Insignia NS-46E340A13, no sound with 75ohm, turns itself on
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Hello everyone. Just got an Insignia NS-46E340A13 with an interesting issue:
    With the 75ohm antenna in hooked up it has no sound, but does have sound with HDMI and audio/video in (RCA jacks). I don't have headphones to check for sound there. It also turns itself back on after shutting it off with either the remote or power button. When I enter the service menu the "speaker select" option allows for no changes.
    When I went to look at it the set would not power on in any way, but when I got it back to my laboratory here and plugged it in, it turned on. The picture is great, the backlighting looks appropriate and there are no other indications of problems save for no audio with 75ohm and turning itself back on.
    I will be having a closer look sometime this weekend so I thought I'd post this now and see if anyone has any initial suggestions.
    They call me......."threadkiller"
    • 12330
    • U.S.
    Re: Insignia NS-46E340A13, no sound with 75ohm, turns itself on
    Make sure the TV is not set to SAP (secondary audio protocol), no audio options in the sound menu? did you try a factory reset?
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      I started messing with those settings after looking at your post and voila, audio shows up! Wondering if the set would now power itself back up I turned it off, it turned itself back on and audio is gone even after messing with the SAP settings.
      I tried a factory reset with no change. I can't find any firmware anywhere for this TV, thought about trying an update, nothing on the Insignia website.
        • 12330
        • U.S.
        Always a shame when there's virtually no product support, found this, not familiar with them tho, can't tell from the ad if its just the dump they are selling or dump and chip, you would need an eeprom and programmer if so, programmer is about 3 or 4 bucks on ebay if you don't have one, might do the trick if it's an eeprom issue. https://www.tampaelectronicfix.com/p...0-ns-46e340a13
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          Yeah the lack of support from the manufacturer is not helping and I appreciate you sharing that. Just don't want to do any repairs without some experienced guidance and it looks like I've run out of road at this site. The more posts I've made on various TV's the less answers I seem to get.
          Thanks again for the replies nomoresonys and thanks again for that link.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Board pix if that will help?
            I pushed the power button then unplugged the IR/button board and the set still powers itself on.
            Also tried a moderate amount of heat on the main board with no change in sound.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              One more observation...when I switch from English to Spanish the speakers will sometimes make a buzzing sound until I switch back to English, then all's quiet.
                • 12330
                • U.S.
                Check voltages at cn902, I think the 12 v are the ones that provide sound.
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  I checked and there is 12v present at the power supply and the main board.
                    The 12V is OK because you do get sound with HDMI input.
                    Does this TV have RCA (RED/WHITE) audio line out?
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      Thanks for the reply budm, here's a pic of the RCA jack ID's. Never seen Pb and Pr, would those be outputs? I plugged the converter box I use for DX'ing in to the L, R and video jacks and it had sound/video.
                        • 12330
                        • U.S.
                        https://www.cnet.com/forums/discussi...-cable-257287/ similar problem.
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          Thanks for the link, I had a look at that last night trying to self-help. Sound like an incompatible or problem cable box on that thread. I'm pretty sure my problem is the opposite but I'm not sure. Mine has sound with accessories and none with the 75ohm in.
                            Those are Input for Component Video + L/R Audio.
                            At this point it seems to be something in the audio Tuner section since you were able to get the Audio when switching the SAP.
                            It may be FW problem. I believe these day Insignia are made by Hisense.
                              • 12330
                              • U.S.
                              What stood out to me was that they had to keep going into sound settings and making adjustments every time they switched inputs. "I have the same problem on a Insignia 22" LCD. You need to reset the input source to component every time you turn on the TV. The video will come on when you turn on the TV but not the sound until you go into the meu and reset the source input to component as edellen suggested"
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                The thing is now when I switch to Espanol the speakers start this buzzing noise that changes pitch. The minute English is selected the buzz stops.
                                I did find a speaker with a headphone compatible jack and the sound is the same as above.
                                When I first looked at it, it wouldn't turn on at all. The first thought that came to my mind....eeprom, or corrupted firmware. The buzz/no buzz on SAP along with coming back on by itself seems to confirm that? It comes back on with the IR/button boards unhooked.
                                If I turn it off manually, unplug it and plug it back in it will not turn on until I command it.
                                Do you think a FW update might help....if I can find a download? I've yet to locate one.
                                EDIT: The service menu has a "EEPROM INIT" command? on it. Is this a repair utility by chance?
                                  FW may help but not easy to find since the TV is made by third party, which ever one can provide them at the lowest price.
                                  • DXseekerMO
                                    • Feb 2018
                                    • 1119
                                    • US
                                    Thanks budm, so would a pre-programmed EEPROM replacement put me ahead of the curve here? I thought about getting some freeze spray and cooling it off to see if the problems disappear, just have none around.
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      Just in case it's related this artifact shows up after the set is on for a while. Change the channel and it disappears then comes back after a while. The picture seems a bit grainy at times too.
                                      It's got some gremlins.......
                                      • ChaosLegionnaire
                                        by ChaosLegionnaire
                                        09-13-2022, 09:02 AM
                                      • LEECH666
                                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                        by LEECH666
                                        Good day ladies and gentleman!
                                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                        01-19-2024, 05:46 PM
                                      • jose6326
                                        Insignia Ns-l22x-10a no picture only sound
                                        by jose6326
                                        When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                                        When i was removing the back cover i heard a rattle.
                                        Removed the metal plate and the heat sink was off (see pic)
                                        would this cause a no picture/image issue?
                                        What is used to put back the heat sink
                                        07-30-2024, 11:03 PM
                                      • Christos Tsiligiannis
                                        Marian Trace Alpha sound card repair help
                                        by Christos Tsiligiannis
                                        Hello to the forum.
                                        My name is Christos, I am new to the forum here and i am posting from Greece.
                                        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                        So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                        11-18-2024, 05:26 AM
                                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                        This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-12-2024, 02:30 PM
