Insignia NS-55D420NA16 Backlight Problem
  • nomoresonys
    • 12323
    • U.S.
    #41
    Re: Insignia NS-55D420NA16 Backlight Problem
    I would indeed use suction cups.
    • letienne
      • Aug 2019
      Using LED backlight tester to apply voltage to my Insigna NS-55d420NA16, I get 331 volts on the tester. The power supply was disconnected. None of the LED's light. Is the wire between the power supply connector and the first LED strip open?
        You have open circuit, I.E. broken wire/s, LED, connector/s between LED strips.
        • zape
          • Jul 2017
          • 176
          I fixed mine. It had two failed LEDs, one of them burned in a way it damaged the traces on the led strip so it had open circuit.
          • nomoresonys
            • 12323
            • U.S.
            #45
            Glad to hear it, nice save.
            • letienne
              • Aug 2019
              I found one the LED's was open. When I tried to remove the bad led with a hot plate. The LED broke into parts. The part that was soldered to the smaller pad did not want to unsolder because the connection to board foil are via a plated thru hole and trace. Only 3 of the 11 strips were without bad LEDs. I replaced all of the strips with new ones. When I put everything back together without the back, I got a great picture. I next installed the back and base. When I set the TV on a stand, I powered the TV back on I had a crack in the screen. I don't know if the crack happened after installing the back or after setting the TV on the stand.
              • zape
                • Jul 2017
                • 176
                Did you use suction cups?
                I did as recommended above and everything went well.
                I also watched shopjimmy's video and identified the suction cup model they use:
                https://www.homedepot.com/p/QEP-4-7-...000Q/100119050
                • Toocheap
                  • Sep 2020
                  I have the same TV with a bad LED strip. I was able to isolate the one bad LED, and I have removed the LED from the PCB. Anyone know where I can find the correct LED for my LED strip so I can fix this strip and get this thing back up and running? LED strip PN: 4C-LB550t-GY2
                  • hoangmai
                    • Feb 2014
                    • usa
                    #49
                    If you need the set, you can get from here:
                    https://www.shopjimmy.com/hisense-in...5d420na16-new/
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • lostone
                      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                      by lostone
                      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                      05-19-2024, 11:40 AM
                    • triplefour
                      TCL 75S421 has sound but no backlight not even a flash
                      by triplefour
                      TCL 75S421
                      PSU BOARD: 40-L402H8-PWD1CG
                      it shows not even a flash of backlight when powering up.
                      but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                      testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                      unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                      i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                      with mb connected, PSON...
                      11-17-2023, 09:54 PM
