LG 47LD452B no power to backlights, blown fuse, shorted FETS, what did I miss?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    I picked up this LG 47LD452B today that tries but won't turn on. The stand-by light turns from red to blue then flashes red.
    I checked voltages and appropriate voltage is found at the power to main board connector including INV on/off, 3.2v/0v. The main caps switch from 165V to 395V when the power button is pressed. There is zero voltage at the backlight plug and no voltage on either side of the backlight transformers.
    So I pulled the LIPS and found the 4A 250V backlight protection fuse open. I checked the MOSFETS and three of them are reading shorted in-circuit.
    So my question is: it looks like I need to replace all 4 FETS, but I'm really wondering what else got taken out or what I may have missed, even if it's the mark entirely?
    Thanks all
    They call me......."threadkiller"
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: LG 47LD452B no power to backlights, blown fuse, shorted FETS, what did I miss?
    So how about it guys, can I get an opinion?
      Check all the parts connected to the GATE of the MOSFET.
      Those MOSFETs are driven by the isolation GATE drive transformers so I do expect the IC to be damaged when the MOSFETs shorted out.
      Verify that rectangular DC Blocker/coupling cap right next to the inverter transformer is OK, you need to remove it to check the capacitance and leakage resistance.
      The MOSFETs may have gone bad by itself or may be bad inverter transformers are bad.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        About how often do you see those inverter transformers bite the dust?
          Not very often on the failure on the primary winding, but the secondary winding does fail a lot so you may want to check the secondary winding resistance of both transformers to see how close they are with each other.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Ok I will do that this weekend.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              I went ahead and de-soldered the two MOSFETS, circled in red. They did test short across all pins.
              What I find interesting is the other two (outer, circled in green) do not appear to test short in-circuit, although it looks like they trace to different legs of the same transformers. Questions:
              Are these the isolation gate drive transformers you were referring to?
              Is electricity flowing from these to the MOSFETS?
              The item circled in yellow, is this the IC that is likely damaged?
              The backlight transformers and the two small transformers all test very close to short, not even an ohm primary or secondary. Funny thing is the readings are the same on all four transformers, leading me to believe something else in that circuit has to be shorted, or this is how they usually ohms-test?
              The other thing I find interesting is there are no signs of any transformer being overheated. The board is nice and clean under all of them.
                The two arrows are pointed to the Isolated Gate drive transformer, the IC is more likely to be fine when the MOSFETs shorted out since the circuit is isolated by the transformers, but the resistors and diodes connected to the GATE may be damaged which you need to check and verify.
                I would replace ALL 4 MOSFETs at the same time.
                The DCR (DC resistance) of the primary winding will be very low which is normal.
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  Budm, what are the items on the board marked "BD", and what is their purpose? Looks similar to a diode?
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    Ferrite Bead? (BD) For reducing noise?
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      "BDs" are ferrite beads indeed. That BD IC however is the backlight controller. Replace all 4 FETs, but just after you finish removing all of them, another test I'd do is (with no FETs in place, so nothing blows), check the datasheet for that IC and identify the VCC pin - measure it and make sure it's within spec. Assuming the TV functions properly but lacks backlight, the IC should have VCC and you should be able to get away with just replacing the transistors. If it's got a blown CCFL lamp however, you won't know until you try it. Fire it up without the lamps connected first to see if if blows the fuse again - it shouldn't. Let us know how it goes.
                      Wattevah...
                      • DXseekerMO
                        • Feb 2018
                        • 1119
                        • US
                        Is that the IC I have circled in yellow in the previous picture?
                        Thanks for the reply!
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Yes, that's the one.
                          Wattevah...
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            I looks up the datasheet and found the pin, I don't have a voltage spec unless it's somewhere I haven't seen just yet. Datasheet shows 4V nearby.
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              It should most definitely have the maximum/minimum VCC stated somewhere. Even the most obscure, most disgusting datasheets have them
                              Wattevah...
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                Pulled the other two FETS, they will not go in to "on" state. I will have to order fuses and try it with no FETS installed. I may have a fuse in another board I can steal.
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  What do you mean by this ? Do you mean you're not reading shorts across them ? That's fine, but still, whenever dealing with multi-FET arrangements like these it's a good idea to replace all of them nonetheless. Just like with a bridge rectifier made up of 4 individual diodes: if two pop, you don't replace just those two - you replace the entire set.
                                  Wattevah...
                                  • DXseekerMO
                                    • Feb 2018
                                    • 1119
                                    • US
                                    Completely agree, they were gonna be replaced no matter what. When I touch the probes of the voltmeter on diode mode, + on gate, - on drain FET is open. Touch + to source momentarily then touch it to gate and it's still open. What I meant is it looks like it won't switch on.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      Much easier to test diodes/FETs using the beeping continuity thingy on meters: it instantly tells you if a semiconductor is faulty if it beeps. FETs never/rarely(?) fail open - they always fail shorted, unlike resistors which is the opposite, so if you don't get a reading that means it's ok AFAIK, because it's a very high impedance device.
                                      Wattevah...
                                      • petehall347
                                        • Jan 2015
                                        • 4439
                                        • United Kingdom
                                        shorted is one thing .open is another that can happen pretty rarely . been there seen that . only once though.
                                        just a guess but are all those the fets same specs ?
                                        • EazyBone
                                          Un70TU7000b Backlights work, no picture, has sound, panel shorted caps
                                          by EazyBone
                                          Picked up this Samsung above thinking it'd be backlights but it isn't. Now MAYBE I'll get lucky.
                                          Found some shorted caps among the panel boards. Each cap along the line is shorted. On every board (3 panel driver boards)I disconnect each side right and left ribbons and they are no longer shorted caps and have about 1.5Mohm resistance (on left and right boards). The middle board has the main board disconnected and the caps are shorted. Last 4 pics show arrow to caps.
                                          Now what exactly do I need to do in order to attempt to fix this issue?
                                          do I have to take each one...
                                          12-24-2023, 06:59 PM
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
