Sharp Aquos LC-70LE650U
  • b43n70n
    • Sep 2018
    • 14
    Have two of these TV's, one on either side of the room. One of them started acting up with the screen flickering. After disconnecting all inputs and going to the menu screen it was still flickering. Here is a video of what I am seeing...
    https://youtu.be/9-_1NuXqJ90
    I swapped the TV from the other side of the room over to this side and within the hour the second TV started doing the same thing.
    I have read through many threads here and have not seen this exact problem but I have tried resetting the TV and using the vol+ -cha while plugging in the TV.
    After the TV is unplugged for a while it works fine for a couple minutes then starts with the flickering again no matter where it's plugged in.
    If anyone could shine some light on this I would really appreciate it.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4500
    • Italy - Milan
    Re: Sharp Aquos LC-70LE650U
    That's incredible... one is not enough??
    • b43n70n
      • Sep 2018
      • 14
      well, it's a big room in a large building.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4500
        • Italy - Milan
        It's incredible also the fault, it is a panel issue for me, but i never thought of a panel issue that has something to share with a wall socket power issues..
        • budwich
          • Jul 2015
          • 3097
          does your cleaners also do windows??? :-)
          without taking the set back off (and maybe the front bezel), you aren't going to find your answer very easy.
          My guess would be water ingression either from "good people" or possibly long term humidity. Inspection of the connections / cabling / tabs will tell the story.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4500
            • Italy - Milan
            It's the third time that i push the link Previous Thread instead of PostQuick Reply and i have to rewrite all with my f****ing tablet, Sob..
            Now an intriguing question for you, does the two tv 's were be always switched on and off at the same time? In other words can you with the help of the forum tell me the total usage hour count of both that is visible in the secret service menu? Thanks, i have an insane idea...
            • b43n70n
              • Sep 2018
              • 14
              These TV's are mounted high enough that they do not get touched by anybody. They are both turned on only during events and then shut off the rest of the time. I would estimate they are on less than 10 hours a week and that is a high estimate. One thing I regret not doing is using some kind of line conditioner since we have so many electrical storms here in Florida.
              As for the secret service menu. I went through all 27 pages and did not see a "total hour counter". Unless I was in the wrong service menu...
              I have the back cover off and I did a visual inspection of all the components on the board the power comes in on and I didn't see anything out of the ordinary.
              There is a whine sound coming from this board that would annoy me if I hear that in my living room. Not sure if that should be there.
              Any ideas anyone has would be a tremendous help as I am not sure where to go from here.
              • budwich
                • Jul 2015
                • 3097
                you need to look at the edge boards along the bottom where the cables from tcon connect to the bottom. From there you need to look along the edge boards to see if there is any "moisture looking dry stuff". Further, as part of the "testing", you can try isolate your problem more by disconnecting, one at a time, the cables going from the tcon to the panel and see if this changes anything. This will tell you more about the problem.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4500
                  • Italy - Milan
                  The service menu is not mentioned in the user guide, i have watched a service manual but unforturnately it seems taht Sharp did not store unit working hours like the other brands, anyway i report you the method of another model:
                  2. Method of shuts down for Power supply
                  Please execute the following procedures to shut down Power supply from the state of normal operation.
                  1) Keep touching the power supply key on the set for 5 seconds from the state of watching.
                  * The screen disappears when power supply key is touched, but Keep pushing the power supply key.
                  2) A central icon lights between 500ms when the power supply shuts down.
                  Please separate the finger from the power supply key when lighting of a central icon is confirmed
                  3. Entering and exiting the adjustment process mode
                  Please execute the following procedures to enter the adjustment process mode when the power supply shuts down.
                  1) While holding down the “VOL (-)” and “INPUT” keys on the set at once, touch the power supply key on the set.
                  Please separate the fingers from key on the set when boot-up is confirmed with lighting of a central icon etc.
                  After a while, The letter “K” appears on the screen. This state is in Inspection mode.
                  2) Next, hold down the “VOL (-)” and “CH ( )” keys on the set at once.
                  Multiple lines of blue characters appearing on the screen indicate that the set is now in the adjustment Process mode.
                  If you fail to enter the adjustment process mode (the display is the same as normal startup), retry the procedure.
