Sharp TV Model# LC-60UD27U
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Sharp TV Model# LC-60UD27U
    yes maybe worth checking/swapping the part as in post 19 as it may of fixed the same fault on the other persons tv whats the part number stamped on q7120 and budm still needs a picture showing how all the boards connected up in the tv so a good picture showing the whole back and all the boards fitted and connected thanks
      Q7120 (KIAxxxxx?) is a 4-pin switched 12V LDO which supplies the 12VDC to to the T-CON board via PNL -12V pin.
      Are these your boards?
      http://www.shopjimmy.com/sharp-lc-60...-version-1.htm
      You need to report the Voltage reading of each pin of the PD connector, you must put down the pin name and follow by the Voltage reading of each pin when TV is OFF and when power switch is activated.
      Your TV has many boards and since I do not have TV in front of me to look at to see how all the boards are connected together so please follow the simple request if you want free help.
      • JayPoorJay
        sharp LC70EQ10U 2 slow, 2 fast blinks
        by JayPoorJay
        Good morning... I'm new here and have a LOT to learn.
        I'm a rescue-er. I live in NYC and I don't even want to get started on the amout of stuff that makes it onto the curb, to be crushed and in a land fill, simply because our repair shops have been sold out and because - well, it's a disposable society... Anywho
        I have 1 motorcycle, 3 Jaguars and a Porsche that were all headed to the crusher due to a couple handfuls of needed parts and a Lil Love,,, I'm hooked on the rescue. A member of several forums and a huge fan of DIY environments such as this one. Hats off to you...
        01-24-2022, 09:26 AM
      • joblo37pam
        Sharp LC-80LE844U Blinks 2 slow, 5 fast
        by joblo37pam
        It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
        The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
        10-26-2023, 02:17 PM
      • klassic
        Sharp Aquos LC-60LE635E three blinks
        by klassic
        Hi community,
        I will describe my problem with a TV in those short following terms to be the most precise :
        What i have :
        power board DPS-162KP-1
        main logic board QPWBXF733WJN2
        symptoms :
        white led light logo at startup,
        after 2 minutes, blinking 3 times a row, repeating
        no backlight (and apparently no picture, checked panel with flashlight)
        no startup sound
        powerboard investigations :
        1-2 PNL : 0v
        3-4 GND
        5-6-7-8 UR : 13.15v
        9-10-11-12...
        10-24-2023, 01:39 PM
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
      • EazyBone
        Un50cu7000 2 blink oddity *partially solved
        by EazyBone
        I write this to maybe help another with this TV.
        So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
        The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
        03-18-2024, 10:24 PM
