Vizio VO32L FHDTV 10A Powers ON will not Power OFF No Pic or Sound
  • rebelkustoms
    • Sep 2015
    • 150
    Re: Vizio VO32L FHDTV 10A Powers ON will not Power OFF No Pic or Sound
    Ok here is an update on this one. I looked into an Eeprom and it was 15$ with no real guarantee that was my problem. I elected to go ahead and get a main board on ebay for 20 with free shipping from a recycler. Put it all back together and plugged it up and DAMN now it has a picture problem big time. I have attached some photos, it comes on and I can see the no signal message and can pull up and go through the menu. It seems as the vertical position is wrong and the screen is mostly green or blue with pixellated fuzzy purple wording and menus. This set is really testing me, but its just one I had laying around and became determined to fix. Any help would be very appreciated thank you guys so much.
      • 12330
      • U.S.
      Try a factory reset.
      • rebelkustoms
        • Sep 2015
        • 150
        I did a power cycle and a reset through the menu and no dice. I am just wondering what I am dealing with here, I am guessing a T-conn issue possibly, if anyone can confirm through past experience I was wondering if there is any way to fix this on a component level, or am I in new board territoty. Thing that really puzzles me is how could this thing have a power issue, then a main board issue and then a T-conn issue if that is the problem?
          • 12330
          • U.S.
          Could try a firmware update/reapply.
          • CapLeaker
            Leaking Member
            • 8352
            Originally posted by ivtec
            Hi capleaker; does the Epprom comes pre-programmed? i have Vizio E320-B2 in same symptoms and suggested fix the epprom!
            Those from SJ are drop in.
            • rebelkustoms
              • Sep 2015
              • 150
              Im not sure if I can do that on this old guy. I am looking and looking for firmware files to upgrade but I am kind of caught in a loop of little or no info. Seems like the only ones with firmware update are the smarttvsand smartcast models. If you have a source for this stuff let me know.
                • 12330
                • U.S.
                #27
                That is a tough one, there's some in one of the stickies above but finding the right one is like trying to pick fly shit out of pepper.
                • rebelkustoms
                  • Sep 2015
                  • 150
                  Well this is about where I draw the line on this one, it may remain one of the great unsolved mysteries of our time, if anyone needs parts off this like recapped power supply or VO 32L/ VO 37 L Main board let me know before it gets recycled.
                  • Amlan Chatterjee
                    • Sep 2016
                    • India
                    #29
                    You can replace the eeprom from the old board and give a try
                      • 12330
                      • U.S.
                      #30
                      Guess it's possible your new mainboard is faulty or maybe you need a tcon, could try testing the tcon GAMMA voltages and reseating, cleaning the connectors. Could be the old AS-15 or equivalent acting up, maybe try another factory reset, sometimes the first doesn't take.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #31
                        Is the mainboard set up for the correct lcd panel. Can you change the panel model in the service menu?
                        • ChaosLegionnaire
                          by ChaosLegionnaire
                          09-13-2022, 09:02 AM
                        • ggil44
                          Vizio M65-E0 No Picture, No Sound
                          by ggil44
                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                          09-03-2024, 08:30 PM
                        • csmith
                          Vizio D50u-D1 Powers up no picture
                          by csmith
                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                          issue. Set will power up with remote but not power off....
                          07-11-2025, 11:52 AM
                        • LEECH666
                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                          by LEECH666
                          Good day ladies and gentleman!
                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                          01-19-2024, 05:46 PM
