DA0ZPVMBAD0 rev d Mainboard - blank screen issue
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    I have the DA0ZPVMBAD0 rev d logic board and it doesn't boot up. I see all the voltages are okay. So I suspect the issue is bios.
    When I power on with fn+ esc the blue light start blinking on mainboard.
    I guess its a good sign. As all the voltages are okay and also charging indicates orange light when battery connected, I think it confirm that the EC bios is okay. So I ignored the ec and flashed main bios with 32mb bin file provided in the link below. But the condition is same.
    https://www.badcaps.net/forum/troubl...-d-aspire-vero
    Do we need to modify this bios file before flash?
  • lapfix
    • Mar 2020
    • 2765
    • my workshop
    Better you upload your bios + seriak number+model exact...and someone will help you to get the appropraite bios for your lap
    • harshana
      • Aug 2022
      • 216
      • Sri Lanka
      MainBoard model number: DA0ZPVMBAD0 rev d
      here I upload the original main bios backup. any luck?
      Also is there any way to move this thread to BIOS request category?
        • 22188
        Better you upload your bios + seria number+model exact...and someone will help you to get the appropraite bios for your lap
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          Acer Aspire Vero N22Q21
          AV14-51-58AK
          S/N: NXKBNEM001251050927600
          issue: Blank Screen
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • alltvrepairs
            Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
            by alltvrepairs
            I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
            This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
            Any help appreciated!...
            03-14-2024, 03:39 AM
          • dbuergi
            PS5 Dualsense controller stick drift a mainboard issue?
            by dbuergi
            I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
            I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
            05-02-2025, 05:00 PM
          • mmartell
            Sony KDL-65W850C is this a Mainboard issue ??
            by mmartell
            This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
            Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
            It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
            11-19-2023, 10:27 AM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
