Weird Custome Built 55" LED Monitor
  • Michale32086
    • Nov 2011
    • 1453
    Got a weird one in..
    It's a custome built 55" LED Monitor.. Just has DB15 and DVI hookups..
    I push the power button and the LED Power Light goes GREEN, then RED after a few seconds.. After a min or so, the Power LED starts blinking red...
    There were some loose pads on the TRACE side of the Power PCB. I fixed those and still have the same problem..
    All the other components on the Power PCB and the "Main" video board look OK..
    Voltages look OK.. I get around 175V steady on the LED connector
    At this point, I am leaning towards a bad LED Strip, but I want to exhaust all other possibilities before I break it down that far...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Weird Custome Built 55" LED Monitor
    It gives the led driver voltage on the board but I can't read it. Have you applied a signal. Some computer monitors turn off if no signal present.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      The Backlight LED strips seem to be connected in parallel and what you are seeing is perhaps an open string . Measure WRT GND the -ve pin voltage as you said you have 175V on the +ve pin.
      • Michale32086
        • Nov 2011
        • 1453
        These help???
        ACK!!!! Good point!!!!
        Lemme do that..
        • R_J
          • 9625
          If you have 175 volts across the led leads going to the panel the led's should light up unless the circuit is open, open led or open connection on a plug etc.
          • Michale32086
            • Nov 2011
            • 1453
            OK It does appear the be the backlight issue.. The LED Power light goes green and I can see a latent image on the screen from a laptop...
            Andrew, can you simplify the WRT GND -ve thing??? Am a little slow this morning.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              WRT GND.....With Respect To Ground....The RED lead on the -ve pin and the BLACK lead to chassis ground.....to check if you have return voltage to the Driver....NP (No Problem)
              • Michale32086
                • Nov 2011
                • 1453
                0v or, more accurately, .003mV
                • Michale32086
                  • Nov 2011
                  • 1453
                  Yea, it's beginning to look like I may have to crack this puppy open..
                  Not looking forward to that...
                  On the plus side, I don't have to take off the plastic backing or the front bezel.. There is none.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Yes it ls looking like a possible led fault. If you measured Vled at 170V and the panel says 108 - 120V then it's probably the open circuit voltage.
                    • Michale32086
                      • Nov 2011
                      • 1453
                      OK Well, at least I know it's likely the problem.. OK Cracking it open after lunch...
                      Thanx for all the replies...
                      • Michale32086
                        • Nov 2011
                        • 1453
                        That did it.. It was a bad LED strip.. Found a replacement that I could wire in and we're all good.
                        Using those suction handles makes taking off the largest panel a breeze.. I kick myself that I didn't get these sooner...
                        Thanx to all for all the help...
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Always nice to have a happy ending.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Good job.
                            • Michale32086
                              • Nov 2011
                              • 1453
                              "Indeed"
                              -Teal'c, STARGATE SG-1
                              Good job.
                              Danke..
                              • SLK001
                                • May 2014
                                • 264
                                Are you referring to the Harbor Freight dual suction cup lifters we discussed earlier?
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  I am indeed.. They are a godsend!!! I bought 2 sets, the orange singles and the red duals.. I have used the orange singles exclusively as the panels I have been moving are 50" and lower.. I am wary about the red ones because the suction is pretty intense. But will likely use them on my next 70" +...
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    A 'must have' tool when doing Panel backlight issues.
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Yea, when I think back on all the TVs I could have saved had I had these...
                                      Especially that REALLY nice 70" 4K Ultra HD....
                                      Oh well, we go on...
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        That's for sure!!
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
