Vizio E60-E3 No power, No standby light
  • nomoresonys
    • 12274
    • U.S.
    Re: Vizio E60-E3 No power, No standby light
    might be a bad ir sensor board, are the connections to it ok? unless all 3 remotes are not compatible: https://www.google.com/search?source...ih=607&dpr=1.5
    • x_orange90_x
      Vizio E550i-A0 no power, no standby light
      by x_orange90_x
      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
      11-20-2023, 09:49 AM
    • AleMonti
      LG 55EG910V - no power and no standby light
      by AleMonti
      I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
      I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
      The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
      After checking the basics I did the following:
      • I measured all voltages and as expected the only active supply is the 3.5V standby. It
      11-04-2024, 05:02 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • SkishyIshy
      Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
      by SkishyIshy
      Hey All,
      I have a Sony 65x900f that I purchased cheap because of a no-power issue.
      I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
      I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
      03-17-2021, 11:44 AM
    • noinimod
      Sony 55X900E no standby light, no power. Replaced mainboard already
      by noinimod
      No standby red light, nothing
      This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
      Disconnected JK3 power board from main board, checked voltages on all the pin outs
      At a few pins I can see the power supply providing 19.5V to the main board
      Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
      LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
      12-22-2021, 12:58 AM
