2011 Panasonic TC-P50GT30 7 Blinks Help
  • PanasonicPlasmaProblems
    • Aug 2018
    Hello all.
    My Panasonic Plasma is on its 2nd 7 blinks error. I fixed it the first time using a repair kit for ShopJimmy. Well its back 1.5 years later. Was SC board so bought a used SC board off ebay. Replaced and got same 7 blinks. The green LED on the SC board never lit up. Unhooked SC from buffer boards SD and SU and removed grounding screws connecting SC to bufferboards and shorted SC50 and still 7 blinks. So now I am assuming the SC board I was sent was bad. To see if the TV would just stay on I unhooked the power and ribbon cable from the SC board and turned it on. I get 8 blinks. From my research I see most 8 blink errors mean the SS board is shorted. Is this true?
    I also used a multimeter set to check continuity and checked the ribbon connections on the buffer boards SD and SU. No beeps and was getting a reading of .800 and lower. From research again this tells me the buffer boards are okay. Is this also correct?
    I have a 42" Panasonic TC-P42ST30 in the basement we don't use much. Does anyone know off hand if I could "borrow" parts off that to see if I can't figure out the issue. I can open up the back and check if need be but just wanted to save some time.
    Thanks for the help!
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: 2011 Panasonic TC-P50GT30 7 Blinks Help
    Use your meter in beep mode and check the sc and ss power connections for a short. A beep longer than 2 seconds means short. And no you can't use anything from the 42" to diagnose.
      • Aug 2018
      Thanks tvtimmy.
      I checked for shorts on the power connections on ss and sc board and there were none. I check all the wires from the P board to the sc and ss board and all wires were good.
      I did make a little progress. When I turn the tv on I can now hear a buzz and the green LED on the SC board will light up only for a second then a click and then the 7 blinks comes back. Any idea on what is causing that?
      Thanks!
        • Aug 2018
        Also removed all three connections between SC and the SU and SD boards (SC41, SC42, and SC46). Removed the 4 VFG screws between the boards and jumped SC50. Fired it up and get 6 blinks.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          6 blinks after replacing the FETS is usually a DG302 on the SC board or the driver chip. ( IC501 ). DG302 will probably not read short but it is wise to replace it.
          When SS board fails it is usually the Q201 close to the blue cap. Read it in diode mode over the 2 pins. Beep is bad.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Make sure all screws are tight also.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • Biruslapio
              Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
              by Biruslapio
              Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
              It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
              It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
              02-16-2021, 09:44 PM
