Sammy PN50B650. Excellent display cept for 3 thin horizontal lines
  • Michale32086
    • Nov 2011
    • 1453
    Want to confirm that it's a panel issue..
    Things I have checked...
    The buffer board connection cleaned and reseated.... The tab bonds off the X-SUS cleaned and reseated.. The connector off the Control board and the LVDS connector between Main Video & Control board cleaned and reseated..
    Missing any other possibility???
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sammy PN50B650. Excellent display cept for 3 thin horizontal lines
    Have you checked the last buffer chip for any problems. It does look like either those lines are not being driven or you may still have a ribbon connection problem. Just a thought.
    • Michale32086
      • Nov 2011
      • 1453
      Thanx for the reply...
      Attached is a pic of the last 2 buffer chips.. They look OK, but I don't have the expertise (and likely, the equipment) to check them beyond the visual..
      As far as the ribbon connection, do you mean the LVDS cable??
      Thanx again...
      • R_J
        • 9551
        Like dick said, check the buffer ic's, I doubt its a bad connection since the ribbon plugs into a socket on the buffer board. Also in your last picture, having that ribbon on the Z-sus side unpluged will have no real effect, all those ribbons on that side of the panel are connected together.
        All that is required to check the buffer ic is a meter with diode test
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Hopefully the youtube video will help and its the bottom socket your interested in checking.
          • Michale32086
            • Nov 2011
            • 1453
            Youtube video helped a lot.. I get no continuity when, as I understand it is a good thing.. I didn't do the diode test because I think I found the issue..
            Although it's hard to make out from the pics, it looks like the metal contacts have worn down and are obscured by the plastic housing...
            When the TV is powered up, I can't make all the lines disappear, but I can get it down to 1 thin line or a bunch more lines, by rocking the connector slightly to/fro...
            Dunno if I have the dexterity to clean/scrape the plastic residue from the contacts.. Barring that, it's likely a buffer board replacement will fix the problem..
            • Michale32086
              • Nov 2011
              • 1453
              Final dispo on this..
              Ordered a replacement buffer board.. Still have the same 3 lines..
              I guess the bear got me this time...
              Thanx to all for the input..
              • budwich
                • Jul 2015
                • 3097
                did you check the "other end" (ie. the connector that plugs into those connectors on the board. It is likely that those connectors have an issue.
                • Michale32086
                  • Nov 2011
                  • 1453
                  Yea, and I even crimped them a bit to make sure they were making good contact..
                  I can only assume that the issue is where the tab bonds (for lack of better term) mold into the panel...
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4343
                    • Italy - Milan
                    There's a rich literature about that around 2010 Samsung plasmas that often has a problem like yours, the lines are not fixable, there's an electrical problem in the buffer board driving, sometimes is broken the buffer sometimes also the y-sus but i suspect the fault comes from a high ripple psu, so if you want to save some money selling the tv with the lines, you can maybe stop the appearing of further lines by checking the el.co., if it worth the pain..
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • Ihandyrepair
                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                      by Ihandyrepair
                      Hi guys
                      I just started fixing 4k TV few months ago. so I am still learning a lot
                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                      then it started to show the ghosting white image.
                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                      it has 3 thin small boards at the bottom of the...
                      12-05-2022, 04:18 PM
                    • ggil44
                      Sony XBR-65X750D Horizontal lines bottom of screen
                      by ggil44
                      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                      05-30-2023, 07:51 PM
                    • noisykid
                      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                      by noisykid
                      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                      12-30-2024, 07:15 PM
                    • x_orange90_x
                      Samsung UN46C8000XFXZA Horizontal lines
                      by x_orange90_x
                      I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                      I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                      07-15-2023, 05:06 AM
