Found a blown capacitor - is it necessary to replace?
  • expertreader
    • Sep 2025
    • 10
    Hi all, Acer Nitro 5 - GH51M LA-K862P Rev 1A motherboard. I went through all the troubleshooting steps but couldnt find a short on any coils. By chance, ended up finding a blown capacitor PCZ49 which is suppose to be 2.2uF. I can see plenty of 2.2uF in the same +5VALW line which will all parallel up anyway - do you guys think it is critical for this cap to be replaced or i can get away without one?
  • mon2
    • 14914
    You should be fine to operate without this capacitor. If available, you can use another capacitor here with the same or higher voltage rating. For example, 4.7uf or 10uf.
    • expertreader
      • Sep 2025
      • 10
      Thanks a lot for that. This capacitor is ultra small and I am afraid of effectively soldering another one in its place and hence the question. This was bringing the whole +5v rail that is always on and laptop wouldn’t show any signs of life. I am hoping that this is the only fault on the board as I believe always on 5v line controls all the other voltages as well and can explain why I didn’t even have +19v power rail present.
      • cap__
        Can I replace 15uf capacitor with 22uf?
        by cap__
        "If I wanted to replace an old 15uF/400V capacitor with a new one,
        I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
        11-29-2023, 11:16 AM
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
