Vizio E390VL no 12V
  • culcuhain
    • May 2016
    • 186
    • U$@
    Vizio E390VL no 12V
    Good afternoon!
    I present to you today's patient. An older Vizio E390VL my neighbor gave me since it was dead.
    Symptoms:
    1. Plug in. No standy lights or Vizio lights up.
    2. I have 5.2V on the 5.2V line between PSU and main. (5.18V Pins 1-3)
    3. I do NOT have 12V on 12V line between PSU and main. (0.00V Pins 8-10)
    4. 0.00V on Pins 11-14
    5. When jumpering Pin (5.2V stby to Pin 12) 12V lines still show 0.00V
    6. Pressing Power button does not change the voltages and doesn't seem to turn on.
    Since Main board is receiving the 5.2V and not returning any other voltages i assume the Main board is dead. Thoughts? Next test?
    Pics attached.
    Cheers and beers!
    Re: Vizio E390VL no 12V
    You should put down the pin number and follow by the pin name for each pin to make it easier for us the see what is going on.
    https://www.badcaps.net/forum/attach...7&d=1529176264
    1) Pin 12 is BL-ON pin not PS-ON pin.
    2) Pin 11 Remote on/off is the PS-ON pin
    3) To force on the power supply board, you MUST remove the connector that goes to the main board first otherwise you will damage the main board when you directly connect power supply pin to the control pin without using the resistor.
    4) ALWAYS use the resistor, 1K is typical, to do the force on incase you make the wrong connection.
      • 12330
      • U.S.
      There you go, do pin 11 and 5v stby with the resistor, see if those volts come back, I know it's the same thing that bud just said but so many people lately have just been skipping on to other things without doing these tests.
      • culcuhain
        • May 2016
        • 186
        • U$@
        Ok here we go. Brain cramp on the 5V to BL/ON. Long day Already.
        Jumpering Pin 1 to Pin 11 (5V stby to Power On) I get the proper 12V lines.
        Next up, jumper pin 2 to Pin 12 (5V stby to BL/ON) backlights come on.
        Bad main board, right?
        Been a few months since I last fixed a tv and now have like 16 to do. :S
        Cheers and Beers
        Last edited by culcuhain; 06-16-2018, 03:36 PM. Reason: changed from pin 23 to pin 12
          Status pin is 0 V?
          There is EEPROM, see if the problem matches the bad EEPROM PROBLEM.
          http://www.shopjimmy.com/catalogsear...q=Vizio+E390VL
          • culcuhain
            • May 2016
            • 186
            • U$@
            Originally posted by budm
            Status pin is 0 V?
            Correct. Pins 11-14 have 0V until I jumper the power on to standby. Will look at eeprom issue
            • culcuhain
              • May 2016
              • 186
              • U$@
              EEPROM is ordered. Will update after I receive and install it.
              • culcuhain
                • May 2016
                • 186
                • U$@
                No change with the new EEPROM.... Time to find a board. :S
                • culcuhain
                  • May 2016
                  • 186
                  • U$@
                  Found one. Part Ordered. Will update after it arrives. I will desolder this EEPROM and save it and the original for later. Cheers and Beers
                  • culcuhain
                    • May 2016
                    • 186
                    • U$@
                    Dead Main Board. Used board and I have the tv up and running.
                    • petehall347
                      • Jan 2015
                      • 4450
                      • United Kingdom
                      i always like a happy ending
                      • petehall347
                        • Jan 2015
                        • 4450
                        • United Kingdom
                        for fun check old board for shorts ..one example is audio chip .. but not thinking its that ..
                        • culcuhain
                          • May 2016
                          • 186
                          • U$@
                          Not a bad idea....
                          • zwazovole
                            • Feb 2019
                            Originally posted by culcuhain
                            Good afternoon!
                            Symptoms:
                            Pics attached.
                            Cheers and beers!
                            Here is something that may help others - see attached
                            • zwazovole
                              • Feb 2019
                              After reviewing my own notes, I made some changes to clarify and corrected a couple of errors on steps 8 and 9.
                              The revision is attached.
                              Good Luck.
                              • SS454
                                vizio e650i-a2 backlight flashes then turns off
                                by SS454
                                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                panel: au optronics T650HVN05.4
                                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                08-20-2020, 03:57 PM
                              • cheeky2
                                by cheeky2
                                05-25-2024, 03:27 AM
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • gavric
                                Vizio M70-C3 Half picture is bad, main board on its last leg?
                                by gavric
                                Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                When tv powers on vizio V logo shows nice on whole screen. picture 1
                                When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                When i click video to start playing picture goes black(like when you change...
                                09-02-2021, 08:55 PM
