LG T250SC DVD receiver - noise from the speakers
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    • Bulgaria
    Well, hello again, dear friends.
    Today I will torture you with my problems again.
    I have a problem with my old DVD receiver, that I used to use as audio system some time ago. I have only a noise from the speakers - all of them. It doesn't matter if you turn the volume to the minimum or blast it to the max - the noise doesn't change at all as intensity
    I've checked the PSU voltages and I've found that 35V a lit a little bit low - about 27V. Everything else checks as it should.
    The receiver uses a pwm driver and BA505, so perhaps it's hard to diagnose without a proper equipment..
    I would be extremely glad if you can help me with this problem.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    Re: LG T250SC DVD receiver - noise from the speakers
    What is the full model number?
    https://elektrotanya.com/showresult?...oria=&kat2=all
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      • Bulgaria
      Originally posted by budm
      LH-T250SC P/N 3850RLM008F
      2xSTA 515 as a final stage amplifiers.
      BA5954FM as a actuator driver
      Pulsus ps9818 as a digital sound processor/PWM driver of the STA515
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        27V is a bit low. Re-test/replace all the smaller e-caps on the PSU. Investigate why that voltage is so low. The large filter e-caps should be good, though
        • televizora
          ghettomodmaster
          • Nov 2016
          • 957
          • Bulgaria
          Well...I think..If one of the STA-s is shorted, do you think that it's possible for the voltage to drop that low? I cant separately test the STA-s, because they are not usual final stage amps and I can't just supply the inputs with some signal.
          So, I have noise from the speakers. When I move the board or connect antenna, then I can hear cracking for a second from the speakers. I cant regulate the volume neither from the front panel, nor from the remote.
          The problem is that there are 2 STA-s, and I hear only noise from all the speakers. This means that either both are busted, there is a problem with the driver or there is other issue that affects both the STA-s.
          Do you think that this can be power supply issue?
          • televizora
            ghettomodmaster
            • Nov 2016
            • 957
            • Bulgaria
            WTF!!?Yesterday, I heard a strange noise, but thought that it comes from the PSU. Today I've tested the receiver again. I've connected antenna to the FM antenna jack. When I increase the volume to the maximum, I can hear a faint sound from the radio station that is being received coming from the FM tuner itself!!? Something inside the tuner is oscillating as well as both the STA-s are warming up the coller placed on top of them.
            Please help!?
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              • Bulgaria
              It's one of the STA-s. I've cut the power of the one of STA-s. Before, there was some sound from the front left channel. From all the other channels - only noise. Now I have 3 channels that work and there isn't any noise.
              What I did is to cut the trace with +36V to the STA that is responsible for the sound on the front right, SubWoofer and back right. Kinda ghetto mod. Now I will look for another STA, perhaps I will order one. They are cheap - something like 5$. I didn't think that one defective STA will interfere with the sound coming from the other STA, as they are separate IC-s. Seems like the noise passes tru the common ground the the two STA-s.
              • osrex
                LED DRIVER KEEPS DYING
                by osrex
                Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                i have no datasheet at all for the LED lights, all i have is its length.
                long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                05-05-2025, 03:36 PM
                Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                by momaka
                More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                02-15-2022, 12:43 AM
              • tony359
                by tony359
                11-28-2023, 05:18 AM
              • jason123
                Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
                by jason123
                Hello folks,
                New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
                05-27-2025, 07:26 AM
              • CDNBrewer
                Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                by CDNBrewer
                Hello Everyone,
                I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                Symptoms:
                • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                • I swapped the Left and Right surround
                08-05-2025, 09:29 PM