                  3) To exit the adjustment process mode after the adjustment is done, unplug the AC power cord to force off the power.
                  (When the power is turned off with the remote controler, once unplug the AC power cord and plug it in again. In this case, wait for 10 seconds or
                  so after unplugging.)
                  For instance, i was suspecting programmed obsolescence...
                  • b43n70n
                    • Sep 2018
                    • 14
                    I was able to get to the service menu with the blue text. There were 1-27 pages of information as I pressed the channel up and down buttons. I could change some of the items with the volume up and down. But I did not see anything about working hours.
                    I disconnected the tcon connectors one at a time and the problem persisted with the left side (while looking at front of TV) connected but went away with the right side connected. So with the left side disconnected there were not flickering lines.
                    • b43n70n
                      • Sep 2018
                      • 14
                      I took off the left side metal bar and disconnected the ribbon cable on the left side and now the TV is working properly without having to cut anything off.
                      Is this really all there is to it?
                      • b43n70n
                        • Sep 2018
                        • 14
                        Looks like I jumped the gun a little. After injecting a signal there are lines on the left side. Is this where I have to rip off the brown tabs?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4500
                          • Italy - Milan
                          I dont like much the ripping off of the side tabs, there are maybe better ways but with language limits and without to know your skill level and time availabilty i prefer to stop here..
                          • budwich
                            • Jul 2015
                            • 3097
                            slow down and make sure you and the forum understand what you are doing BEFORE you go too far.
                            The "test" to see if you have to "rip off the tabs" is to get at the little corner cable on that side that you think is the problem. Its unclampable so disconnect it... it breaks the connection between the bottom edge board and the side edge board / tabs. Post a picture of the resulting image and go from there.
                            • b43n70n
                              • Sep 2018
                              • 14
                              Sorry for the poor choice of words. I have been working with electrons all my life, just not with 70 inch monitors although I've replaced my share of caps in Dell monitors.
                              I have attached an image of the screen after disconnecting the ribbon cable on the bottom left side of the screen...
                              The blue at the top left of the screen is a reflection of a monitor, I tried to turn it to reduce the amount of reflections but that was missed.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4500
                                • Italy - Milan
                                Right to make it clear, it's evident that your screen has at least one of the gate drivers faulty, the minimal goal is to insulate all the drivers on that side, the most destructive way is to rip off those, buta more conservative way (useful or not useful) is to put a little piece of adhesive tape on the flat cable between tcon and panel on the faulty side, about wich signal to mask i'm not sure, never tried, but i suggest to start with the vertical start pulse, something expressed with a serigraphy like Vst or vstp, that may or may not be present on tcon.
                                • b43n70n
                                  • Sep 2018
                                  • 14
                                  I don't believe I see any silk screening on the tcon board where those connections are...
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4500
                                    • Italy - Milan
                                    I don't see much with a little photograph but seem almost free of silk screening. The osciloscope can be an answer only for expert people, i don't even have one, so right to not let you lost any time i stop with any other suggestion, but it remain strong the sensation of a programmed obsolescence trick.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      The gate drivers can never be fixed anyways so the "minimal method" doesn't buy you much, if anything and you further are playing with plugging and unplugging tcon cables at a risk of damaging them or the connector. Further depending on what the failure of the side driver is, potentially leaving them connected may ultimate load the remaining good side and cause it to fail sooner.... just my read on things, I have no actual data / info to support this other than having saved a 70 in sharp using the "tab removal method" that is still working for the last 3 years.
                                      your picture shows a bad driver in the lower left of the screen that is causing the horizontal line across the screen which slowly fades as it goes to the right. The darkness of the left side is caused by the remaining drivers on that side not get "signal" because of the disconnected interconnection cable and the resulting load of the other side.
                                      • b43n70n
                                        • Sep 2018
                                        • 14
                                        I tested several times covering up some pins on the tcon connector but didn't have any success with that and I am afraid of damaging that connector. Looks like the only thing left to do is surgery, right? Do they all need to be cut or should I start from the bottom?
                                        The hair on the back of my neck stands on end just thinking about this surgery.
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
                                        • foxyUK
                                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                          by foxyUK
                                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                          10-22-2024, 10:27 AM
