Sony KDL 32L4000 Troubleshooting
  • Eaglecrest
    • Jul 2018
    • 147
    I have this LCD TV and am told it was working fine, but just went dead. Plug it in and I hear a click, but no lights other than the optical audio out.
    Attached are three pictures, one a wide picture of the back, the second of the power board and the third of the main board. I couldn't quickly figure out how to remove the shielding for the main board and will need to investigate further if necessary; however, i am trying to figure out if I need to go there.
    To start with let me set the understanding that my knowledge is very high level and my terminology may be rather inexact. I would be interested in a component level fix if possible, but a board level fix may be sufficient.
    I tested the voltages with the power supply plugged in, but CN201 and CN202 unplugged. CN201 has two connectors -- one going to the main board and the other going to the inverter board. CN202 has a PS On, Power Err Det three grounds and three 4 VSB markings. With nothing plugged in the PS On shows 4.17 V and three 4 VSB posts change voltages over the range of about 4.03 to 4.20 (continually changing readings). Nothing on Power Err Det. No voltages detected on CN201.
    If I plug all the connectors in two of the 4 VSBs have a connection and both read 4.17V; zero volts on Power Err Det. and PS On shows .08V. CN201 has 24V and ground on the top connector which goes to the inverter and the lower connector (middle one of the three) shows 1.13V on the Pwr 6V connections, .44V on the Pwr Panel connections, .87V on the 15V connections and .01V on the 30V connections.
    These readings would lead me to believe the power supply is bad. As previously stated, pushing the power button on the top of the TV does nothing (i.e., TV seems dead), though i do notice that the optical audio light is on. My understanding is that the main board waits to be energized by the power button being pressed and then turns on the set. So i am suspecting that the fact i am getting 4.17V on PS On when nothing is connected means the power supply is good and that the main board is not energizing the TV when the button is pushed. Which I am guessing would then generate the voltages shown with CN201
    I am not sure if that is a correct understanding and would appreciate corrections to my thinking if necessary. I also suppose that the power button could be malfunctioning, but I do not suspect this because I am told the TV was working and just turned off and would not turn back on.
    I can check other things and get other/better pictures, but first would like to know if the above understanding is correct.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Sony KDL 32L4000 Troubleshooting
    It makes for easier reading if you could give the voltages at the connectors when in standby and out of standby in a similar format as shown.
    • Eaglecrest
      • Jul 2018
      • 147
      Am i correct in understanding standby to mean plugged in, but power button not pressed? If this is correct then not sure what you want for out of standby since I have mentioned that nothing happens when the power button is pressed.
        We are looking to see if any of the control signals change state at all when TV is in standby and when power switch is activated, that is what we NEED right now.
        • Eaglecrest
          • Jul 2018
          • 147
          I read the LCD TV link and put together the voltage chart attached. This is the same information I shared originally. To make sure my terminology makes sense. Standby means the measurement with all connectors attached and the plug connect to household current. Powered means that the measurement was taken while the power button on the top of the TV is being pressed. Please note there is no difference in the readings and nothing happens when the power button is pressed. Lastly if i read the pins on 202 with the connector removed I get the power readings noted and the Relay RL1 continuously clicks.
          If I understand the LCD tutorial the readings on the power board indicate that power is generated and sent to the main board; however, the main board is not generating the voltages needed to start up the set. Is this a correct understanding?
            "Lastly if i read the pins on 202 with the connector removed I get the power readings noted and the Relay RL1 continuously clicks."
            Which connector removed, the CN202?
            • Eaglecrest
              • Jul 2018
              • 147
              Yes. Remove the connector, plug in the TV and test the pins to which the connector attaches.
                But in your PDF you indicated '202 ONLY PLUGGED IN' and that causes the relay clicking. I just want to make sure we get the correct DATA.
                  If you do not have any connectors connected to the power supply board except the AC power cord, is the RL1 still clicking when you plug the power cord into the AC outlet?
                  • Eaglecrest
                    • Jul 2018
                    • 147
                    Yes. With 201, 202 and 203 disconnected the relay clicks slowly.
                      OK, your power supply board is Sony 1-857-108-11 Power Supply
                      http://www.shopjimmy.com/sony-1-857-...pply-unit.htm#
                      That power relay should not be turning on and off when the power supply board is running by itself.
                      I found the schematic for it:
                      Per schematic, the PS-ON signal in this case is active LO, <1VDC at PS-ON = the rest of power supply come on, you did indicated that the PS-ON pin is 0V when all connectors in place and you should notice that relay RL1 clicks on. So it does not make sense that the replay is clicking on and off when the power supply board is not connecting to anything.
                      • Eaglecrest
                        • Jul 2018
                        • 147
                        Thanks Budm, it is the end of my day. I will investigate this further.
                        Mike
                        • Eaglecrest
                          • Jul 2018
                          • 147
                          Budm,
                          I looked over the info and don't understand where you are getting the fact that PS-ON is active low. However, it is < 1VDC when all three connectors are attached. In that state, when power cord is plugged in I hear a RL1 clicks once, but nothing comes on.
                          RL1 continuously clicks whenever connector 202 is not connected, the other two connector's status makes no difference. It clicks about once/second and about double that rate, once unplugged, until it stops (drains?). I mistakenly stated on the chart that PS-On cycles between 4 and 4.25 VDC with 202 only connected, what should have been stated is the this happens whenever 202 is NOT connected.
                          So when 202 is disconnected PS_ON is > 1VDC which would make it in active. Would that cause the relay to keep trying to energize and keep clicking on and off?
                            Budm,
                            Well, if you look at what the PS-ON pin is connected to in the schematic, you will see that it connected to PNP Transistor then you will see why it is ACTIVE LO, that is why RL1 is turned on when all the connectors are in place, you can easily check the DC Voltage on the two legs of the relay coil.
