150uf at 450 wv Large Capacitor Blown - I've Never Seen This... Have you?
  • barryra
    • Aug 2013
    • 107
    I work on tv's off & on & have repaired about 100 TVs over the years. I opened up the back of a Philips 47pfl7403d/f7 and saw that the large 150uf at 450 wv was totally expanded and blown wide.
    I'm just curious if any of you have seen this often.? I don't see any any other blown capacitors but I may change some of them in their surrounding area. Also do you think there is any other issues I should check out before I order parts? Thank you
    I asked on the AVS forum but have not seen any replies.
  • mariushm
    • May 2011
    • 3799
    Re: 150uf at 450 wv Large Capacitor Blown - I've Never Seen This... Have you?
    It can happen... lightning strikes, power phases being shorted in such a way that you'd get 300v+ in the device, active pfc circuits breaking and sending high voltage in those caps...
    • barryra
      • Aug 2013
      • 107
      Thanks for the reply. Do you think the tv should work after I replace those 2 150uf caps or should I replace all caps?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        These caps are filters in the rectifier circuit and they can fail, after all it they are man-made and active in circuit. I would suggest you test the bridge rect and the switching transistor/s also.
        • JohnCT
          Lurker
          • Apr 2018
          • 32
          • US
          Yep, I've seen about a dozen or more. Several were from bad house wiring (open neutral doubling input voltage), but most were just runaway high ESR. These supplies run 24/7, and when they start getting hot, you can get a thermal runaway. The hotter they get, the worse the ESR gets and they may even get electrically leaky. Once the vent opens, they spew and vent themselves out. You'll find the cap weighs about a quarter what a good one of the same size weighs.
          John
          • arenat
            • Nov 2015
            • 22
            • Argentina
            An open resistor in the voltage sense of the PFC could be the issue .
            • barryra
              • Aug 2013
              • 107
              I'm a little ashamed to show my novice but can you tell me where this/these resistors are located?
              Thank you very much.
                You need to upload good clear straight shot pictures of the whole top and bottom side of the board to be able to locate the feedback resistor network.
                • barryra
                  • Aug 2013
                  • 107
                  Thanks budm... I took 4 pictures.
                    Need pictures of the bottom side of the board because they will be SMD type resistors connected in series in the PFC feedback section..
                      • 12200
                      • U.S.
                      http://www.shopjimmy.com/philips-272...pply-unit.htm# Pics. of power supply if that's the one.
                      • barryra
                        • Aug 2013
                        • 107
                        Hopefully... All that's needed are the capacitors replaced... thanks for checking the board out.
                        • JohnCT
                          Lurker
                          • Apr 2018
                          • 32
                          • US
                          Well over 99 percent that all you need is a new cap(s).
                          AFAIK, most if not all pfc controller ICs will shutdown with overcurrent detection, the type that happens when the pfc capacitor is over volted.
                          John
                          • barryra
                            • Aug 2013
                            • 107
                            John
                            So... I me need to change more than the capacitors since the larger capacitors were blown? Thanks
                            • JohnCT
                              Lurker
                              • Apr 2018
                              • 32
                              • US
                              Not sure of your question.
                              If the pfc filter is vented and dried out, just change it. Change any other electrolytic caps on the primary side that check high ESR or show signs of venting (values between 2.2 to 47 ~ 50v for instance). Otherwise, just change the pfc cap and go.
                              John
                              • barryra
                                • Aug 2013
                                • 107
                                John
                                Okay, I'll do that. The capacitors arrived today from Digikey... I live about 2 hours away so the parts get here in 1 day. Thanks for your help! I really appreciate it.
                                  Leave the meter probes on the cap's legs then turn on the TV and see how high the Voltage goes up to, make sure you will able o unplug the cord in case the Voltage goes over 400VDC.
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    I have seen the bottoms of the caps blow out. Almost tear the leads out of the board.
                                    • barryra
                                      • Aug 2013
                                      • 107
                                      I am having a difficult time melting the solder on this board. Is there some type of coating on top? I'm using a Hako soldering iron at 750.
                                      • tvtimmy
                                        • Mar 2015
                                        • 1160
                                        • usa
                                        Hot air or a real soldering jron? If its real just melt some new lead free solder on it and then reheat each leg and pull them out with a wiggle.
                                        • MeetingIncapable
                                          Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                                          by MeetingIncapable
                                          I am new to repairing computer electronics, so excuse any mistakes I make.
                                          A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                                          I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                                          I wanted to replace the capacitor, but I have two questions:
                                          • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                                          • How do I determine the rating/value of this capacitor? or something
                                          05-04-2024, 09:56 AM
                                        • NuclearSpartan
                                          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                                          by NuclearSpartan
                                          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                                          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                                          I don't see any other visible damage anywhere else on the board....
                                          11-14-2024, 02:32 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
