Vizio bad smps ic NEED SOURCE FOR NEW ONE
  • B33M
    • Jun 2013
    • 8
    • Us
    Hey guys I'm having trouble finding replacement and I'm hoping you guys can help me find a place to purchase one of these or a suitable replacement
    Thnx
    Manufacturer FAIRCHILD
    Chip reads
    DA23AX
    S
    00465R
    Last edited by B33M; 05-24-2018, 02:18 AM. Reason: Formatting moves my s which should read vertically 3sr
  • B33M
    • Jun 2013
    • 8
    • Us
    Re: Vizio bad smps ic NEED SOURCE FOR NEW ONE
    Bump.....
    • nomoresonys
      • 12332
      • U.S.
      Can you put up a good close up picture of it, whats your full model number? maybe someone will recognize the part.
      • jetadm123
        • 2169
        Possibly FSGM0465R, but without photos......
          +10. Pictures of the IC and the whole board + model number of the TV will help.
          • R_J
            • Jun 2012
            • 9627
            It could also be a FSQ0465RS, Have a closer look at the lower number, is the first number a '0' or 'Q'
            • B33M
              • Jun 2013
              • 8
              • Us
              Model VIZIO MA470NV
              https://drive.google.com/file/d/1PVV...w?usp=drivesdk
              https://drive.google.com/file/d/1gco...w?usp=drivesdk
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                It does look like Q0465R
                • B33M
                  • Jun 2013
                  • 8
                  • Us
                  It is Q
                  • B33M
                    • Jun 2013
                    • 8
                    • Us
                    Bump for help on a suitable replacement or a source to purchase this one
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Try Mouser.com or do an internet search on the part number.
                      I would also test all the components around that device to see what else has been damaged.
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        These are available on ebay from the US.
                        • R_J
                          • Jun 2012
                          • 9627
                          FSQ0465RS is also available from digikey (FSQ0465RSLDTU-ND)
                          • rewease
                            Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                            by rewease
                            There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                            Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                            Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                            09-17-2023, 12:53 AM
                          • learnmore
                            Help choosing replacement transformer for Levoit 600S SMPS
                            by learnmore
                            Hello Community,
                            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                            Peace
                            LM...
                            11-04-2025, 09:35 AM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • tofik
                            MOSFET equivalent K8A60DA
                            by tofik
                            Hello guys,
                            I have a shorted MOSFET K8A60DA with the following characteristics:
                            Type Designator: TK8A60DA
                            Marking Code: K8A60DA
                            Type of Transistor: MOSFET
                            Type of Control Channel: N -Channel
                            Maximum Power Dissipation (Pd): 45 W
                            Maximum Drain-Source Voltage |Vds|: 600 V
                            Maximum Gate-Source Voltage |Vgs|: 30 V
                            Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                            Maximum Drain Current |Id|: 7.5 A
                            Maximum Junction Temperature (Tj): 150 °C
                            Total Gate Charge (Qg): 20 nC
                            Rise Time (tr): 25 nS
                            Drain-Source
                            07-19-2023, 05:18 AM
                          • bstewara
                            Vizio P659-G1 Screen Removal / Backlight Replacement
                            by bstewara
                            Hi All,
                            Has anyone had the experience of replacing backights on the “P” series Vizio tv?
                            Model number P659-G1
                            This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
                            Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
                            Thanks in advance...
                            09-26-2022, 10:40 AM
