Weird 29" LG Flatron Problem
  • GraphicMan
    • Aug 2018
    • 124
    • Egypt
    Re: Weird 29" LG Flatron Problem
    that is cracked or lost its insulation .. new fly-back will likely be expensive if you can even find one .. i used to scrap sets with bad fly-back transformers as they simply wasn't worth spending that sort of money on .
    you may get lucky and find a new one cheap enough .
    hmm very interesting
    I found some on ebay, they are not so cheap when you compare its prices to what I have paid to the whole tv set
    however, can you help me know which FBT model I should look after?
    do you think if I replaced the FBT it will work? perhaps another failed component lead to the FBT failure?
    is that a common failure, I have seen many tv's that lasted way more working hours than this one!
    • petehall347
      • Jan 2015
      • 4450
      • United Kingdom
      looks like insulation breakdown or a crack like i said .. any other things are unknown .. maybe you could try insulating it somehow just to test if it is just that .. not much to lose at this stage . i might try a few coats of ignition sealer spray after cleaning it with isopropyl alcohol
      • GraphicMan
        • Aug 2018
        • 124
        • Egypt
        I think you are very right
        even before reading your last reply
        I read few articles online and rechecked the FBT
        I found a very tiny hole
        the uploaded pic is still the same one but a larger crop from the original
        after cleaning the are it is more visible, and the arcing is coming straight out of it
        I am so happy now because it make sense, I cleaned and used a high quality silicon sealant (thick coat over that are)
        now I am waiting for tomorrow for it to cure, lets cross our fingers
        thank you so much, will tell the news
        • petehall347
          • Jan 2015
          • 4450
          • United Kingdom
          if it works it is just to test everything else . it wont be permanent even if it works at all
          • GraphicMan
            • Aug 2018
            • 124
            • Egypt
            yes I heard about that too
            would an epoxy be better? or do you mean if a FBT start to crack it means that it is internally loosing its insulation and sealing a cracked area will lead to a crack elsewhere?
            • GraphicMan
              • Aug 2018
              • 124
              • Egypt
              #26
              couldnot wait for more than 12h
              but wooooooooooow the tv worked again!!!!
              thanks for everyone
              • petehall347
                • Jan 2015
                • 4450
                • United Kingdom
                #27
                maybe get the correct epoxy . or thermal adhesive might work .
                might last longer than silicone .
                • GraphicMan
                  • Aug 2018
                  • 124
                  • Egypt
                  #28
                  Thanks bro
                  I would like to get the replacement
                  can you please check if there is a compatible replacement for it on ebay?
                  I cant even find the part # for it
                  • petehall347
                    • Jan 2015
                    • 4450
                    • United Kingdom
                    #29
                    i have no idea what the part number is . maybe you can search for it by using set id . or board id .?
                    • R_J
                      • 9624
                      there should be a label on the flyback, but might be on the oposite side, between the flyback and the metal shield
                      This is for the MC-049A chassis
                      https://www.chatchaielec.com/shop/la...c25-n1537.html
                      I have repaired similar problems using silicone and sometimes epoxy and it worked fine.
                      • GraphicMan
                        • Aug 2018
                        • 124
                        • Egypt
                        #31
                        Thank you very much RJ
                        I have already seen this exact part # listed but in a very similar TV model # but not the exact one I have (yes perhaps the label is on the other hidden side)
                        so I am not sure if I should buy it or not, perhaps you can tell me
                        about this fix how long you think it might last?, the hole is very close to 0.4~0.5mm only
                        one more question please:
                        the only thing I notice after this fix and replacing the main capacitor is that I need to boost the brightness to 80% instead of 45~50% to get the same brightness (contrast is the same, great)
                        what do you think about that?
                        thanks again
                        • steviewonder
                          • Dec 2013
                          • 183
                          • england
                          #32
                          Advance the A1 control slightly on the lopt-the bottom screw.top one for focus.
                          • steviewonder
                            • Dec 2013
                            • 183
                            • england
                            #33
                            not with your fingers,i hasten to say!,use a small insulated screwdriver with the set turned on.
                            • R_J
                              • 9624
                              The repair should last 11673.5 days. The plastic insulation broke down and the high voltage started to arc to the nearest ground. If the insulation is repaired (silicone) and it is working it should be ok. You can adjust the master screen on the flyback up a bit, if you go too far you will have retrace lines in the picture and poor black level, see if there is a master or sub brightness control on the board and adjust that if it is there.
                              This flyback could be different than the one I posted, the label is likely covered with dust and hard to see, try cleaning the dust from that area on the flyback and see if you can read the number otherwise you would need to remove the flyback to access the number.
                              • GraphicMan
                                • Aug 2018
                                • 124
                                • Egypt
                                #35
                                Thank you very much for your replies
                                this time I am using a very accurate power meter between the mains and the TV set
                                the TV is rated at 135W but the most I could read (full wight screen) is about 115W at most
                                does that mean anything at all?
                                the picture/colors and the contrast of this set is still even better than my dad brand new 43" led tv and thats why I still prefer this old crt's
                                when the set does not meet its rated wattage by that difference does that tell anything about its internal component?
                                • chaos-theory
                                  Nitro rx580 very weird problem, VCORE and EN
                                  by chaos-theory
                                  Hello!
                                  I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
                                  All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
                                  08-17-2024, 04:56 PM
                                • sorrowfulfloyd
                                  Samsung UE32J5373AS Weird LED Problem
                                  by sorrowfulfloyd
                                  Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
                                  This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
                                  12-23-2022, 07:00 AM
                                • brockauly
                                  Macbook M1 A2337 EMC 3598 weird battery charging problem
                                  by brockauly
                                  Hi guys,
                                  If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                                  Then if I unplug the charger and plug it back, it won't charge anymore.
                                  In the first case, main voltage is regulated at ~12.5V and charges the battery.
                                  After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                                  After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                                  I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                                  02-05-2025, 10:51 AM
                                • wnt2fx
                                  a1398 2015 weird keyboard problem
                                  by wnt2fx
                                  I installed a new keyboard and it can smc reset and the power button works. but nothing apart. no boot picker e.g. I am wondering how this can be explained if the alt key (smc reset) is working. I am aware that on the board side shift, ctrl, alt and pwr are separately wired but the board, trackpad/cable are good. The keyboard was tested working prior installing and as another keyboard now tested on the same board improvised works as well the only idea I have is that I damaged the keyboard flex cable while installing it into the case. But why hell smc reset and power are working then ? Anyone has...
                                  04-27-2025, 08:41 AM
                                • VikramB
                                  Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
                                  by VikramB
                                  First thread here on this forum, excuse me if I miss something in my first post.
                                  I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
                                  1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
                                  2. I've tried the tape method and...
                                  03-17-2023, 02:56 PM
