Pioneer 1410-HD Plasma Vertical Line Top Right 1/3rd
  • Michale32086
    • Nov 2011
    • 1453
    I got in a hulking monster of a 65" Pioneer Plasma TV...
    Any idea what could be causing that line (see pic)??
    If it's not any easy fix, I am thinking of just using it as a display monitor in the front of my shop.. Kinda scared ta put it up on a wall, though..
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Pioneer 1410-HD Plasma Vertical Line Top Right 1/3rd
    I'm not even going to say it unfortunately. Just use it like it is.
    • Michale32086
      • Nov 2011
      • 1453
      Yea, that's my thinking as well..
      • chrismurphy
        • May 2014
        • 251
        • australia
        Not certain how the drive is done on this tv but look for drive board on the top RHS connections to the panel . Tap the connector lining up with the panel or un clip and re clip the tab connector , see if that fixes the problem
        Almost 99% not a panel fault
        • Michale32086
          • Nov 2011
          • 1453
          I'll check that when I get into the shop tomorrow. Monday is my day off..
          The thing is built like a tank... Heavy thick metal frame.. It's gonna be fun to tear down..
          Not sure if it's relevant, but the "line" is actually made up of 2 or 3 very thin lines. And they change color.. Sometimes shades of red (red, orange, yellow) sometimes shades of blue (blue, green)
          Thanx for all the replies..
          • Michale32086
            • Nov 2011
            • 1453
            OK fiddled with the tab bonds and the buffer board.. Still has that line.. Ordered a replacement buffer board..
            Hopefully the problem is in the board and not the panel...
            Thanx for the help.. I'll follow up and advise the result..
            • Michale32086
              • Nov 2011
              • 1453
              Final dispo on this..
              Turns out it was in the display panel.. Replaced the buffer board, still had the same quarter line..
              Oh well.... I'll pair it with an XBOX 360 system and, for $100, it will make someone an awesome 65" gaming monitor..
              Onward and upward...
                Definitely a dead panel. You should know better than replacing the buffer board because that deals entirely with rows. There is no failure of the buffer board that could cause this fault. Literally nothing could fail in that way on the buffer board, due to the principle of operation (see my previous posts on why buffer boards should be called scan drivers, and why they are pretty easy to diagnose really.)
                • Michale32086
                  • Nov 2011
                  • 1453
                  "Something that would have been good ta know YESTERDAY!!!!"
                  -Adam Sandler, WEDDING SINGER
                  Just kidding..
                  Yea, live and learn.. It only cost me $12 to find out what a nimnull I am...
                  But I did get a win today.. A Panny P60"... Another Dead As The Proverbial Doornail Panasonic.. Ordered a new Main Video board and it came up like a champ!
                  So, all in all, not a bad day..
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Yea. I knew it was a bad panel. That's why I said what I said earlier. Just run it as is. NEC/Fujitsu had this problem quite a bit in the mid 2000s.
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Yes ya did.. OTOH Hope springs eternal..
                      • otaku_nut
                        Vizio E701i-A3 fixed but now has red vertical line
                        by otaku_nut
                        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                        08-19-2025, 06:11 PM
                      • TrueSword88
                        Kogan - KALED65XU9220STB - Blue Vertical Line
                        by TrueSword88
                        Hi all.
                        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                        The line just happens to coincide with the end of COF and start of the next COF (attached).
                        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                        Hoping to fix...
                        05-05-2023, 04:28 PM
                      • almarhum
                        To fix laptop screen vertical line by working on its EDP cable
                        by almarhum
                        Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                        As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                        05-07-2024, 02:12 PM
                      • mrsith
                        Samsung UE58TU7100K - no picture, vertical line
                        by mrsith
                        Hi.
                        Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                        This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                        Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                        02-07-2023, 11:18 AM
                      • canadaboy25
                        LG 50PG10 Plasma Vertical Line
                        by canadaboy25
                        Hey guys, I'm being offered an LG 50PG10 plasma with a vertical line running down the screen.
                        Apparently, if you give the TV a good smack on the frame above the line, it will go away for a while.
                        Does this sound like a bad solder joint or loose ribbon cable? Or a bad panel? If it's not likely to be a bad panel I will likely pick it up.
                        What do you guys think?
                        Thanks...
                        11-24-2020, 11:50 AM
