Dynex 40 inch TV - DX 40L261A12 - Shuts off and won't turn on after a few hours.
  • OwnedbyCow
    • Jul 2018
    I am going to start off by saying that I am new to fixing actual components rather than what I am used to and just trying to replace them. Off topic - Does anyone know a good starting place to start learning how electronics actually work? Working on my tv seems to be a good place to start learning about troubleshooting components, but I still will not completely understand why it works.
    There are two issues with the tv.
    The first one which is the most important. After having the tv on for a few hours it will shut off and when I try to turn it on, it will attempt to start up. The red light will disappear and it will do everything as normal until it tries to actually turn on the screen then it shuts off. After this, none of the touch buttons will work anymore. I have to unplug it for 30-60 minutes and then try again. Usually waiting for an hour before plugging it in will let me use the tv for another few hours.
    Where should I start with trying to find the actual issue for this? I feel like this would be a power supply issue, but I haven't taken it apart yet. Once I get a bit of feedback, I will take it apart and visually inspect it to see if anything looks burnt out. Then I will try using a voltage meter, but I am not 100% sure where to use it at.
    The second issue is more of an annoyance.
    This problem has been going on for a lot longer than the first issue that I mentioned. The tv will randomly change volume, channels, open the menu or turn off. These are all touch buttons that are on the front of the TV. It is more uncommon than common. Maybe, once or twice during an 8 hour span on average. Sometimes more, sometimes none.
    Could there be dust or anything inside of the tv that would cause it to think there was a touch input? I have cleaned the touch area really well and the problem persisted, so I don't think it has anything to do with the exterior "buttons."
    Any advice helps greatly. Thanks for reading.
    Re: Dynex 40 inch TV - DX 40L261A12 - Shuts off and won't turn on after a few hours.
    First, we need good CLEAR picutres of the whole backside of the TV showing how the boards are connected together, then good clear straight shots pictures of each board.
    Basic check right now will be visual inspection, check and verify that all the connectors are plugged in properly.
    Then you will have to the Voltage readings of the power supply at various connectors and test points. You should read basic TV troubleshooting guide.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      That sounds just like what my Moto e4 (with Android Nougat) does, LMHO! (except it doesn't do that when I have Spotify playing)
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Rolin
        Onkyo/Integra DBS-50.2 Blu-Ray Player - Won't turn on or shuts off immediately.
        by Rolin
        I have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2,...
        09-07-2024, 12:11 AM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • RdeveLabs
        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
        by RdeveLabs
        To all the members here...
        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
        05-05-2025, 04:59 AM
      • robante15
        Acer Aspire 4520 won't turn on after reboot
        by robante15
        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
        If I remove the...
        04-06-2024, 06:50 PM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
