LG 37LV3500 No Picture, Backlights working
  • neilc6
    • Nov 2015
    • 1550
    Found a scorch mark on the tcon shield and burnt out IC on the Tcon.
    Screen has a 1 pixel vertical blue line at left edge and splotchy screen at an angle (like it wasn't cleaned well underneath the panel).
    Unplugged LVDS cable and blue line goes away so looks like it is from Tcon and not panel. Splotchiness not that visible when viewing directly from the front and probably not too visible with an image.
    Replacement Tcon boards are around $30 USD.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 37LV3500 No Picture, Backlights working
    When you replace the T-CON Bd. the blotchy screen should clear up.
      I think what you are going find out is that the panel is bad and caused the IC to burn up.
      The blue line went away when removing the LVDS cable due to no more 12V to run the T-CON.
      • neilc6
        • Nov 2015
        • 1550
        Any other opinions/experiences? The ebay seller cancelled my tcon board order. Can't find any exact part matches on ebay. There seem to be several different versions of this tcon - shopjimmy says mine is 2484B stamped on the board.
          • 12206
          • U.S.
          If you had a spare IC you could replace it, then if it cooked the replaced IC, would be a very good bet for bad panel, don't know if there's a way to test the panel.
          Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
          • neilc6
            • Nov 2015
            • 1550
            I found a board on Aliexpress for $8. Picture showed 2484B and got a 2484C with extra connector. Plugged it in and got half a screen. Checked the tcon ribbon on the bad side and the connector is melted where it attaches to the flex circuit. Should have done a better inspection. Would have been a good find. Was a nice thin TV.
            Edit add: Tearing it apart, lots of damage on the left side flex. Looks like a coffee was dumped on that part of the screen. TV is edge-lit hence the thinness.
              Thanks for the follow-up.
              • mrsith
                Samsung UE58TU7100K - no picture, vertical line
                by mrsith
                Hi.
                Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                02-07-2023, 11:18 AM
              • DXseekerMO
                TCL 55US57 backlights, no picture.
                by DXseekerMO
                So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                Power Supply, main and T-CON board are working.
                Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                Unhook FFC from left side...
                09-18-2021, 03:56 PM
              • Awsmessymail
                Vizio E701i-A3 backlight only and now no backlight
                by Awsmessymail
                Hello all,
                I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
                I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
                As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
                02-13-2024, 11:04 PM
              • stinger
                Samsung UN70TU6980FXZA no sound no picture but does have backlights
                by stinger
                When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                04-17-2024, 03:06 PM
              • shelby5041
                Samsung LCD TV no picture backlight on no 12v at tcon
                by shelby5041
                hi
                i have a samsung lcd tv
                it powers on with sound and backlight but no picture
                all voltages from PS are good 12v 3.3v and 5v
                whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                no 12v at the tcon fuse
                i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                the odds of having 2...
                10-08-2021, 08:21 AM
