoping the replacement T-Con board will arrive tomorrow and hoping this will resolve my issue . I will post my findings when it arrives.
                            • megaraider
                              • Jul 2015
                              • 307
                              • Portugal
                              #74
                              I can understand what you are saying (...)
                              OK. Hope changing T-CON will solve the problem
                              • ronhayes
                                TV Engineer
                                • Mar 2014
                                • 458
                                Hi All
                                Here is a update on this set.
                                The replacement T-Con board arrived today the board that i ordered was from a different model TV ie (the model number is UE46H6203AKXXU) now i know this T-Con board is out of a 46" TV and my TV is a 55" but the BN numbers are the same which is BN41-02069A I will include a picture of each board showing these numbers.
                                Now when i installed the replacement board the TV when plugged in came on in St/by i then powered up with the remote and the TV stayed on it did not go off/on repeatedly as with the original board. Showing me the fault was indeed with the T-Con board.
                                As i had not been able to take a picture of the display with the original board in due to it not staying on long enough i have played the video that i took and paused it so i could take a couple of pictures from my PC screen.
                                The first two pictures you will see are taken off my pc screen the second two are of the actual TV screen with the replacement board installed
                                And as you can see from the second two pictures the image is only in the centre of the screen and there are lines down the one side of the screen. And the first two pictures albeit taken of my pc screen show a full screen with no lines down the one side ? Does this mean that the replacement T-Con board is faulty.
                                Or could this mean there is a fault with the ribbon cable from the main board to the T-Con as pointed out by (megaraider).
                                But at least now the TV does not keep going off/on as it was before.
                                Now what i am asking is this showing that the replacement board is not compatible or can i rectify this in a service menu and why with this replacement board do i have these lines down the one side of the picture ?
                                I have double checked that the ribbons are correctly fitted. Any input would be very much appreciated.
                                  BN41-XXXX is for blank circuit board P/N, the blank board can be stuffed to make many PCBA's for many model of LCD panels.
                                  You need to match the barcode number, not the blank board number.
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    budm
                                    Which label do i need to match ? number 1 label or number 2 label.
                                    If anyone knows where i can locate a T-Con for this TV i have tried looking but cannot find a perfect match to the label on my board ?
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      I now know it is the T-Con board that is causing the fault on this TV just need to find an exact match but that is being very difficult if anyone knows where i can get one it would be very much appreciated or maybe some one has one that i can purchase of them ?
                                        What is your LCD panel model number?
                                        LSF550HJ03?
                                        https://www.badcaps.net/forum/showth...t=71980&page=4
                                        The PCBA numbers as printed on the bar code is BN95-01134A.
                                        • ducky29
                                          • Dec 2015
                                          • 370
                                          • Europe
                                          #80
                                          What is the correct model number of the tv? Ex UE55F6800SB / XXHU ; and panel number as well
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
