Blinking 10x Philips 32PFL3008K/12 - VESTEL 17MB95-2.1 and 17IPS19-5 17IPS19-5P V.1
  • Folxs
    • Nov 2016
    • 167
    • Poland
    Hi, I have Philips LED TV 32PFL3008K/12 that blinks 10 times and doesn't turn on.
    It is cheapo VESTEL made TV.
    I measured all the diodes on power supply, some voltages and they are ok, I suspect mainboard - but there are so many variants of firmware so I need some help to find right one.
    There are NAND 28F1G08ABAEA (U13) and 25L1606E (U10)
    LCD Panel is VES315WNDB-01 (more info on sticker)
    Can I maybe reflash NAND from USB?
    I can also write on 25L1606E - I have TL866A programmer
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Blinking 10x Philips 32PFL3008K/12 - VESTEL 17MB95-2.1 and 17IPS19-5 17IPS19-5P V
    What made you guss Main bd. Did you do any voltage measurements, etc??
    • Folxs
      • Nov 2016
      • 167
      • Poland
      Yes, on main connector PL200:
      PIN 5 24V
      PIN 7 12V
      PIN 11 5V
      PIN 15 3.2V
      PIN 17 0V
      PIN 19 24V
      PL501 (LCD Supply) 24V is OK
      Also whole system takes about 12W from wall (I have Power meter)
      PL201
      PIN 1 3.2V
      GND OK
      24V OK
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        From what I see here your Main Bd. is working. I didn't see a pin labeled PS-ON, but I am guessing here that this is working as the other PSU derived voltages are present. On the other hand you could be right as the software could be corrupt and causing the no-start-up issue. Did you test the backlights to see if they are faulting the system?
        • Folxs
          • Nov 2016
          • 167
          • Poland
          I think that this ST_BY have role of PS-ON
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I think its pin 17, ST_BY active low.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Yes, I think so too. Any testing of the Backlights?
              • Folxs
                • Nov 2016
                • 167
                • Poland
                so, ground the signal down to see what will happen?
                not yet - is there converter inside the panel?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  No. From what I interpret the Red ad Black wires go to the backlights directly from the PSU. Is this correct??
                  • Folxs
                    • Nov 2016
                    • 167
                    • Poland
                    Yes
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      With the set off connect the RED probe of the DMM to the red wire and the BLACK probe to the chassis GND. Turn on the set and record your findings. Take the set off and attach the RED probe of the DMM to the black wire and the BLACK probe to the chassis GND. Turn on the set and record your findings. Report your findings.
                      • Folxs
                        • Nov 2016
                        • 167
                        • Poland
                        On red wire:
                        When I tries to turn on TV voltage is ramping to 46.3V and alowly goes down to 0V
                        On black wire:
                        Ramping to 100V and slowly goes down to 0V
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          That's 53.7V difference between them. Looks OK, unless there is a shorting LED that is trying to pull a larger current and shutting down the LED Driver. Well you have another Main Bd. with Driver on the way. Try that and maybe it would work.
                          • Folxs
                            • Nov 2016
                            • 167
                            • Poland
                            So now You suggest to check all LEDs?
                              https://www.ebay.ie/itm/2-X-STRIP-LE...W/112676310576
                              Base on your panel model number provided, it looks like it has two LED strips with 22 LEDs total.
                              The supply Voltage went up to 100V (which is the maximum Voltage rating of the Boostconverter output filter caps C514, C515 which means the power supply is not seeing the load so it goes into OVP shutdown.
                              The Cathode return of the LED string goes to GND via PIN11 (LED 1) of the IC 500.
                              So it can be that the LED string has open circuit some where, or the LED 1 pin is not PWM on. Having the LED tester will be good to have at this point.
                              • Folxs
                                • Nov 2016
                                • 167
                                • Poland
                                Ok, I will check the diodes tomorrow - thanks for advice!
                                • Folxs
                                  • Nov 2016
                                  • 167
                                  • Poland
                                  I couldn't fall asleep - one LED was burned open, I installed LED from other TV and now everything is working fine
                                    Thanks for the follow-up, make sure to turn down backlights level to as low as possible for all inputs.
                                    • Folxs
                                      • Nov 2016
                                      • 167
                                      • Poland
                                      I will
                                      • unimatrix93
                                        JVC lt-32hg35e (Vestel) blinking LED
                                        by unimatrix93
                                        Dear forum,
                                        I'm stuck with this old TV unit.
                                        PSU: 17PW04-1
                                        MB: 17MB62-1
                                        Symptoms:
                                        - Blue LED constantly blinking when connected to AC.
                                        - Only sigh of life is beeping when touching the capactive buttons on the front.
                                        Diagnostics so far:
                                        Checked the PSU output voltages:
                                        12V present
                                        5V present altought its only around 4.2V
                                        3V is present measured 3.4V.
                                        I check TP 202 which is for the short circuit protection: 0.606V on diode mode
                                        Since I met with some vestel models before with similiar symptoms...
                                        05-03-2024, 03:18 AM
                                      • unimatrix93
                                        Inexive (Vestel) TV constantly blinking after plugging in
                                        by unimatrix93
                                        Hello everyone, I have a constantly blinking Inexive LED TV.
                                        Display is: VES390UNVA-2D-N01
                                        Mainboard: 17MB97​
                                        PSU: 17IPS71
                                        The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help....
                                        03-26-2025, 08:36 AM
                                      • KevinWysocki
                                        Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
                                        by KevinWysocki
                                        Hi there,
                                        My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
                                        At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
                                        After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
                                        Flash upgrade didn't seem to work,...
                                        08-20-2023, 09:45 AM
                                      • Jaime Morillo
                                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                        by Jaime Morillo
                                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                        The TV was stuck on the logo and I couldn't access the update menu.
                                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                        The image result was good, but the image is inverted.
                                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                        08-18-2025, 11:38 AM
                                      • Sharpa
                                        Repair attempt Philips 55OLED804/12
                                        by Sharpa
                                        I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                        The symptoms when bought: Philips logo appears then tv turns off
                                        Things tried so far:
                                        1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                        2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                        Today, 08:30 AM
