Phillips TV no backlight
    • 12331
    • U.S.
    Re: Phillips TV no backlight
    Did you test it out of circuit?
    • DjKrish
      • Oct 2012
      • 354
      • SG
      Yes i did.
        • 12331
        • U.S.
        That's a head scratcher, if you could get the working board again, you could test them both with your meter, seems like the faulty component should test off, unless you have a bad solder joint or something like that?
        • DjKrish
          • Oct 2012
          • 354
          • SG
          Originally posted by dick_barton
          Check the values of the following components are within specification
          R9101 1M +/- 1%
          R9102 1M +/- 5%
          R9103 1M +/- 5%
          R9104 22K +/- 1%
          C9101 10nF
          C9102 100nF
          and also the solder connections of IC9101
          R9102 and R9103 - according to service manual is 1M but when i pop it out and look at it, its under 5 color range and the value is 10.5Ohms
          Brown, Black, Green, Gold, Brown
          But when i measure it with MM, it shows under 1M reading
            • 12331
            • U.S.
            Wonder if C9105 could be the problem?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              It is a 1Mohm resistor.
              The schematic says both R9102, 9103 are 5% so should read a minimum of 0.095M and a maximum 1.05M. Measure without your fingers touching the probes or end of the resistor since that will affect the reading.
                • 12331
                • U.S.
                #27
                Ok, its silver not gold, so 1.05ohm.
                  • 12331
                  • U.S.
                  #28
                  According to post 17 it's a little over the 5 %, 943m, I would switch it out, just to eliminate it from suspect, might explain why your meter probe kicks the lights on.
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    #29
                    R9103 AND R9102 has been replaced with new resistors. Still same
                    • DjKrish
                      • Oct 2012
                      • 354
                      • SG
                      #30
                      Anyone pls help?
                        • 12331
                        • U.S.
                        #31
                        Pictures are out of focus, can't read the numbers.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          Did you measure the resistors you use to replace the existing ones and (with your meter) and were they within the resistance range indicated in an earlier post bearing in mind their % tolerance.
                            Never mind, the schematic does not match your board.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              Is C9105 (22nF) capacitor case cracked on top?
                                BTW, what is the P/N of that IC9101? LCS700LG?
                                https://www.badcaps.net/forum/attach...7&d=1525502099
                                I am trying to read the P/N of that bracode sticker.
                                Is it PLTVEY741XA, FSP600403 3073086?
                                C9102 (100N 50V) is OK? You can try tagging on another cap in parallel to see if the power supply will stay on.
                                • petch08
                                  • Feb 2021
                                  • thailand
                                  #36
                                  Hi, I had this same problem on philips 50pft5100, I would like to know how this problem is solved. Please let me know, thank you.
                                    • 12331
                                    • U.S.
                                    #37
                                    No idea, the OP quit...yet ANOTHER eternal mystery.
                                    • DanPoka
                                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                      by DanPoka
                                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                      02-15-2025, 05:05 AM
                                    • Comp_Pro
                                      No Backlight Macbook A1990 820-01041
                                      by Comp_Pro
                                      Hello all,
                                      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                      Tests performed:
                                      There is no backlight even with a good screen.
                                      Backlight IC is receiving the correct support voltages.
                                      Fuse F8400 ok
                                      Current sense resistor R8400 ok
                                      Backlight IC is receiving 3.3V on enable pin.
                                      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                      Backlight IC receiving 5V from PP5V_G3S
                                      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                      05-06-2024, 10:23 PM
                                    • cheebster
                                      iPad Pro 12.9 5th Gen Backlight Issue
                                      by cheebster
                                      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                      Anyone...
                                      05-20-2025, 09:17 AM
                                    • gabrielA7
                                      Macbook pro A1706 / Backlight flex cable compatibility
                                      by gabrielA7
                                      Hey guys!!
                                      I’ve got a question here!
                                      I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                                      Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                                      Here’s what the bot told me:
                                      I said to him: “I’m going to install the 821-01229-A.”
                                      ChatGPT replied:
                                      Understood — but before you solder or install the 821-01229-A,
                                      11-11-2025, 03:26 PM
                                    • triplefour
                                      TCL 75S421 has sound but no backlight not even a flash
                                      by triplefour
                                      TCL 75S421
                                      PSU BOARD: 40-L402H8-PWD1CG
                                      it shows not even a flash of backlight when powering up.
                                      but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                      testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                      unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                      i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                      with mb connected, PSON...
                                      11-17-2023, 09:54 PM
