Black horizontal lines on Samsung plasma TV
  • Semovski
    • 18
    • Bulgaria
    Hello all
    I have a Samsung plasma TV 42 inch which has black lines and strange pink color. What could be ba. Checked caps but it is not. When it is working I can hear strange noise as the old square TVs used to have.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Black horizontal lines on Samsung plasma TV
    You need to check the voltages at the various test points marked on the circuit boards and compare them to what is given on the white panel label.
    What is the model number?
    • Semovski
      • 18
      • Bulgaria
      Model is Samsung S42SD-YB05.
      Do you mean to test powerboard on the picture. Not sure if it is a power board failure
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Without any voltage readings you really cannot say for certain what the fault may be.
        The voltages given on the panel have test points you need to compare with that can be found on the Ysus, Zsus and power supply boards
        Manual available from here
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          The voltages mentioned here are: Vs, Va, Vsc and Ve. These are the 'Vital Signs' and are set for each Panel. The expected voltages are on the white panel label attached to the Panel.
          • WildPuppy
            • Mar 2018
            • 61
            • Romania
            I am no specialist, especially on Samsungs, but am I the only one that thinks those black horizontal lines are from the panel to buffer connectors not being seated correctly ? The lines sure look identical to my lines when this was the problem on my plasma...
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              It may well be the buffer connections although the lines appear to be an equal distance running down the screen. For all the buffer connections to be wrong would be surprising.
              Also I believe the pink could be an ageing panel or the voltages need to be adjusted.
              I would at least take some voltage readings and run the test pattern to try an narrow down the fault. But so far no further information has been forthcoming.
              • R_J
                • 9629
                This set uses a plug to connect the panel to the buffer boards, not likely a connector seating problem. You might want to check the lvds cable between the main and control board, make sure it is seated properly at the ctrl board end.
                • steviewonder
                  • Dec 2013
                  • 183
                  • england
                  Assuming all voltages are correct from the psu,a educated guess would be the control pcb..(the t-con of-sorts from a lcd) .These are hard work sets,with the sub-power supply board.Rule out buffer boards,as the lines are equal distance apart.These are very old sets too,but can still produce good results when working,much more reliable,(though complicated) than more modern offerings.
                  Good luck!
                  • arctor
                    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                    by arctor
                    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                    04-26-2025, 05:22 AM
                  • CyberNinja
                    Samsung plasma 50" TV, model PN50C540G3F, has black horizontal lines
                    by CyberNinja
                    First, the black horizontal lines even overlay the TV's menu. Does this behavior indicate that it's the plasma panel that's defective? If not for the black lines, the TV works just fine. I've cleaned the 6 connectors between the panel and the Y-buffer board, causing no change in the black lines. Visually, the 12 ICs on the Y-buffer look brand new (no holes, etc.). I put my fluke meter in continuity mode and tried to perform the "short" test on the 6 panel ports and found many shorts. But I don't think I'm doing the "short" test correctly and I'm hoping someone can provide guidance....
                    01-10-2021, 09:38 PM
                  • noipi
                    samsung Oled 65 Horizontal Lines and Flicker
                    by noipi
                    I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                    10-14-2025, 02:11 AM
                  • Ihandyrepair
                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                    by Ihandyrepair
                    Hi guys
                    I just started fixing 4k TV few months ago. so I am still learning a lot
                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                    then it started to show the ghosting white image.
                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                    it has 3 thin small boards at the bottom of the...
                    12-05-2022, 04:18 PM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
