LG 32le4900 issue
  • jonny78
    • Apr 2017
    • 72
    • United Kingdom
    LG 32le4900 issue
    Hi again guys! Got this set and the problem is the set turns on fine but there's no picture! Took the back off and no obvious signs of damage.
    But when the cable connecting the mainboard to the psu is connected at an angle like this "/" the backlights come on but there is still no picture! All voltages are correct from the power cable to mainboard except the second to last 24v which sparked when I tested it with my multimeter and has left a slight burn mark... I've posted a pic of the voltage chart and the damaged caused by multimeter on 24v point! Will post further pics soon! There is a thread about this TV but the advice was to resolder some points but I've done this and it hasn't helped!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 32le4900 issue
    Check the solder joints of the connector and it's plug and resolder if necessary. Are any of the connector /plug pins burnt where they connect ?
    • jonny78
      • Apr 2017
      • 72
      • United Kingdom
      Solder points look fine but I've resoldered anyway but makes no difference! Like I said the one of the 24v pins sparks when I test it with multimeter! I've attached a couple of photos to show you how the backlights come on when cable put in at a particular angle!
        So what Voltages do you have on all those pins of the connector per Voltage chart?
        Can we see the pictures of the bottom side of the board where the connector is?
        You have three 24V pins, so only one of the the 3 pin sparks?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I've put a circle around one of the pins which appears to have some staining on?
          • R_J
            • 9556
            I think he made that mark during testing, shorting that +24 volt pin to ground
            When that plug is at that angle you are removing the error signal from the led driver board
            You could also check if you have 12 volts on the t-con board fuse, the fuse seems to be just left of the lvds cable and marked [P]
            • jonny78
              • Apr 2017
              • 72
              • United Kingdom
              Yes I did! I think it might have been my fault! Here are the voltages
              1..NC ERROR = 0
              2.. PDIM=12
              3...ADIM=12
              4...DV_ON=12
              5... GND=0
              6...GND=0
              7... 3.5v=3.5v
              8....3.5v=3.5v
              9.....GND=0
              10. GND=0
              11...24V=24V
              12...ON/OFF=3V
              PIN 11 24 VAULT WAS THE ONE THAT SPARKED AND CAUSED THE MARK (USER ERROR I THINK) but is now reading 24v
              Cheers!
              • jonny78
                • Apr 2017
                • 72
                • United Kingdom
                OK will check tcon!
                • R_J
                  • 9556
                  There are 2 rows of pins (24 total) on that plug that goes to the main board the pins you labeled 2,3 & 4 are just +12 volts, the PDIM, ADIM, DV_ON are on the other row
                  On 1..NC ERROR = 0, you are checking the NC (no connection) pin not the ERROR pin
                  • jonny78
                    • Apr 2017
                    • 72
                    • United Kingdom
                    my mistake! ok will check all voltages and report back!
                    • Nairolf
                      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                      by Nairolf
                      I have a Samsung DM32D display.
                      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                      Here’s what I have tried so far:
                      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                      From these tests, I suspect the problem might be on the mainboard. Could anyone...
                      Yesterday, 03:47 AM
                    • harshana
                      DA0ZPVMBAD0 rev d Mainboard - blank screen issue
                      by harshana
                      I have the DA0ZPVMBAD0 rev d logic board and it doesn't boot up. I see all the voltages are okay. So I suspect the issue is bios.
                      When I power on with fn+ esc the blue light start blinking on mainboard.
                      I guess its a good sign. As all the voltages are okay and also charging indicates orange light when battery connected, I think it confirm that the EC bios is okay. So I ignored the ec and flashed main bios with 32mb bin file provided in the link below. But the condition is same.
                      https://www.badcaps.net/forum/troubl...and-electronic...
                      08-16-2025, 02:16 PM
                    • alltvrepairs
                      Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
                      by alltvrepairs
                      I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
                      This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
                      Any help appreciated!...
                      03-14-2024, 03:39 AM
                    • Stephen
                      A2141 MacBook Pro 16" lid sensor issue.
                      by Stephen
                      Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                      11-01-2024, 03:45 PM
                    • dbuergi
                      PS5 Dualsense controller stick drift a mainboard issue?
                      by dbuergi
                      I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
                      I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
                      05-02-2025, 05:00 PM