                            • Eaglecrest
                              • Jul 2018
                              • 147
                              Budm,
                              Thanks, as I mentioned my knowledge level is low, but I would like to understand better. Are you willing to help walk me through a better understanding, or is that asking too much? If so better to do so through this forum or offline?
                                Well, you will need to learn the basic first such as how Transistors, MOSFET's, Diode function, knowing the Ohms laws, knowing how to read schematic symbols and diagrams. It will not be just a walk through without knowing the basic first and apply that knowledge to what you are trying fix.
                                Lots of free electronics learning out on the web.
                                • Eaglecrest
                                  • Jul 2018
                                  • 147
                                  I have no doubt about that and to understand all the design parameters of the electronics I am looking at will take quite a bit of learning. I am thinking that at the macro level, perhaps less depth can still be useful.
                                  I assume the tutorial, "LCD Flat panel TV troubleshooting guide by Bud Martin" is your work piece. At the macro level it states that the power supply board creates the voltages for running the various boards and supplies them as needed. The main board controls the logic and drives the actions of the other boards. The inverter and TCon control translation of the video signal into the visual representation on the LCD panel.
                                  An LCD TV is always powered with a standby voltage that allows to TV to sense a turn on command either from the power button or from the remote control. Once this signal occurs the TV is energized to turn on the rest of the circuits to allow it to accomplish its task of displaying video inputs.
                                  All the boards are, obviously, tied together and if one is out or malfunctioning then the final output will be inferior at best. If the TV is dead it could be because the power board is bad or because the circuit that reacts to the "turn on signal" is bad. What I am trying to understand is how this works at the macro level.
                                  On this set there are no status lights on, no picture, no sound. Power is making it to the connector 202 pins, but no other pins have power. I recall reading somewhere that the other voltages don't get generated until the power on operation is completed so I am assuming that the 201 and 203 voltages are absent for that reason and not necessarily because the power board is bad.
                                  The tutorial states "The power supply has Standby 5vdc ... which is always on the minute the TV is plugged into the AC outlet". This TV does not have 5 VDC, but does have 4 VDC which I am assuming is the standby voltage. If that is correct then I have a standby voltage, but the TV is not turning on when signaled to do so. Assuming this understanding is correct the following questions come to my mind:
                                  1. [1]Voltage reads 4.16 VDC is this acceptable for a 4 VSB requirement or is this an over voltage?
                                    [2]Is the monitoring of the power on signal done on the main board?
                                    [3]Is it a correct understanding that either pin 3 or 7 on 202 is feeding the "signal on" monitoring circuit?
                                    [4]What does the other 4 VSB pin do?
                                    [5]The tutorial states "the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin)" Since the voltage reading for PS-ON is .08 it appears that the turn on voltage is not being sent by the microprocessor. Correct?
                                    [1]Voltage reads 4.16 VDC is this acceptable for a 4 VSB requirement or is this an over voltage? 4.16V is fine, it is <5% off, the higher reading can also be due to your meter calibration.
                                    [2]Is the monitoring of the power on signal done on the main board? The main board send out PS-ON steady signal. most TV's use active high (>2vdc = on <1V = OFF, but your TV uses active low.
                                    [3]Is it a correct understanding that either pin 3 or 7 on 202 is feeding the "signal on" monitoring circuit? cn 202 Pin 1 is an input pin for PS-ON pin, pin 2 is for the output pin for Power supply error signal to tell the main board the condition of the power supply. Pin 3, 7, and 8 are output pins for 4V Standby Voltage to run the main board.
                                    [4]What does the other 4 VSB pin do? If you look at the traces you will see that 4VSB pins are all tied together.
                                    [5]The tutorial states "the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin)" Since the voltage reading for PS-ON is .08 it appears that the turn on voltage is not being sent by the microprocessor. Correct? Your TV uses active LO, you can easily verify that by check the DC Voltage on the two pins of the relay coil when all the boards are connected together and the PS-ON pin showing 0 V.
                                    Sony 1-857-108-11
                                    Pictures provided by shopjimmy.
                                    • Eaglecrest
                                      • Jul 2018
                                      • 147
                                      As you have mentioned my TV is active low. So if I understand that, a low voltage from the microprocessor turns on the switch to energize the TV. It is has .08 VDC on PS_ON which should turn on the TV, but it doesn't so, therefore, the assumption would be the Power board is bad.
                                        It is turning on the power supply because the relay RL1 is on based on your report that the relay clicks on (as I already indicate as how you can tell by checking the DCV of the relay coil) but the rest of the power supply did not come on as you can see that the 6V,15V, 24V, and 30V did not come on.
                                        So right now the power needs to be fixed first to get all those Volages.
                                        • Dogindelusion
                                          Sony XR-77A80K 5 Red Blinks Troubleshooting
                                          by Dogindelusion
                                          Hi everyone! I am a new member and am new to electronics repair. I have a background in electrical engineering, but little experience in electronics.
                                          I have a Sony XR-77A80K which will not turn on and has 5 blinking red lights in the stand-by light. I had previously done a forced factory reset, which removed the error code, and the TV regained functionality for a few weeks. I repeated the factory reset and again regained functionality. This happened a few times until I so I had to begin troubleshooting the error.
                                          Observations:
                                          1) I noticed I was not getting...
                                          08-09-2023, 09:44 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                        • Awsmessymail
                                          Vizio E701i-A3 backlight only and now no backlight
                                          by Awsmessymail
                                          Hello all,
                                          I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
                                          I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
                                          As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
                                          02-13-2024, 11:04 PM
