Help identifying a surface mount fuse
  • brucetv
    • May 2015
    • 281
    • united states
    I'm working on a LG oled with a bad main board. I found a blown surface mount fuse marked F61. Anybody know the specs of that fuse? here's a pic. It's at VA6701...thanks
    Re: Help identifying a surface mount fuse
    1) What is the TV model and the main board model? It does not look like fuse.
    2) What Voltage do you have at both ends with ref to circuit GND?
    3) Is one end connected to circuit GND?
    • arenat
      • Nov 2015
      • 22
      • Argentina
      VA varistor .
      • brucetv
        • May 2015
        • 281
        • united states
        It's a LG model OLED65B6P-U version BUSZLJR. If it's a fuse it's blown but I'm confused with the VA6701 marking.
        • vinceroger69
          • Mar 2012
          • 6714
          this maybe the service manual
          https://www.manualslib.com/manual/11...Oled55b6p.html
          va6701 is on page 52 bottom left of page use preview function
          • R_J
            • 9624
            EAF62990001 Varistor, Sg300Q 300V 30% Or Glass Discharge Tube
            F = Type code = SG300Q
            6 = Year code (last digit) = 2016?
            I = Month code = September
            • brucetv
              • May 2015
              • 281
              • united states
              Looks like it main board part number EBT64267805. here's a pic. No voltage on either side and shows open. here's a pic.
                It is for protection of that Tuner module in case the surge comes though the RF cable.
                So what is the TV not doing?
                  Looks like a gas discharge SMD device for surge arresting.
                  Not sure how well a little SMD like that is going to do, but nice to see that they've at least tried to add some protection on these vulnerable inputs.
                  Thing to watch out for these OLED TVs is they have a lockout. If there's panel damage or a short, after five attempts to power up, they'll lock out and something needs to be reset to try again. Freakaftr8 may be able to advise here as he has done quite a bit of hacking with these.
                  • brucetv
                    • May 2015
                    • 281
                    • united states
                    Thanks for the help gang....took a lightning surge and if that's all that is wrong with it today is my lucky day.
                    • brucetv
                      • May 2015
                      • 281
                      • united states
                      Tom, I'm getting good voltages to the main and can hear the relay clicking on the power supply but no video or audio, or optical. I'll have to pull the board and look at the traces on the back and see what this does and if anything else is short. The lockout sucks so I might just order another Main and keep life simple since I am not a authorized LG service center. $230USD a pop....At least it was fairly easy to get the back off this model. Most of the other LG Oled's were a bear to get the back cover off. Push here, clip there, cuss here and it finally comes off. Panels are so thin I can't wait to get them out of my shop. After watching golf on it for 3 or 4 hours.
                      • brucetv
                        • May 2015
                        • 281
                        • united states
                        Good news. I got this varistor in and it turned on fine. I did get a message I've never seen that said to hit the ADJ so have a LG Factory SVC Remocon remote handy. Hit the ADJ and the Tv will turn off. Then hit the power button and the Tv fires up. The remote stayed paired so I didn't lose any customer settings. Thanks R J for helping me identify it and it does act as a protection from a lightning surge through the coax and this time only took out that varistor so my customer dodged a bullet as the main boards are very expensive and had a factory back order of two weeks. That was the last thing I wanted to tell my customer right before football season starts. I almost told him the part wouldn't come in until after the first game so I could watch the game on this fantastic picture. Underwater diving scenes and the 4k Youtube video's of Costa Rico wildlife video's are very nice. Gotta get me one of these.
                          Surface Mount Fuses Fundamentals Datasheet
                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                          10-07-2024, 06:07 AM
                          TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                          FF Series (Very Fast Acting), 0603 Size
                          Features
                          ● Very fast acting at 200% overload current levels
                          ● Low DCR
                          ● High inrush current withstanding capability
                          ● Fiberglass enforced epoxy fuse body
                          ● Copper termination with nickel and tin plating
                          ● Halogen free, RoHS compliance and lead-free
                          Applications
                          ● Notebook computers and tablets
                          ● Digital cameras
                          ● Memory cards
                          ● Toys
                          ● Bluetooth earphones
                          ● Portable electronic devices​...
                          10-07-2024, 05:50 AM
                          Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                          09-06-2024, 08:10 PM
                          Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
