Samsung UN60H6203AF LED TV Screen Won't Turn On
  • vergezee
    replied
    Re: Samsung UN60H6203AF LED TV Screen Won't Turn On
    Originally posted by budm
    The readings are not correct.
    The exposed pins that you can see from the Top side of the board are the ODD number pin, the EVEN number pins you will have to probe from the back side of the connector using thin probe.
    There is pins assignment chart printed on the board for those 10 pins, so you should have 10 pin names and Voltage for each pin except for the GND pins.
    So according to the chart:
    Pin1 A13V = ???V
    Pin3 A13V = ???V
    Pin5 A13V = ???V
    Pin7 A13V = ???V
    Pin9 GND
    Pin 2 UD = ???V
    Pin 4 PWM_BLU = ???V
    Pin 6 PS_ON = ???V
    Pin 8 GND
    Pin 10 GND
    Ok thanks for clearing that up. I was a little confused from the diagram. I'll check it out tonight after work.
    replied
    Pin1 A13V = ???V
    Pin3 A13V = ???V
    Pin5 A13V = ???V
    Pin7 A13V = ???V
    Pin9 GND
    Pin 2 UD = ???V
    Pin 6 PS_ON = ???V
    Pin 8 GND
    Pin 10 GND
  • vergezee
    replied
    You didn't yet... on the PSU connector CN803 pin 4. Actually measure all the pins on that connector and post the pin out name and the DC voltages measured.
    Ok thanks
    CNM803
    1/2 - UD: 14V
    3/4 - PWM_BLU: 14V
    5/6 - PS_ON: 14V
    7/8 - GND: 15V
    9/10 - GND: 0V
  • CapLeaker
    replied
    Originally posted by vergezee
    I thought that's what I did lol ?? Sorry, I'm a rookie... Can you tell me what I did wrong?
  • vergezee
    replied
    I would do as suggested in post number 9, see if the signal is being sent, assuming and skipping basic testing steps=not good.
  • vergezee
    replied
    Originally posted by maxvalutech
    I'm somewhat nonplussed by post 10 where you record ' backlights came back on ' so did they ? If so problem isn't led string circuit.
    Yes, they came on only when testing the voltage
    replied
  • maxvalutech
    replied
  • dick_barton
    replied
    Budm, I stand corrected. The board does indeed say the working led voltage and current. 326V @ 410mA.
    replied
    The LED Voltage/current chart as printed on the board (BN44-00775A) shows 326VDC @410mA, so getting over 400V seems to be about right without the load.
  • dick_barton
    replied
    Have you read through this thread. Gives the voltages you would expect to find on your power supply. Show working backlights to be 113V working.
    replied
    Are those Voltage readings are made with the black meter probe attached to the chassis GND?
    It looks to me the LED power supply is not seeing the Load (LED strips) so the output Voltage went up very high. You have open circuit (I.E. bad connectors on the LED strips) or bad LED.
    Samsung BN44-00775A
    http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
  • vergezee
    replied
    Sorry for the delay... finally got a hold of a multimeter from a buddy of mine and checked the voltage on the connection to the LEDs. Here's the results:
    With TV turned on and LEDs plugged in to Power Supply:
    D+: 469
    D+: 469
    NC: 0
    S-: 360 (Backlights Came Back On)
    NC: 0
    S+: 360 (Backlights Came Back On)
    NC: 0
    D-: 0
    D-: 0
    With TV turned off and LEDs unplugged from Power Supply:
    D+: Decreasing Voltage
    NC: 0
    S-: 0
    NC: 0
    S+: 0
    NC: 0
    D-: 0
    D-: 0
    I'm no expert, but those 469V and 360V readings are really high, aren't they? Lol
  • CapLeaker
    replied
    This TV set is very known to have bad LED's. However, turn the TV on and measure the VDC of the BLon pin on the PSU, in order to make sure the main board is actually turning on the back lights.
  • thoma
    replied
    Training Samsung 2014
    Wait until GET MANUAL APPEARS!!!
  • maxvalutech
    replied
    Well that's good and bad perhaps. The set is working your LEDs aren't. Time to check the PSU connectors markings and voltages with the set turned on and post them for the people here who will guide you from there.
  • vergezee
    replied
    Ok just got home and checked. No backlights working but when I shine a flashlight on the back while toggling the menu, I can see the image on the screen!
  • maxvalutech
    replied
    These days LEDs are very suspect when PSU seems to be working (audio OK) but it pays to check the basics plus voltage outputs first as marked on that board near the connector to which they apply. Your led output is top rhs of PSU with leads going into the back panel of screen and that output voltage should be checked and all of them recorded in your next post together with the ref marks. Multimeter's are cheap but be careful testing particularly around PSU and especially near bottom half of that board marked HOT.
  • tvtimmy
    replied
    The word "torch" is the proper English word for our flashlights. Just to stop anybody from taking a flamethrower to their tv. Haha. Always wanted to try that. Haha.
  • Andrew F. Ali
    replied
    Does the screen have a glow as if backlights are on but there is no picture information?
