sharp lc-46le600 with red fix on front
  • biro
    • Apr 2018
    • 4
    • Italia
    Hello everyone, I need your experiences to help me with this TV .... I'll give you a short history, the TV arrived in protection with red LED steady so I began to look on the internet as much info as possible from the manual of repair to the service mode. Entered the service I found "error lamp" then as per the procedure I reset and I also updated the firmware and the TV seems to be back as new .... after a few weeks I came back, I repeat the procedure but this time the front led from red becomes green ... but nothing, black screen and no backlighting ..... tried a couple of times and finally now remains on red led fixed .... at this point I just have to open it and start making some measurements .... from switch off to on I have BU5V [5V] - AC_DET [3.5V] - PS_ON [2.3V] while the UR13V line and the VLED arrive for an instant about 11V and 136V respectively and then go down to zero other measure on C7122-C7123 there are about 390V visually the board seems ok also by ohmic measurements on the main components .... what I would like to ask you I can try the card outside the TV, without the load of the LEDs and if you do it activate (I assume PS_ON at least 2V) or try the stris LED without having to disassemble the panel if the power board is not faulty.
    thanks to anyone who can give me some advice and sorry for my english translate
    • 12331
    • U.S.
    Re: sharp lc-46le600 with red fix on front
    https://www.youtube.com/watch?v=mUvclBfaMXg It is suggested that you use resistors so nothing gets shorted in case of accidental or erroneous meter lead contacts during testing.
      We need pictures of the whole backside of the TV showing all the boards top see how they are connected together, then we need good clear straight shot pictures of the whole top and bottom side of the power supply board, also need close up of the LED connector so we can see how many wires are used on the LED connector.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I reckon you have a 'Bad Backlights' issue from what I've read. However. it could be a malfunctioning LED Driver, also. Do what budm asks in Post #3
        • biro
          • Apr 2018
          • 4
          • Italia
          thank you, for your answers ... as soon as I can try to take some pictures the tv being large is not my possession but in the owner's house.
          • biro
            • Apr 2018
            • 4
            • Italia
            I enclose the photos of the power and the simple scheme and one more in detail
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Do you have 3.3V (TP7503) as well as your BU5V
              Does the relay (RL7102) click in as the 13V comes up.
              Without the 13V the relay contacts will not stay latched closed
              You could try to check the power supply by disconnecting the main board from the power supply and then
              Connect Pin 11 (BU5V) to Pin 12 (PNL_POW) using a 1K resistor [CN7501]
              Connect Pin 11 (BU5V) to Pin 10 (PS_ON) using 1 1K resistor [CN7501]
              You may be able to switch the backlights on by connecting Pin1 (3.3V) to Pin 2 (BL_ON) connector CN7603
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
              • Egidio85
                SHARP LC-40LE814E does not turn on 2 flashes
                by Egidio85
                hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                07-21-2023, 11:49 AM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • sefoster
                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                by sefoster
                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                11-20-2022, 09:29 AM
              • gavenb
                Sharp LC-80LE661U 80 inch
                by gavenb
                Hi folks!
                I have a LC-80LE661U that had some interesting issues.
                Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                11-12-2023, 02:05 PM
