Re: Samsung UN60H6203AF LED TV Screen Won't Turn On
Use a torch and check if you can see a picture on the screen. Try toggling the menu button and see if it's on screen.
Hi everyone! Woke up to terrible news that our TV wasn't turning on yesterday.
I unplugged it, waited a minute, plugged it back in and turned it back on. The light by the power button blinked 5 times (not sure if that's an error code, or if that's normal), and the screen still remained off.
I have an optical cable running from the TV to our home theater system and could hear audio when I turned on the XBOX , so it seems it's getting power and the screen just isn't coming on.
I've never worked on a TV before, so I could really use as much help as possible in diagnosing which part went bad. I took the back panels off to take a picture (attached). Any help is greatly appreciated. Thanks so much for your time!Tags: None
by JunkmanJimboSamsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
Please help. Thanks in advance! -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ? -
by String2016I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
by andrestecnoHi everyone,
I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
Thanks in advance!
- Loading...
