Insignia NS-55D420NA16 Backlight Problem
  • angelos
    replied
    Re: Insignia NS-55D420NA16 Backlight Problem
    When measuring the LED voltage you put your black probe on Chassis earth and measure on the RED wire (Anode). According to what i read on this post the voltage should be around 200VDC. You probably have an "open" LED and that's why the voltage spikes at 400V.
    Take great care when opening the panel as to not break the screen. My experience is almost every time i had a problem like this it turned out to be backlight LED's that had failed.
  • Betviper
    replied
    **First post** Man that sucks. I have the exact same TV but when I check my red/white wires going to the LEDs I get a spike of a little over 400DCV then back to almost 0DCV. I am trying to remember if that was across the red/white or red only and to chassis for ground. (it's been a few weeks) My backlights do not even flicker. With the red/white wires unplugged I get 0DCV on both pins. My voltages on my 10 pin output are the same as yours. Not sure if I should order the LED tester or if it is the LED driver on the powerboard. Anyone have any suggestions for a newbie? Thanks
  • Andrew F. Ali
    replied
    Shit happens. Even to some of us who should know better. Don't worry as this exercise is not a total loss. You learnt a few things in the process. Cheer up.
  • Stu71584
    replied
    Originally posted by mmartell
    I might need the strips from this. Let me know if you're selling.
    sure shoot me a message if you want them...
  • mmartell
    replied
  • attainteddragon
    replied
    yeah rather broken.
  • Stu71584
    replied
    Ok update. So I got everything to power up but unfortunately I think I damaged the panel itself during the process. I'm posting a picture so one of you can confirm my diagnosis. So close!
  • Stu71584
    replied
    Ok so I replaced the LED strips and tested them with my tester and they all light up. I reassembled the filters and the panel and tried testing it and now I get no picture or backlight whatsoever. I checked for voltage on the led connector from the power supply board and there is no voltage there. At one point in my testing I touched something on the power supply board and got shocked. I'm wondering if I somehow damaged it. Any thoughts before I replace the board?
    replied
    Take the Voltage reading using the your LED tester when you have new LED strips installed so we can see what the total Vf of the LED string is.
    So you have lots of shorted out LED's.
  • Andrew F. Ali
    replied
    Originally posted by Stu71584
    Update: tore down the panel and tested the strips. I found about 1/3 of the LEDs wouldnt light and one looked burned. i just ordered a set of replacement strips that will be here tomorrow so hopefully thats all i need. i will keep you all posted. thanks for the help so far!
    From what I have read so far, the new strips should get you TV up and running again.
  • Stu71584
    replied
  • Stu71584
    replied
    i guess next step is to take the screen apart and get to the actual strips. Thanks for the help so far guys. I will dig in tonight...
    replied
    I connected the tester to the two wires of the led connector without it being connected to the power supply board. The led tester showed 130 volts. I was able to turn the tv on and It showed a picture like this.
    What is the LCD panel model number?
    http://www.shopjimmy.com/insignia-sv...55d420na16.htm
    I am not sure if your LCD panel uses these LED strips or not, it has 66 LEDs.
    Your tester show 130V which is kind of low, your tester is putting out around 20 ~ 30mA so the Vf for each LED will be about 2.7V instead of over 3V when driven at full current.
    You may have some shorted out LEDs.
  • dick_barton
    replied
    It may be worth running it up again as you did above and in the menu turn the backlights down say to 50% and then reconnect the leds to the power board and see if the backlights stay on.
    The led tester does not supply the same current to the leds as the power supply does so you may have a led breaking down at a higher current.
  • Stu71584
    replied
    Originally posted by budm
    So you connect the LED tester to the LED connector which is still connected to the power supply board and TV is also turned on?
    What dose the LED tester meter show when you put the tester to the two wires of the LED connector without having it connected to the power supply board?
    replied
  • Stu71584
    replied
    Ok so I got my LED tester and plugged it into the led connector. I then powered the tv up and got a picture. I didn't notice any dim spots or areas of the screen so I don't think any of the leds are out. Would it be obvious if there were a problem with the leds themselves? I'm trying to avoid disassembling the screen if I can help it. Should I be replacing the power supply board now?
  • Stu71584
    replied
    Thats what im thinking. I have an LED tester coming today so i can check those out next.
  • dick_barton
    replied
    It is looking like a led or led strip connection problem.
  • Stu71584
    replied
    OK, there are two wires for the LED connector.
    Red wire is the Anode pin of the LED strip
    White wire is the Cathode return of the LED strip.
    So you are getting about 190V on the red wire and 0V on the wire?
    The 190v reading was across the two pins of the connector. red to red and white to black on my meter.
    I also ordered an LED tester to check the backlights as some of my research is leading me to believe they might be bad.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
  • triplefour
    TCL 75S421 has sound but no backlight not even a flash
    by triplefour
    TCL 75S421
    PSU BOARD: 40-L402H8-PWD1CG
    it shows not even a flash of backlight when powering up.
    but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
    testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
    unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
    i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
    with mb connected, PSON...
    11-17-2023, 09:54 PM
