Onkyo/Integra DBS-50.2 Blu-Ray Player - Won't turn on or shuts off immediately.
  • Rolin
    • Apr 2007
    • 174
    I have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2, so maybe that's the problem? I found what I think is the correct part at https://www.digikey.com/en/products/...ampaign=buynow
    I'm a novice at this and really don't have a lot of experience. But with some luck I've fixed a few things in the past - also received some great help from this forum as well. Really would appreciate some advice and guidance. Thanks
ID:	3426300 Click image for larger version
ID:	3426301 Click image for larger version
ID:	3426302 Click image for larger version
ID:	3426303 Click image for larger version
ID:	3426304 Click image for larger version
ID:	3426305 Click image for larger version
  • lotas
    • Jan 2016
    • 4840
    • Russia
    These regulators are controlled, that's why they have 4 pins.
    The controller must give a command to turn them on (PWSW) - Power Switch and then the output voltage will appear.​
    • Rolin
      • Apr 2007
      • 174
      Thanks for that info. I had the other boards disconnected to help isolate whether this board was the issue. Reconnected CN1003 to CN6101 (main board) and reconnected the front panel connector for the power button (left connectors to other boards disconnected). Pressed the power button and 3.3 volts is momentarily present then drops off. Looks like the problem is elsewhere. Too bad, hoping for a simple fix. I'll dig deeper and see if I can find anything obvious - but I welcome any suggestions.
      • nervous_capybara
        Repairing the Hitachi DA-6000 CD player
        by nervous_capybara
        Hello everyone !
        I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
        Feel free to share your experience if you ran into other issues.
        DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
        CD tray would not come out of the player
        I could hear a motor spinning inside the player but the CD tray would not come out.
        Turned out that the issue was the CD tray belt that aged poorly and began to...
        11-05-2025, 03:11 AM
      • Tom_x
        Onkyo grand integra schematic!
        by Tom_x
        Hi friends!
        I'm looking for schematic diagram for Onkyo grand integra A-G10 (A-8890)
        speaker relays not activated, maybe protection circuit blocking.
        If i power on for a minute, and power off and on again, speaker relays activated and unit working.
        thx
        Tom
        12-02-2023, 01:30 PM
        MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
        This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
        09-06-2024, 05:30 PM
      • kokopelli75
        Victrola multi-player - No audio
        by kokopelli75
        Hello!
        My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
        01-11-2025, 03:51 PM
      • huzo
        HP Omen shuts down when loading OS
        by huzo
        The model is 15ec-1061nm
        Board number is DAG3EDMB8D0​
        SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
        10-29-2024, 12:05 AM
