LG 42LV 4400 Will not come on
  • davg
    • Sep 2008
    • 536
    Re: LG 42LV 4400 Will not come on
    Tks appreciate your advise. With the power button pressed I read 0.48v which I believe is 0 volts this is the same as just plugged in and sitting in standby.
      So the PS-ON is present but basically no VCC to run the PFC IC, so you will need to dig deeper down to component level by tracing out the board to locate the switched Transistor that supplies the VCC to run the PFC IC. It is not going to be easy but can be done, it is a matter of tracing the VCC pin back to the switched Voltage source.
        Parts for your TV:
        http://www.shopjimmy.com/catalogsear...q=LG+42LV+4400
        EEPROM:
        http://www.shopjimmy.com/lg-42lv4400...eprom-only.htm
        http://www.shopjimmy.com/lg-cov31310...2lv4400-ua.htm
        You may have problem with two boards.
        • davg
          • Sep 2008
          • 536
          Ya I am kinda rusty at this been several years since I've done this. I was looking for a schematic of the board but nothing so far.
          This problem seemed intermittent; my friend who owned the TV had the problem had it setting in the original box for about a year gave it to me to check it out when I got it home plugged it in it worked fine for a whole day before the condition came back. I turned it on and off several times then left it powered on for approx. 6 hrs when I turned it off for the night the next morning it would not power on???
          • davg
            • Sep 2008
            • 536
            Tks for the source but I do believe shopjimmy will not ship to Canada but I did source a used board on ebay
            • davg
              • Sep 2008
              • 536
              Will that switched transistor be located on the main power board or the logic board? should I have any other voltages present on the main board connector when the board is powered on in standby or just the 5 vdc present
                That switched transistor will be on the power supply board. Right now the power supply board is getting the PS-ON fine, it is the power supply board that is not working.
                • davg
                  • Sep 2008
                  • 536
                  Tks Budm truly appreciate it and since my skills are lacking and I can buy a replacement board for 60 bucks its a no brainer just wanted to make sure I was replacing the right board
                  • davg
                    • Sep 2008
                    • 536
                    Tks Budm just received the replacement board but the symptoms are the same have 5.2v stand-by power but still will not power on? Unless the two boards has the same defect leads me to think the problem must be elsewhere?
                      So the new power supply board with PS-ON forced on and still no PFC Boosted Voltage? If that is the case then your new power supply board is bad, you need to have that boosted Voltage when PS-ON is present.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        #31
                        Disconnect the connector going from the PSU to the Main Bd. I couldn't make out the pin Nos. from the poor quality pics you posted. Anyway, you would need two (2) 1k Ohm resistors. Connect one end of a 1k Ohm resistor on the pin labeled Std-By and the other end to the pin labeled PS-ON. Plug the PSU into the ac. Measure the other pin and see if the voltages labeled on the connector appear. If they don't then the PSU is no good. If they do, leaving the 1st resistor in place, connect the other 1k Ohm resistor on the Std-By pin and BL-ON pin. Connect the backlights and apply the ac. The backlights should come ON and stay ON. If it does that then the PSU is perfect if it doesn't then the PSU/Inv Driver has a problem.
                        • davg
                          • Sep 2008
                          • 536
                          That is quite possible since it is a used board?
                          • davg
                            • Sep 2008
                            • 536
                            Thank you Andrew sorry for the poor quality photo maybe this one will be better it shows the connector from the power supply to the main board. The pins are 1,2,3,- 5.1vsb (Remote_ on/off), 4,5,6,7 are ground, 8 & 9 - 12.6v, 10 - pwm1, 11 - pwm2, & 12 - pwm3 (BL_ on/off.
                            Not sure which pins are Std-By and PS-ON
                            • davg
                              • Sep 2008
                              • 536
                              Sorry I am not sure if I am reading the markings on this connector correctly?? I think the pins should be as follows; 1,2 Remote_ on/off, 3- 5.1VSB, 4,5,6,7 SGND, 8 & 9 - 12.6v, 10,11 BL_ON/OFF, 12 PWM1, 13 PWM2, 14 PWM3
                                DELTA DPS-131BP
                                LG COV31149501 (0500-0607-0240) Power Supply for 42LV4400-UA
                                Pictures provided by shopjimmy.
                                Pin 10 is the REMOTE ON/OFF (PS-ON) as printed on the board '(CN201 - 10) REMOTE_ON/OFF.
                                So the report on post #5 is not correct.
                                • davg
                                  • Sep 2008
                                  • 536
                                  DELTA DPS-131BP
                                  Thanks for clearing that up Budm so pins 1,2,3 are common 5.1 VSB. That means I do not have the 5 VSB on pin 10 ps-on? And there is still no voltage when the switch is activated
                                  • davg
                                    • Sep 2008
                                    • 536
                                    Following your instructions I do get 12v and the backlights will come on and stay on? so the PSU/Inver Driver test ok??
                                    • davg
                                      • Sep 2008
                                      • 536
                                      So the main logic board is not switching the 5vdc to the ps-on pin. Reading the troubleshooting guide would seem to indicate a bad switching transistor? What are the probable causes
                                      • davg
                                        • Sep 2008
                                        • 536
                                        DELTA DPS-131BP
                                        Maybe I should start a new tread since some of the info I gave is incorrect? However the symptoms are the same the unite will not power on. I have the red indicator light on the front, I have 5vdc standby power but I do not have the 5 vdc at the PS-ON #10 pin when the power button is activated (or should I have it always)? The power supply board tested ok with the 1K resister from standby pin to PS-ON pin and the backlights came on and stays on with the extra 1k Resister from standby to BL-ON pin. What would happen if I placed the 1K resister form SBP to PS-ON Pin with both boards connected? What should I look for that would cause the logic board not to switch the 5 vdc? or is the 5 vdc switched by activating the power on switch or the remote on switch. Where can I read to get more understanding of this process? I apologize if these are stupid questions but I am a learner with lots to learn and would take a lot of satisfaction from this to make it work.
                                          Right now the problem is on the main board, what the exact cause for it not to send PS-ON (<1Vdc = OFF, >2Vdc = ON) I do not know. You may try heating and cooling the main board to see if the PS-ON will be present or not.
                                          • cstout
                                            DeLonghi AC Remote only accepts 3V
                                            by cstout
                                            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                            I can't find any schematics...
                                            06-03-2024, 03:53 PM
                                          • Mc_Millian
                                            Toshiba 50lf711u20 fire tv remote not pairing
                                            by Mc_Millian
                                            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                            The Tv model number is: 50lf711u20 Rev B.
                                            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                            I've tried 3 different remotes which should be fully compatible with this TV.
                                            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                            The power button, along with the volume,back,select, and directional...
                                            04-07-2022, 12:15 PM
                                          • edugimeno
                                            HiSense 55A7500F won't obbey to remote after power on
                                            by edugimeno
                                            Hi! I have this TV set that does the following:
                                            1) I press the red power button on the remote
                                            2) The TV turns on normally
                                            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                            Then after it's off, it would again accept the TURN ON from the remote and same again
                                            BUT:
                                            -The remote does show the correct IR beam while observed thru a phone camera
                                            -The TV works fine while using the MiRemote...
                                            03-14-2023, 11:22 AM
                                          • rustinjust
                                            Please help, where can I get a remote for my subwoofer?
                                            by rustinjust
                                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there...
                                            10-28-2023, 03:43 AM
                                          • tmhobadcap
                                            Pioneer VSX-522-K remote control not working???
                                            by tmhobadcap
                                            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                            12-24-2020, 01:44 AM
