LG 50pm6700 with shorted upper buffer board
  • goldbird78
    • Feb 2018
    • 188
    • canada
    I have a 50PM6700 that has a shorted upper buffer board so I removed the board and tested the tv. As you can see it has two transparent grey bands on the bottom half. Is this another problem or just due to the upper board being removed ?
  • R_J
    • 9518
    Re: LG 50pm6700 with shorted upper buffer board
    It's likely your lower buffer to panel connections are not seated properly. or it could be a bad lower buffer also
    • goldbird78
      • Feb 2018
      • 188
      • canada
      Yep....Turned the TV back on now no lower picture at all and the Ysus voltages were jumping around like crazy. Disconnected the lower buffer too and now my ysus voltages are back good and stable. Looks like I'm on the hunt for buffer boards.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • modtool
        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
        by modtool
        Hi to all,
        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
        04-01-2025, 08:22 AM
      • Yanleb
        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
        by Yanleb
        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
        D608, good
        D618 RF101L4S, good (See warning 1 below)
        D619 RF101L4S, good (See warning 1 below)
        D865 RF101L4S, shorted (See warning 1 below)
        IC464 Inverter HA MC74HC1G14, shorted...
        03-09-2020, 12:00 AM
