Sharp Aquos LC-70LE650U
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp Aquos LC-70LE650U
    the bonded tabs are like tape which just pulls off. They have to be pull up from the front of the panel.... if you look close at the edge of the panel, you can see where the "tape" sits / rides. You do have to be careful as you can damage the tracks underneath which would be bad. It doesn't really matter where you start but they all have to be removed from the "bad side". Your chances of success are high as this "operation" has been probably performed hundreds if not thousands of times as it keeps one more set from the dump.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4465
      • Italy - Milan
      Looks like the only thing left to do is surgery, right?
      YES. Watching better the monoscope photo, yes there can be something like a short on the drivers outputs where there is that stripe, so a inactive driver can load down some current, (i'm on a field of supposition, i have done few tests).
      • b43n70n
        • Sep 2018
        • 14
        I'm looking at these tabs...
        • budwich
          • Jul 2015
          • 3097
          yep... if you look close at them, you might see some sort of "heating marks" in and around the embedded chip.... that is one clue. Sometimes people find one hot to touch compared to others. basically, if you look at the "tape" near the panel, you can see that it is "laid down" on the panel edge just like a "regular piece of tape. It is removed by gently pulling up on the bottom or top edge and slowly "ripping" it off.
          In your picture, it appears perhaps that the bottom one might have some "stain" although that could be a reflection in the picture.
          • b43n70n
            • Sep 2018
            • 14
            After removing the tabs and turning on the TV, it started to smoke on the bottom left corner behind the panel.
            I immediately turned it off and after a few minutes passed I turned it back on. No smoke this time.
            Looks like it is working at this point.
            • budwich
              • Jul 2015
              • 3097
              WHAT!!! you let the smoke out and now it works! :-)
              hmmm that doesn't sound good maybe somewhere was touching the frame.... check to make sure that no portions of the edge boards are touching areas that shouldn't be in contact with metal. It appears that you have done good overall. Hope it lasts as most have.
              can you tell / smell where exactly the smoke was generated?
              • b43n70n
                • Sep 2018
                • 14
                Can't tell where it came from but I still had the narrow circuit boards connected to the bottom corner ribbon cable. I removed the narrow boards and covered the end of the ribbon cable with some tape. Hopefully this will work...
                Once I sat down to look at the gates I saw that the one at the bottom left corner was crispy. Take a look.
                Notice the corner, it's discolored and damaged too.
                Thank you for helping me with this, I feel the other TV is going to need the same treatment...
                • budwich
                  • Jul 2015
                  • 3097
                  it is possible that since you left the interconnection cable still connected to the side edge board that it was still trying to drive the components. Anyways, you are now an experienced saver .... :-)
                  note: you don't need the bottom corner ribbon cable... it can be removed from the set.
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    #29
                    got this same set yesterday - -exact same symptoms. removed buffer tabs, small ribbon cable that connects bottom boards to side boards and set lives again. Want to thank everyone who contributed to this post = nothing better than success and saving another one from the dumpster. been looking to upgrade my shop tv !
                    • markolino
                      • Mar 2020
                      • 109
                      • Slovenia
                      #30
                      but this cut only works on size TVs70 "
                      what about half calf chips on the sides of the TV?
                      I'm not clear on the point of this cutting .. how can a TV work if one cuts? Hehehe
                      • budwich
                        • Jul 2015
                        • 3097
                        it works on any set with "external drivers" (ie. not embedded in the panel).... assuming the problem is related to drivers and not something with the bottom edge boards or the panel itself (eg. window washing and such contamination).
                        • Greyrockone
                          • Nov 2014
                          I know it's an old thread, just posting my success story! (July 2023) I just acquired this set for free (curb alert) and after removing the driver board(s) on the affected side of the screen as suggested, it worked! I'm still VERY confused as to why the TV appears to work like new again after removing these components, go figure. Anyway I'm back in business. Many thanks to all that contributed about their own experience.
                          • scubacamper
                            Sharp Aquos LC-70C6400U Half Screen Dark
                            by scubacamper
                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                            05-03-2025, 12:19 PM
                          • sefoster
                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                            by sefoster
                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                            11-20-2022, 09:29 AM
                          • jonah1024
                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                            by jonah1024
                            Hello!
                            I'm a few days old into this TV screens repair universe so please bear with me.
                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                            - I did a factory reset as well...
                            07-16-2024, 04:23 AM
                          • klassic
                            Sharp Aquos LC-60LE635E three blinks
                            by klassic
                            Hi community,
                            I will describe my problem with a TV in those short following terms to be the most precise :
                            What i have :
                            power board DPS-162KP-1
                            main logic board QPWBXF733WJN2
                            symptoms :
                            white led light logo at startup,
                            after 2 minutes, blinking 3 times a row, repeating
                            no backlight (and apparently no picture, checked panel with flashlight)
                            no startup sound
                            powerboard investigations :
                            1-2 PNL : 0v
                            3-4 GND
                            5-6-7-8 UR : 13.15v
                            9-10-11-12...
                            10-24-2023, 01:39 PM
                          • foxyUK
                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                            by foxyUK
                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                            10-22-2024, 10:27 AM
